Old Oct 10, 2011, 10:41 AM
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Hobbyking TEK SUMO fpv
Ok did the maiden FPV with my new TEK SUMO from HobbyKing today!
Doesn't seem to be much interest for the wing on here , but anyway here the footage if anyone's interested.
It flies really nice , and I would recommend it to anyone looking for a short range bird! Great fun for only $30
Hobbyking TEK SUMO Maiden FPV (5 min 28 sec)
octane81 is offline Find More Posts by octane81
Old Oct 11, 2011, 12:55 AM
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
I was thinking of buying one for FPV but wasnt really that impressed by the fact that all the important stuff is just hanging off the bottom.
How does it all go when belly landing?
Teamsherman is offline Find More Posts by Teamsherman
Old Oct 11, 2011, 01:16 AM
United States, NJ, Manchester
Joined May 2011
Swift is the same way right? One reason I stayed away from it.
Bear_Pants is offline Find More Posts by Bear_Pants
Reply With Quote  (Disabled)
Old Oct 11, 2011, 01:22 AM
Member #1
Joined Aug 2011
I think i'll just kit out my Zagi, all the important parts are on the top and it flies quite nicely even with extra weight onboard.
Old Oct 11, 2011, 01:38 AM
Joined May 2011
I fly my grim reaper. Has been more than perfect to me.
Old Oct 11, 2011, 06:21 AM
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
As long as you land on grass theres no problem. For $30 its a bargin!
Old Oct 11, 2011, 07:21 AM
Multi Rotors Rule ! ;-)
SkyEyes's Avatar
United Kingdom
Joined Jul 2010
Well done octane, as long as you are happy and enjoy flying it, thats the main thing.
Plus at that price, it would be hard to buy a better Wing for cheaper. Good vid.
SkyEyes is offline Find More Posts by SkyEyes
Old Oct 11, 2011, 08:41 AM
IsaacW's Avatar
Christchurch, New Zealand
Joined Nov 2010
Seems a bit silly everyone being put off by the bottom mounted gear. Just because the manufacturer has given you holes to put stuff doesn't mean you have to put it there. I've got one on the way for fpv, I plan to cut the holes right through and then push the epp bits to the bottom. Or I may just fill in the holes with some scrap pieces. One problem I have is that I am wanting to use a pan servo for my cam and also have the battery completely imbeded into the foam on the top. With the pre-installed spars there isn't quite enough space at the nose. I thought that I could cut out the top wing spars and then recut the slots so that the spars curve around at the middle. A bit like if you were using one continuous spar. This would give me much more space at the nose and also add a bit to the strength of the spar system. Octane, how hard do you think it would be to cut out the spars? Are they glued in very well?
Cheers
Isaac
IsaacW is offline Find More Posts by IsaacW
Old Oct 11, 2011, 01:44 PM
Spektrum Dev Team
aaronredbaron's Avatar
United States, IL, Champaign
Joined Apr 2002
Here's how I dealt with mounting the gear on my swift
Swift 2 FPV setup (1 min 37 sec)
aaronredbaron is offline Find More Posts by aaronredbaron
Old Oct 11, 2011, 05:26 PM
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
http://www.youtube.com/watch?v=dab9GdILtNA
Thats a nice wing !
What motor / prop combo are u using? And what about flight time?
Old Oct 12, 2011, 06:06 PM
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Tested RCTimer 1400kv motor with 8x4 prop , and got between 15-20min flight time out of the 2200mAh lipo.
RCtimer 2200kv only gave me max 10min time, tested with 7x5 and 6x4.
Old Oct 12, 2011, 07:21 PM
Spektrum Dev Team
Joined Apr 2002
I'm using a Great Planes Rimfire 28-30-950 on an 8x6 prop. I easily get 15 minutes out of it on a 3s 2200mAh. love the way it flies, very locked in and groovy. (I'm assuming the TEK SUMO is basically a knock-off of the MS swift 2...)
FPV Swift Hunting Down FunCub (5 min 20 sec)
Old Oct 12, 2011, 10:16 PM
United States, WI, Eau Claire
Joined May 2011
+$32 shipping kinda takes away the "bargain" thing.
banzi28 is offline Find More Posts by banzi28
Old Oct 13, 2011, 06:42 AM
IsaacW's Avatar
Joined Nov 2010
I was actually just looking at that motor. I'm curious about the flight time, is the 15-20min near max flight time or is that you being a bit hard on the throttle. Also what sort of vertical are you getting from that setup? Thanks
Edit: Also wondering what type of prop you're using. Some people are using slowflys which tend to draw more amps/create more thrust ?
http://www.youtube.com/watch?v=J7eaMtUv8Sw
I loved the video, it was just so smoooth and as you said 'locked in'. I'm thinking this may be because of your big prop, with a higher kv/smaller prop it may be more jumpy? Anyway, it seems you're able to cruise around 4amps, meaning you'd be able to get around half an hour flight time?! You wouldn't happen to know your auw would you?
Yea the Teksumo is a tiny bit bigger, is denser and has spars preinstalled. I'm loving the centre pod idea. Definitely going to do that to mine!
Yea you kinda have to order in bulk from HK, else the shipping ends up more than the actual product..
Old Oct 13, 2011, 07:03 AM
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
15-20min flight time is just half throttle crusing... vertical is not so great because of the heavy 2200mah lipo + camera up front.
It wasnt great with the 2200kv motor either , but without fpv gear and a 1500mah battery instead it really goes vertical no problem!
Im just using normal thin electic props , no slowflys.
Discussion Problem with FPV camera from Hobbyking haidar Aerial Photography 1 Mar 19, 2014 05:41 AM
Sold Golf Clubs - Nike Sumo Irons and Sumo 2 Driver with Bag - Full Set major.monogram Non R/C Items (FS/W) 9 Aug 11, 2011 02:58 PM
Cool Sumo 3D FPV GallopingGhost FPV Talk 7 Oct 18, 2009 06:33 PM
