Old Nov 30, 2014, 02:51 PM
Joined Nov 2014
Control of DC motor?
Hi all,
I am in the process of designing a miniature jumping robot. To compress a spring we are using a dc motor combined with alot of gearing!! The act of turning the motor on starts the spring compression and at max compression it releases automatically.
I am asking what is the best way to turn on the motor remotely? I really only want to create a remote controlled switch...the catch being it has to be all powered off a single battery and be as small and light as possible.
At the moment I have a spektrum DX6i TX and RX, which I was hoping to use, but could consider other possible Rx components.
I suppose I am seeking help so as to create an elegant solution... I appreciate all input.
I hope this is in order and appropriate.
Thanks in advance
Regards
Johnny Paterson
johnboyjp is offline Find More Posts by johnboyjp
Old Nov 30, 2014, 03:24 PM
Who let the dogs out?
phil_g's Avatar
Pontefract, Yorkshire, UK
Joined Jul 2007
http://www.hobbyking.com/hobbyking/s...USHED_ESC.html
phil_g is offline Find More Posts by phil_g
Old Nov 30, 2014, 04:30 PM
Joined Nov 2014
Hi, Thanks....I think you misunderstand...I am really trying to create a radio controlled switch. I only want to supply a brushed motor with power so it runs at a certain speed, no control of speed is needed.. I also would like the solution to be as small and light as possible
Old Nov 30, 2014, 04:45 PM
phil_g's Avatar
Joined Jul 2007
How about one of these ? http://www.hobbytronics.co.uk/pololu...mall-mosfet-v2
Old Dec 01, 2014, 03:30 AM
Joined Nov 2014
Thanks very much, That looks like the perfect thing. I suppose I now have another question.
The rc switch board can be powered from the Rx ( easiest option) but is there a way of powering the load(DC brushed motor @6v) and the Rx off the same battery, say a 2s Lipo?
I hope this is in order.
Regards
Johnny P
Old Dec 01, 2014, 04:32 AM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
It may depend on how many amps?
Maybe something like this-- http://www.castlecreations.com/products/ccbec.html
or similar
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Dec 03, 2014, 04:21 AM
Joined Nov 2014
Thanks all....we have changed the design to use a different motor so I have solved the problem
Discussion Recommended Brushless DC and AC motor control texts james_28 Power Systems 4 Feb 13, 2010 06:02 AM
Discussion Speed Control for Brushed DC Motor for E Car Conversion jlagran Heli Power Systems 2 Sep 03, 2007 04:26 AM
Discussion Control of a 12V dc motor speed forward/reverse? boyntonstu Dock Talk 2 Apr 27, 2007 05:45 PM
Discussion Is there a way to power and control a DC brushless motor off AC mains? Peter W Power Systems 11 Jan 15, 2007 05:37 PM
control dc motors deltaops88 Electric Power Cars 9 Apr 13, 2005 08:41 PM
