Old Feb 09, 2009, 04:40 PM
EricClark is offline
Find More Posts by EricClark
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
Build Log
1/6 Sig J-3 Piper Cub 71"
Well, its been a while since I've built a glow plane, the last was a Kadet Senior about a year ago. I guess I don't have much to say, I'll just be posting here as the build goes on.
Eric
EricClark is offline Find More Posts by EricClark
Old Feb 12, 2009, 02:58 PM
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
Well, here's a pic to show that I've at least started.
Latest blog entry: Blade 600X Winter Flying
Old Feb 12, 2009, 11:14 PM
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
For those, if any, that are interested, I will be using a Thunder Tigre GP42 engine with a 10x6 prop in this Piper Cub. I am attempting to make it relatively scale, but not at the expense of excessive time. I don't want to build it for 2-5 years, so as much detail as I can put into it in a reasonable amount of time, I shall try to make it scale-like. The wings are going to be a two piece removable assembly so that it will be more transportable with some kind of tube spar holding them together.
I now have both fuselage sides built and the right side has a scale working door.
Eric
Old Feb 13, 2009, 03:16 PM
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
Some progress...
Old Feb 13, 2009, 06:44 PM
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
More progress.
Old Feb 13, 2009, 08:28 PM
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
And more progress.
Old Feb 13, 2009, 10:01 PM
DPlumpe is offline
Find More Posts by DPlumpe
AMA 8711, FCC K4WZA
DPlumpe's Avatar
Salem, SC
Joined Mar 2003
Sig's 1/6 scale Cub is a great plane, Eric.
I worry a bit, though, about putting a .42 on it. Their present Cub design is an update of Chuck Hollinger's, published in Jan., 1955, Air Trails magazine and kitted by Berkeley, then Sig. Chuck used a .19 in his. RC gear was heavier then, but flying was relatively sedate.
I have the present Sig Cub with an OS .26 4-stroke. I like it a bunch - realistic flying is at half throttle, 2/3 with floats - but have to admit most folks would go for a bit more power.
The only real problem might be getting it down without having to kill the engine. Make certain you have a really good low idle. And at the top end, you'll have unlimited vertical!
Have fun!
-Dave
DPlumpe is offline Find More Posts by DPlumpe
Old Feb 13, 2009, 10:53 PM
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
Haha, indeed. I tried using this engine in my Kadet Senior and it was a tad bit underpowered so I figured it would work good in this plane. I don't plan on ever flying WOT cause it would be overkill, but it does idle very well, and I love the sound when its rumbling at the low end. I'm not a fan of its high pitch whining at full throttle. I hope it'll fly great at 1/2 throttle so its more scale like. I like also like that a 10x6 appears almost scale on this cub and I'm thoroughly enjoying building this kit. Thanks for the info!
Eric
Old Feb 14, 2009, 03:08 PM
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
Getting there.
Old Feb 14, 2009, 07:45 PM
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
Its starting to actually look like something.
Old Feb 15, 2009, 09:36 PM
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
Got a little more done today... The scale doors open both top and bottom now.
Old Feb 19, 2009, 05:55 PM
ak49flyer is offline
Find More Posts by ak49flyer
Clear prop!
ak49flyer's Avatar
Soldotna, AK
Joined Dec 2008
Subscribe! Glad I found this! I'm building this kit as a Super Cub http://www.rcgroups.com/forums/showthread.php?t=969764 ; I about freaked when I saw your door pic; it looks just like mine! What are you using for hinges on the top window? Looks great!
Josh
ak49flyer is offline Find More Posts by ak49flyer
Old Feb 19, 2009, 05:56 PM
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
Been working on it a little, not much though, been busy with the Army lately. However, I did manage to make the landing gear near scale like with elastic shock absorbers. I'll get pics later tonight hopefully, or as soon as I can.
Eric
J-3 Piper Cub 1_Aeronut Giant Scale Airplanes 1 Mar 15, 2008 11:19 AM
Great Planes J-3 Piper Cub Kit GSAV8R Aircraft - Fuel - Airplanes (FS/W) 1 Jan 04, 2004 05:32 PM
Sig J-3 Piper Cub 1/6 Scale kit BrianRickman Aircraft - Electric - Airplanes (FS/W) 2 Aug 19, 2003 06:12 AM
Wattage J-3 Piper Cub Toywizard Parkflyers 3 Aug 30, 2002 07:35 PM
Graupner 6v speed400 w/2.33:1 gearbox and Herr J-3 Piper Cub for sale cloudhopper Aircraft - Electric - Airplanes (FS/W) 6 Mar 13, 2002 01:45 PM
