Old Dec 04, 2013, 11:13 AM
Illegitimi non carborundum
grosbeak's Avatar
Joined Mar 2011
Ski / wheel combination for Hobbistar 60
I thought I'd try a hand at designing a ski / wheel combination for my Hobbistar 60. Thanks to the guys at my LHS and to the information at http://www.modelairplanenews.com/blo...eady-for-snow/. If I have time after my other winter projects for this plane I'll give it a shot.
Clicking the image will enlarge it.
grosbeak is offline Find More Posts by grosbeak
Old Dec 05, 2013, 10:34 AM
grosbeak's Avatar
Joined Mar 2011
I have shortened the length to 24" and after various feedback and a review of a lot of images have moved the wheel back 60% from the tip from its previous position at 40%. Version 2:
Old Dec 06, 2013, 12:58 PM
United States, MD, Frostburg
Joined Aug 2008
Very cool! Still one of my favorite, lazy, every day flying planes! Thanks for the info!
4075aaron is offline Find More Posts by 4075aaron
Old Dec 06, 2013, 02:09 PM
grosbeak's Avatar
Joined Mar 2011
My pleasure!
Plans are up to version 3.1 - I've added runners to the bottom.
Old Jan 13, 2014, 11:24 AM
grosbeak's Avatar
Joined Mar 2011
I finally got going on the skis yesterday. Off to a great start, I misread my plans, which stated a length of 2' 0". I cut them to 20". As it happens I had to lop another inch or so off the front for prop clearance - no biggie.
Here are the two blanks - 20" x 4".
Next step was to cut the wheel holes. To start, I squared up a stop block on the bench.
Both skis clamped against stop block.
Square outline of wheel hole.
Old Jan 13, 2014, 11:32 AM
grosbeak's Avatar
Joined Mar 2011
I planned to use a hole saw to round off the inner corners, so I drilled 15/64" pilot holes to guide the hole saw's 1/4" pilot bit.
That done, I set the hole saw for 2-1/4" and chucked it in the drill.
First hole done... beforehand I had put a piece of scrap wood under the skis to keep from drilling into the bench top.
Both holes done. The alignment is off a hair on the second hole, but not enough to worry about.
Old Jan 13, 2014, 11:37 AM
grosbeak's Avatar
Joined Mar 2011
Time for a little chiseling.
And some sanding.
Old Jan 13, 2014, 11:50 AM
grosbeak's Avatar
Joined Mar 2011
Time for a test fit. Looking good so far.
I used a compass set to a 2" radius on the centre line 2" back from the leading edge to trace the tip profile.
Skis clamped together, I cut out the tips on the band saw.
Old Jan 13, 2014, 11:59 AM
grosbeak's Avatar
Joined Mar 2011
Next I'll trace the outline onto the 1/4" ply I'm using for the spines and cut them out. Just getting started with that.
Old Jan 13, 2014, 12:01 PM
Joined Aug 2008
Very nice!
Old Jan 13, 2014, 01:25 PM
grosbeak's Avatar
Joined Mar 2011
Thanks! As I progress I see I'm probably going to veer away from the design - we'll see how it all turns out.
Old Jan 13, 2014, 08:06 PM
grosbeak's Avatar
Joined Mar 2011
Got the spines drawn - Before cutting I clamped the blanks and screwed them together. You may notice there are two where the drawings show four - I have decided to simplify and go with a single spline per ski. Well, one in front of the wheel and one behind - but both on the centre line. I am very much on the fly now and will make changes to the drawings later.
Here they are, fresh from the band saw. They still need to be cut to their final length - see the bottom photo.
Here are the aft spines.
Here's how they'll go on the skis.
Old Jan 13, 2014, 08:08 PM
Joined Aug 2008
Why did you decide on just one?
Old Jan 13, 2014, 08:11 PM
grosbeak's Avatar
Joined Mar 2011
Marking the point on the ski where the curve begins.
I grabbed an offcut of the same 1/16" plywood made some passes with the mitre saw as a test.
The test piece was very bendy and clamped well. Not sure I like those huge kerfs, though.
I tried smaller kerfs with a fine back saw but the depth is very hard to control.
Old Jan 13, 2014, 08:19 PM
grosbeak's Avatar
Joined Mar 2011
I felt it would offer all the stiffness I needed while keeping down the weight and simplifying the build.
Discussion Stuffing a DLE 20 into a Hobbistar 60 grosbeak Engines 113 Mar 02, 2014 10:14 AM
Discussion Hobbistar 60 - from one aileron servo to two grosbeak Fuel Plane Talk 22 Nov 30, 2013 06:13 AM
Wanted Looking for wing for great planes hobbistar 60 cleansho93 Aircraft - Fuel - Airplanes (FS/W) 1 Oct 13, 2010 11:10 PM
Discussion What size wheels come on the Hobbistar 60 RTF? Street Doc Fuel Plane Talk 2 Aug 10, 2007 08:12 AM
Discussion Few questions for a Hobbistar 60 Pilots12 Beginner Training Area (Fuel) 6 Aug 28, 2006 08:58 AM
