Old Mar 03, 2015, 09:41 PM
North Simcoe Flyers
rcwings's Avatar
Midland, Ontario, Canada
Joined May 2007
Originally Posted by rcflyinff View Post
Looks excellent Mike! I can only hope mine will turn out half as nice as yours. I came across a .61 4-stroker for mine. Do you think this will be a good match? I've got to get back working on her again.
What engine is it? I am putting in an RCV58 four stroke in mine. Hoping it should provide scale like performance. Being that the RV-4 is rated for a .48 - .70 FS, a .61 should work fine unless it is one of the early four stroke engines that may be less powerful compared to most modern versions.
rcwings is online now Find More Posts by rcwings
Old Mar 03, 2015, 09:55 PM
rcflyinff's Avatar
United States, FL
Joined Mar 2012
Hey rcwings. It is an earlier model OS .61 FS. Going to give it a try as the price is right
rcflyinff is offline Find More Posts by rcflyinff
Old Yesterday, 09:35 AM
North Simcoe Flyers
rcwings's Avatar
Joined May 2007
Hi rcflyinff,
I figured it was an old OS by the displacement you noted in your first post. Some of those earlier four strokes were a little anaemic and heavy. Still, no reason why it should not fly the little RV. Good luck and let us know how you make out!
On my bench....covering process has been well under way with the wing almost completed. Pilot has been recruited and seems to be of the correct size/scale. Definitely on the home stretch now!!!
Old Yesterday, 09:44 AM
rcflyinff's Avatar
United States, FL
Joined Mar 2012
You are much further along then I am. I just about have the fuse done then will start on the wing. What size pilot did you decide on?
Old Yesterday, 09:51 AM
North Simcoe Flyers
rcwings's Avatar
Joined May 2007
I used the Great Planes 1/5 scale. GPMQ9016 I have to run, but will snap a picture of him in the cockpit and post later so you can see what he looks like in the plane.
Marko
Old Yesterday, 04:09 PM
North Simcoe Flyers
rcwings's Avatar
Joined May 2007
Here are some shots of the pilot. He does not look impressed! Suspect he is thinking he will not be flying this year....but I assured him he will in the spring! LOL Wings partly covered and wiring cleaned up. Ready for top skin. Don't mind the fuse as still needs final sanding....
Wanted Wanted:Great Planes RV-4 40 kit Warby Aircraft - Fuel - Airplanes (FS/W) 1 Nov 27, 2005 06:04 PM
FS- Great Planes RV-4 Ready to ... wolfast Aircraft - Fuel - Airplanes (FS/W) 2 May 01, 2004 06:56 PM
Ebay - Magnum XL-61 4-stroke and Great Planes RV-4 kit <24 hrs to go neilo Aircraft - Fuel - Airplanes (FS/W) 0 Feb 23, 2004 01:37 AM
Great Planes RV-4 kit pepflyer Electric Plane Talk 2 Jan 10, 2003 05:09 PM
Great Planes RV-4 conversion anyone? All__talk Sport Planes 7 Apr 01, 2002 03:53 PM
