Old Feb 23, 2015, 01:19 AM
midelic's Avatar
Joined Apr 2012
Yes it would bind.
Yes same process..binding pin pin C0 and GND.
Range the same...if you attach a dipole antenna like original.
midelic is offline Find More Posts by midelic
Latest blog entry: DIY FlySky RX ATTINY85/45
Old Feb 23, 2015, 08:53 AM
Joined Nov 2014
Originally Posted by midelic View Post
Yes it would bind.
Thankss
These days I read their threads, I read that range with XL7105 is over 100m +-
this range refers to testing with PCB antenna of XL7105 in the air or on the ground?
I was looking dipole antennas in the forum, and I found a few that I like
these two are the ones I liked, especially the last one that is most similar to the original.
Which would recommend me? , maybe another model better?
http://www.ebay.com/itm/Airgain-N242...item2ecf4f6514
http://www.alofthobbies.com/40cm-receiver-antenna.html
what range (approx ) i have with any of these antennas in the air?
with the original receiver is near to 3 or 4 km approx
I ask because it will use a mini quad fpv, and I want to be sure of have a sufficient range
does not have much autonomy flight, but maybe at some point is away 1 km +-
thank you very much Again
davidluab is offline Find More Posts by davidluab
Old Feb 23, 2015, 09:05 AM
midelic's Avatar
Joined Apr 2012
It depends also of TX ,With which tx you get 3-4km?
The second antenna is better,First one not so good.Range idk I didn't test.Instead of flying I'm mostly busy coding.
Old Feb 23, 2015, 10:11 AM
Joined Nov 2014
My TX is a Turnigy 9x 20dBm, or around 100mw or less
What do you think of range? Maybe can have 1 km?
Do not forget to fly is the most fun part
Old Mar 01, 2015, 09:54 PM
Joined Feb 2015
Just out of curiosity ( sorry I haven't read all the pages yet) could I build a micro heli board for collective,cyclic servos,brushless main mototr and a brushed or brushless tail. All to work with a flysky tx.
i.r.me is offline Find More Posts by i.r.me
Old Mar 02, 2015, 02:48 AM
Hasi's Avatar
Austria, Stmk., Graz
Joined Sep 2011
MultiWii supports 90deg and 120deg cyclic pitch helis, so I believe YES.
Hasi is offline Find More Posts by Hasi
Old Mar 02, 2015, 07:42 AM
Joined Feb 2015
Hasi thank you for the quick reply.this is relatively new territory for me.May be asking for help in the near futur
Old Mar 02, 2015, 07:27 PM
midelic's Avatar
Joined Apr 2012
Hasi,
It arrived the dc booster ,,,,well is is really small.It uses 2108A ..DC booster(Ithink a chinese chip ME2108...didn;t find oher maker data sheet).I will update the board to accommodate this chip.The inductor stays on only the actual chip and a small shottky diode.,,the rest remain.The schematic is simple.
Old Mar 03, 2015, 04:37 AM
Hasi's Avatar
Joined Sep 2011
Hasi,
Sounds good. How much bigger will the pcb be?
Old Mar 03, 2015, 06:25 AM
midelic's Avatar
Joined Apr 2012
Some size not even a fraction of mm.I use the existing inductor pads ,caps ,........added only the 2108(SOT89) chip and one small shottky diode.
The only problem is that I cannot find easily the booster chip(on aliexpress).....I can remove from the original booster pcb.
http://www.ebay.com/itm/271734570473...%3AMEBIDX%3AIT
I found also some equivalents.
XC6382,XC6383,S8321,RH5RI,RT9261
http://pdf.datasheetcatalog.com/data...8/287019_1.pdf
http://www.ebay.com/itm/10-PCS-XC638...item566672c5b3
http://www.aliexpress.com/item/FREE-...522070792.html
Old Mar 03, 2015, 08:18 AM
midelic's Avatar
Joined Apr 2012
I removed the inductor ,shotky diode and pins..It can be used also as it is(Inductor is on main board).I think I will remove also the existing caps...I have caps on the main board.The pcb is really small 10x11mm.I reduced the weight to 0.2 grams(with pcb).
I trimmed a litle bit reduced the size t-9x7mm.I attached a smaller shottky diode SOT323...now I can glue it on the back of my existing pcb(old version).
Also the inductor value to be changed to 22-33uH..preferably with coil.
Old Yesterday, 02:33 PM
flying beam
blackmoon's Avatar
through the Looking Glass
Joined Apr 2008
I want to use the a FTDI dongle to program an Atmega328 :
Code:
Pinout:
FTDI          MEGA
VCC ----------  VCC
GND ----------  GND
TX -----------  RX
RX ------------ TX
RTS/DTR -------RESET
CTS ----   ??? (SS or SCK)
blackmoon is online now Find More Posts by blackmoon
Old Yesterday, 02:53 PM
midelic's Avatar
Joined Apr 2012
CTS unconnected..or to GND.
Old Yesterday, 03:03 PM
flying beam
blackmoon's Avatar
Joined Apr 2008
So the protocol is asynchronous, something new learned Thx
Old Yesterday, 03:59 PM
flying beam
blackmoon's Avatar
Joined Apr 2008
Finally finished the actuator rx prototype, final version will have the big inductor and TQFP AT328 will be removed and replaced by a smd ferrite bead and the MLF AT328. The module pcb antenna will be cut off and replaced by a wire. Will program/test it tonight or tomorrow depends on my state of mind.
The Allegro A3901 was a pita to solder, needed at least to redo it six times, freaking critter was surfing on the solder bed and pins never aligned... Pins are now +/- aligned and tested for shorts, there isn't, I just hope it isn't cocked by all that heat.
Mini-HowTo TH9X Turnigy FlySky IMax modify module to SMA and 1W booster DIY FPV rotaryboots Radios 5 Feb 03, 2015 05:46 AM
Sold flysky th9x, flysky tx module, flysky 8ch rx snakecrew Aircraft - General - Radio Equipment (FS/W) 7 Oct 02, 2013 03:58 PM
Wanted Flysky 9x V1 RF module gdenton3 Aircraft - General - Radio Equipment (FS/W) 0 Aug 16, 2012 09:58 PM
Wanted Flysky 9x V1 RF module gdenton3 Aircraft - General - Radio Equipment (FS/W) 3 Sep 13, 2011 03:27 PM
Sold Flysky V2 RF Module, Antenna and 8 ch Receiver, $30 shipped CONUS ek123 Aircraft - General - Radio Equipment (FS/W) 0 Nov 20, 2010 02:43 AM
