Old Feb 22, 2015, 09:25 AM
RCMC is offline
Find More Posts by RCMC
Inanity-Free Zone
RCMC's Avatar
Delaware
Joined Jan 2006
Help!
Removing Covering from Clear Canopy Material
Team,
Yesterday morning I took on a new project for the recovering an older 81" CAP 232. The plane is in excellent condition for an older model but the covering is showing wear and the color scheme is very dated. At this point I have the main wings and the canopy.
The canopy is my biggest concern...a portion of it has been covered with the same covering (such as, Monokote, Ultracote, etc.) as the plane. I started to remove some of the covering that was brittle or bubbling up but the areas that are stuck well are going to be a problem.
There would be no problem sanding with fine sand paper but that will be time consuming. The clear portion of the canopy is in great shape so I need to be careful of any solvents I use for fear of damaging the area that is intended to be that way.
Any ideas?
RCMC
RCMC is offline Find More Posts by RCMC
Old Feb 22, 2015, 10:29 AM
kw_counter is offline
Find More Posts by kw_counter
United States, CA, Hidden Valley Lake
Joined Aug 2002
I have successfully used WD40 to remove glue residue from plastic in the past.
Might be worth a try here.
Good Luck,
KW_Counter
kw_counter is offline Find More Posts by kw_counter
Old Feb 22, 2015, 11:13 AM
RCMC is offline
Inanity-Free Zone
RCMC's Avatar
Delaware
Joined Jan 2006
kw counter,
Thanks for the tip, I'll give that a try. I did forget to mention that the canopy is to be painted where the teal covering is now.
RCMC
Old Feb 22, 2015, 11:42 AM
aymodeler is offline
Find More Posts by aymodeler
aymodeler's Avatar
United States, CT, Hartland
Joined Jul 2011
You could also mask off the clear areas and then go at the covering with a fairly coarse grit sandpaper (say 120), that would make fast work of the covering material. Then go back with fine grit to prep for painting.
aymodeler is offline Find More Posts by aymodeler
Old Feb 22, 2015, 05:22 PM
RCMC is offline
Inanity-Free Zone
RCMC's Avatar
Delaware
Joined Jan 2006
aymodeler,
I was planning to mask off the area just above the gold stripe so that I wouldn't damage the clear section of the canopy during the removal process.
Do you think the existing covering can be heated with a warm iron so that it doesn't distort the canopy material? I know that that material doesn't take a lot of heat to deform it.
RCMC
Old Feb 23, 2015, 07:36 PM
aymodeler's Avatar
Joined Jul 2011
Originally Posted by RCMC View Post
aymodeler,
RCMC
I tried something like that once and ended up wrecking the plastic ... I still think sanding off the old covering will be the fastest and safest way. It should only take about 5-10 minutes ...
Old Feb 24, 2015, 03:28 AM
RCMC is offline
Inanity-Free Zone
RCMC's Avatar
Delaware
Joined Jan 2006
aymodeler,
I tried sanding last night and I believe that is the way to go but this covering is a bear. It has turned very brittle and is stuck to the canopy almost like paint. I have a long way to go.
RCMC
Old Feb 24, 2015, 06:14 PM
Captain Dunsel is offline
Find More Posts by Captain Dunsel
United States, NJ, Browns Mills
Joined May 2005
Have you tried a warm iron?
Captain Dunsel is offline Find More Posts by Captain Dunsel
Old Feb 25, 2015, 03:23 AM
RCMC is offline
Inanity-Free Zone
RCMC's Avatar
Delaware
Joined Jan 2006
No, any suggestions on how to do that?
RCMC
Old Feb 25, 2015, 05:36 AM
aymodeler's Avatar
Joined Jul 2011
You could also try a soft (brass) wire brush wheel on a Dremel. Go real easy though or you will gouge the plastic.
Old Mar 03, 2015, 08:27 PM
ckimmey is offline
Find More Posts by ckimmey
Master of the 1 point landing
ckimmey's Avatar
United States, IN, New Palestine
Joined Aug 2011
I know that you can remove covering from sheet balsa by applying clear packing tape over it and pulling it up. It helps to release the glue. It may be worth a try and definitely won't mess with the clear portions of the canopy.
ckimmey is offline Find More Posts by ckimmey
Old Apr 22, 2015, 12:27 PM
smokinjoe22 is offline
Find More Posts by smokinjoe22
Glider Guider
smokinjoe22's Avatar
United States, CA, Lomita
Joined Dec 2007
I've had good luck using Goo-Gone for this type of thing. It's citrus / acid
based, and also works when alcohol or more aggressive liquids fail to
remove glue residue from stickers etc. Need to get the full strength kind
that comes in the small bottles, not the diluted stuff that comes in spray
bottles. Apply liberally and let it penetrate. Hope this helps.
Smokin Joe
smokinjoe22 is offline Find More Posts by smokinjoe22
Help! Can you REMOVE fiberglass covering from an old plane? Username14 The Builders Workshop 14 Jan 21, 2015 11:25 PM
Discussion best way to remove old covering material planepainter Thermal 10 Nov 13, 2014 12:36 PM
Question Solvent? For removing paint from windows of rc car body to make clear finguz Painting and Finishing Tips 11 Sep 24, 2014 01:37 PM
For Sale Clear Canopy Material iflytailies Aircraft - Sailplanes (FS/W) 3 Jan 22, 2012 07:16 PM
Question Clear canopy material? gavoss Slope 11 Jan 16, 2012 08:38 AM
