Old Apr 18, 2016, 07:36 AM
tim7 is offline
Find More Posts by tim7
Joined Apr 2013
What advantage would cut vent holes in fue. gas to burshless?
What advantage would you have cutting vent holes in bottom fuselage like is done in gas plane but, for a brushless conversion?
Would they have to be as big?
Would they be worth it?
tim7 is offline Find More Posts by tim7
Old Apr 18, 2016, 08:50 PM
Andrew Schear is offline
Find More Posts by Andrew Schear
Andrew Schear's Avatar
United States, AZ, Phoenix
Joined Mar 2013
You still want to keep your motor and esc cool. Also, with the existing air inlets, the air still needs a place to escape.
Andrew Schear is offline Find More Posts by Andrew Schear
Old Apr 19, 2016, 07:52 AM
Poffertjesporem is online now
Find More Posts by Poffertjesporem
Thumbs are overrated.
Poffertjesporem's Avatar
The Netherlands, NB, Sint-Michielsgestel
Joined Nov 2014
make sure they are bigger (not sure how much), as an over pressure inside the fuse and wings might push the covering of the wood. It also puts an load on the canopy (latch).
Poffertjesporem is online now Find More Posts by Poffertjesporem
Question What gas engines would you recommend for this configuration? LuftwaffeSS Engines 13 Jan 22, 2016 10:34 AM
Discussion To vent...or...not to vent? And what sorts/shape of holes? Flyextreme High Performance 15 Jan 29, 2011 03:41 AM
Vent holes in control surface bays? Dzlstunter Parkflyers 4 Feb 04, 2003 04:42 PM
holy zagi batman... what do u use to cut big holes in foam Beige Foamies (Kits) 6 Sep 17, 2002 01:17 PM
