Old Dec 30, 2014, 02:20 PM
Joined Dec 2014
Help!
Help - Mini CP
I recently purchased the Walkera MiniCP but it developed a fault, when I start it up instead of taking off normally, the helicopter vibrates violently. It eventually manages to lift off the ground but only by about 1 ft and even so it is uncontrollable.
I don't know what to do, any help?
Lamb201 is offline Find More Posts by Lamb201
Old Dec 30, 2014, 02:33 PM
I failed to crash a heli once!
dteel's Avatar
United States, CA, El Cajon
Joined Mar 2014
Did you check all your swash links to ensure they are on the balls properly?
dteel is offline Find More Posts by dteel
Old Dec 30, 2014, 02:44 PM
Joined Dec 2014
Thanks for the fast reply,
Yes I ensured to check all the swash links, they are on the ball joints properly.
Old Dec 30, 2014, 02:52 PM
dteel's Avatar
Joined Mar 2014
Did you bend the feathering shaft?
You know there's a Mini CP thread where they discuss this model of helicopter and the stuff that goes wrong with it?
Old Dec 30, 2014, 03:58 PM
Tucson, Az
Joined Feb 2007
Sounds like main gear has slipped down. Just tap it back up all the way easy like.
I use piece of metal tubing big engough to go over gear hub. Turn heli upside down on firm surface and tap it down easy. Or like said crash may have bent feathering shaft.
dankar04 is online now Find More Posts by dankar04
Old Dec 30, 2014, 04:41 PM
dteel's Avatar
Joined Mar 2014
I considered the main gear but I've never had that cause vibration, generally this just causes a lack of lift when positive pitch is applied. I admit that my experience with the Mini CP is not as great as Dan's so I'd heed his advice and check the main gear as well.
Old Dec 30, 2014, 09:43 PM
Singapore, Singapore
Joined Oct 2014
Yup, i also got this vibration on other heli when main gear slipped down during crash, just push it back and it should be fine.
Jimmylyk is offline Find More Posts by Jimmylyk
Old Dec 31, 2014, 01:44 AM
Tucson, Az
Joined Feb 2007
Even a small gap in main gear will effect lift. Wobble is gyro is not happy as gear is moving up and down.
Old Dec 31, 2014, 09:38 AM
Joined Dec 2014
I'll look at the feathering shaft and the main gear. Thanks for the help
Discussion Best indoor 3D mini heli. HP100BL, Super CP, Mini CP, v977, Hisky HCP100? Varium 3D Electric Heli Flying 4 Jan 14, 2015 12:46 PM
Discussion Help! Which do I get! Walkera Mini CP or HeliMax axe 100ss brushless WhiteCloud Micro Helis 8 Mar 17, 2014 04:52 PM
For Sale Walkera mini cp, super cp, lots of parts!!!! Kenfacemire Aircraft - Electric - Helis (FS/W) 0 Nov 18, 2013 03:12 PM
For Sale Super CP Mini CP billnj2002 Aircraft - Electric - Helis (FS/W) 1 Oct 14, 2013 10:06 AM
Question Super CP v Mini CP???? Cannafish Micro Helis 2 Oct 09, 2013 11:59 PM
