Old Mar 02, 2015, 10:50 AM
Fly as high as the sun
Joined Oct 2014
@PeterVRC: good info on those twin ESC/SBEC/... options.
I guess there's another option to get some more backup/redundancy:
- As both ESC's outputs are wired together in a Y towards the throttle channel of the RX, it's kinda safe to use them as Dynam designed
- However, an extra seperate SBEC is more reliable so I will install one, set to 6V
- Then I'm gonna put a Schottky diode between the SBEC and the Y-throttle cable comming from both ESCs.
This way no need to cut any red wires, the 6V from the SBEC probably will be higher (dominant) as the volts comming from the ESC's BECs, so the SBEC will be the main power for the RX.
In case the separate SBEC fails/burns, the Schottky diode will use the power from the ESC's BECs as provided/designed by Dynam.
icarus the 2nd is offline Find More Posts by icarus the 2nd
Old Mar 03, 2015, 08:29 AM
Australia, VIC, Melbourne
Joined Nov 2006
hehe, super redundancy then! At least for any SBEC failure(s).
PeterVRC is online now Find More Posts by PeterVRC
Yippee! Coming soon! 1500mm Dynam BF-110G in the works! Stay tuned. Nitro_Nancy Nitro Planes 13 Aug 08, 2014 05:36 PM
Discussion dynam 1500mm smart trainer opiejo Foamies (Kits) 3 Nov 12, 2013 06:52 AM
Discussion Unboxing: Dynam 1500MM Smart Trainer hobbypartz Product Announcements 1 Aug 22, 2013 10:44 AM
Build Log Guardian (3D 1500mm wingspan) Home design SU-4ever 3D Flying 1 Feb 26, 2009 10:02 AM
