Old Aug 14, 2015, 12:26 PM
SpeedsterDEN is online now
Find More Posts by SpeedsterDEN
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
At the dunes today
Flyfly Fox, Dsing the dunes. (1 min 50 sec)
Cheers
Soren
SpeedsterDEN is online now Find More Posts by SpeedsterDEN
Old Aug 14, 2015, 05:19 PM
KiwiKid is offline
Find More Posts by KiwiKid
Aeroplanes fly aerobatics!!
KiwiKid's Avatar
Hamilton, New Zealand
Joined Jun 2005
Really enjoyed that one Soren. Just wondering (and can't see any mention in the thread) did you do any strengthening to the wings /fuse or is it still stock?
KiwiKid is offline Find More Posts by KiwiKid
Old Aug 14, 2015, 05:26 PM
TomTerrific is offline
Find More Posts by TomTerrific
United States, CT, Waterford
Joined Jul 2012
I had the electric motorized version i purchased last November.
I added a carbon rod(arrow) down the wing wire channel for some added strenght. I was really enjoying her till the wing snapped at the top of an aerotow launch in June.
TomTerrific is offline Find More Posts by TomTerrific
Old Aug 15, 2015, 12:47 AM
Joined May 2010
Its still stock, exept for stainless wire for the rudder pull pull, instead of the stock rod ones.
Not the best glider for this kind of fun, but looking great in the air.
Regards
Soren
Old Aug 25, 2015, 09:33 PM
slothy89 is offline
Find More Posts by slothy89
Head in the clouds
slothy89's Avatar
Australia, VIC, Sebastopol
Joined Apr 2012
Hi guys,
Good to see this is still an active thread I'm planning to pick myself up one of these Foxes soon, and just had a query regarding the recommended gear to set this up.
As this will be my first scale glider and also bigger than anything in my current fleet this is a bit new for me. I'm a capable flyer and will be flying this on the slope, and am plenty familiar with a 4 servo wing.
What Servos would be recommended for the wings and elevator?
And what battery setup would be best suited? LiFe or NiMH?
Any other recommendations on supplied equipment that should be replaced and suggested alternatives would be appreciated as well.
Cheers,
Chris
slothy89 is offline Find More Posts by slothy89
Old Aug 26, 2015, 05:19 AM
slothy89 is offline
Head in the clouds
slothy89's Avatar
Joined Apr 2012
Nevermind, about the servo's, I read the rest of the Thread and found SpeedsterDen's links to the servos. They look about what I was expecting.
Still interested in info on whether to run LiFe or NiMH.
And if it's worth keeping any of the supplied hardware.
Cheers,
Chris
Old Aug 26, 2015, 09:34 AM
fredo21 is offline
Find More Posts by fredo21
Never too much detail
fredo21's Avatar
Australia, VIC, Hampton
Joined Jan 2007
I haven't finished mine as yet. The two changes I am planning are like Soren replacing the "piano wire" pull pull rudder with a lighter cables and adding a lower plywood support to the main undercarriage.
I am also considering molding servo covers which don't sit so proud of the wing.
Re battery I will be using a 5 cell NiMH's. Lots of room, weight in the nose not a problem. I made sure all the servos etc I use don't mind the extra voltage and if a cell fails should still fly ok.
Stuart
Cheers,
Chris
fredo21 is offline Find More Posts by fredo21
Old Aug 26, 2015, 11:44 AM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
The landing gear that comes in the box is CR@P. Find something better. Mine broke on the first landing.
Martin Y is offline Find More Posts by Martin Y
Old Aug 26, 2015, 02:07 PM
Joined Jul 2012
2nd Martins landing gear experience... Mine broke in building. I cut aluminum into a "U" shape to make the main gear support.
Question Flyfly 3m fox info required yakhakker Scale Sailplanes 2 Feb 06, 2012 03:46 PM
Question Fox EPO glider 2.3 from HK will it fly safely with this specs? seedo Foamies (Kits) 0 Jan 30, 2012 11:56 PM
Discussion Airfield Fox 2.32 meter electric glider. DWA Slope 1 Aug 12, 2011 04:14 PM
Discussion New releases by flyfly hobby-3 Metre fox , 2.6 Metre ask21 gliders Damian Couzoff Australia 12 Jul 26, 2010 05:11 AM
