Old Jul 27, 2014, 06:27 PM
Ireland, Dublin, Dublin City
Joined Feb 2014
did i kill my lipo
hi
i unintentionally over used my lipo today
i am using a giant power 4500 mah 4s battery
it is not puffed
do you think it is damaged and should go into the bin?
thanks
ferdy55 is online now Find More Posts by ferdy55
Old Jul 27, 2014, 06:39 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
What does "over used" mean to you. Are you going by the 4459mah put back in?
For all we know it might actually be a 4800mah pack. If it was actually 99% discharged, the motor would have had zero power at the end. Was that the case?
If it's not puffed I'd use it again and again.
hoppy is offline Find More Posts by hoppy
Old Jul 27, 2014, 06:42 PM
Joined Feb 2014
i mean i landed at a loaded 13.5 volts
i still had power
ferd
Old Jul 27, 2014, 07:21 PM
United States, WA, Woodinville
Joined May 2014
That's over 3.3V per cell. Lower than you want to take it regularly but a single incident won't hurt it. Charge it up and use it.
James_S is offline Find More Posts by James_S
Old Jul 27, 2014, 08:50 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
i still had power
ferd
I agree with James, the unloaded voltage should have been around 3.7V which is OK.
But that begs the question of why a pack 80% discharged would take about 20% more mah in than it could hold (unless it was grossly under rated).
Something is still a mystery.
Old Jul 28, 2014, 04:29 AM
Sverige, Värmlands Län, Filipstad
Joined Jan 2009
ferdy55,
Some indications that a LiPo battery has seen it's better days can be if one or more cell get higher and higer IR (internal resistance) - some charger can display value of IR, one or more cell takes long time to reach 4.20 volt (fully charged) or its performance start to decrease. Or if it swell (but even if a pack swell it is not always immediately ready for recycle bin, but probably soon so). As long as none of these things happen I would just continue to use a pack like Yours. A LiPo pack usually can cope with one such incidence You had but regular drain below lets say 10% left of capacity You will probably get problem with the pack. Rule is to have approx 20% of capacity left at landing (checked by using a timer in radio that beeps after x minutes or telemetry with current sensor to keep track of mAh used for example).
/Bo
bossee is offline Find More Posts by bossee
Old Jul 28, 2014, 05:36 AM
Joined Feb 2014
thanks for all of your replies bossee hoppy and james
it was a one off
i am pretty careful most of the time
ferd
Discussion did i just kill my brand new lipo battery? steelersfan Rock Crawlers 2 Apr 06, 2014 05:16 PM
Discussion What the heck happened here? Did my lipo alarm kill my battery? Vertigo72 Batteries and Chargers 22 Mar 16, 2014 10:32 AM
Discussion Did I Kill My LiPo? jcowgar Batteries and Chargers 9 Jan 02, 2014 02:05 AM
Help! Did I kill my 4s4p pack of lipos? CA'ed fingers Batteries and Chargers 17 Sep 23, 2004 07:43 PM
Did I kill my LiPo? Cpt_Spitfire Batteries and Chargers 4 Jan 21, 2004 04:07 AM
