Old Jan 31, 2009, 05:58 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Leadfeather's EPP Yak 55
In case some of you have not see what Leadfeather has been doing over in the scratch built forum here is a link to some of his very successful designs.
Yak 55
Firefly
PBF
The reason that I am posting here is that I am working with him to bring his designs to those who are not interested in building from scratch. I have an order of foam coming so I can start supplying kits but in the mean time I have put together several Yak 55 kits with what foam that I have. If things take off I will set up a web site to make ordering easier.
The Yak is a very capable indoor aerobatic flyer. The wingspan is 34" and the average weight with out battery is 150 grams (5.4 oz) The kits that I have now are the skinny version which is made from 1.3 lb EPP in 6mm and 9mm thicknesses. These are short kits including the cut foam pieces and a carbon wing spar. Complete kits may be offered later but these are a perfect replacement for a battered airframe using similar components. I can also supply custom air brushed kits.
The unpainted short kit is $25 + $10 shipping.
The airbrushed short kit is $35 + $10 shipping.
Ordering can be done HERE
Here is a build guide
motorhead is offline Find More Posts by motorhead
Old Feb 11, 2009, 03:25 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Here is a good video that one of the scratch builders put together.
video
Old Apr 01, 2009, 09:10 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Well quite a bit has happened sense I first posted this thread. I have come up with a supply of 1.0lb density EPP. Right now I am the only one carrying it. Using this lighter foam we are making what was dubbed a "Fluffy Yak" build and we are getting flying weights of 135 g AUW (4.8oz). These fly totally different and are getting into the F3p performance realm.
I also have put together a short construction video showing how easy this kit goes together. I will be posting it as soon as I get it downloaded.
Most of our local flyers have completely switched from depron to this EPP yak. If flys that good and is not fragile.
Old Apr 01, 2009, 10:44 PM
Livermore, CA
Joined Sep 2004
Where did you get 1lb EPP?
Is bulk or sheet?
Thanks, Butch
Butch777 is offline Find More Posts by Butch777
Old Apr 02, 2009, 05:33 AM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
I am buying it bulk and cutting it down into sheet. The problem is that it is hard to get foam that has the proper stiffness. My last order I had to reject because it had half the stiffness of what we have been using.
Old Apr 02, 2009, 06:14 AM
Odessa,DE 19730
Joined Oct 2003
How do I get one of your kits ????????????
jaldersn is offline Find More Posts by jaldersn
Old Apr 02, 2009, 04:15 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Sorry I forgot to post a link in the first post but it is there now or you can click HERE .
Old Apr 03, 2009, 05:35 AM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
I put together a short construction video on the way I build the Yak kit. It is not comprehensive but I think it covers the basics. After watching it I see that I could have added more info but it was unscripted so it is what it is. I hope it helps someone.
Part 1
Part 2
Old May 05, 2009, 01:44 PM
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Still kitting these Yaks MH? If so I'll take one like airbrushed like Diggs with Bildo Baggins across the wing.
bildo baggins is online now Find More Posts by bildo baggins
Old Jun 01, 2009, 10:03 PM
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
I got Jamie wanting a 55, but he doesn't have time to cut it. You still offering these? He will need a standard kit. IF you sell him one, i am sure it will get mentioned even more on ATTF
Diggs
Diggs is offline Find More Posts by Diggs
Old Jun 01, 2009, 11:16 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
I still have foam for a few. I replied to his email.
Old Jun 20, 2009, 11:05 AM
Elkton Md
Joined Aug 2004
still having alot of fun with this one... it is a must have
the 1.0 epp is really light weight, yet stiff enough that i only needed one piece of carbon on the main wing.... thanks again...
fro540 is offline Find More Posts by fro540
Old Jul 27, 2009, 06:22 PM
allthingsthatfly.com
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
Here is my vid of Mikes cut plane. I even built it heavy.
Great price, perfect cuts
GFBurke is offline Find More Posts by GFBurke
Old Jul 27, 2009, 10:38 PM
I am the BBQ Ninja
Willmsy's Avatar
United States, MN, Woodbury
Joined Jan 2003
Mike, do you have anymore Yak 55 kits?
Matt
Willmsy is offline Find More Posts by Willmsy
Old Jul 27, 2009, 10:42 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
I build the kits as I get orders and have plenty of foam so order away.
I added a link to leadfeathers build guide to the first post.
Video Great Planes EPP YAK 55 Hepdog Electric Plane Talk 2 Dec 23, 2005 08:08 PM
For Sale GP's Yak 55 3D LND409 Aircraft - Electric - Airplanes (FS/W) 4 Jul 02, 2005 01:00 PM
F/S G.P. YAK 55 local p/u only mdlifcrisis Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2005 04:51 PM
F/S Great Planes YAK 55 Electric deedee Aircraft - Electric - Airplanes (FS/W) 2 Mar 08, 2005 08:09 PM
F/S Yak 55 from Extreme Flight R/C Robert Belluomini Aircraft - Electric - Airplanes (FS/W) 3 Nov 12, 2004 11:46 AM
