Old Jan 01, 2009, 05:16 PM
MorrisM is offline
Find More Posts by MorrisM
MorrisM's Avatar
Oklahoma City
Joined May 2004
Build Log
Dirty Birdy 60 with 10S A123 for SPA
For the New Year I have started my Dirty Birdy build. This is my first build log, so please be patient with me.
This is the Bluejay kit, but I am going to use foam wing and stab.
The power will be a Scorpion 4025-12 and 10S A123 battery. The Dewalt battery looks like it will fit just right in the tank compartment.
Starting with the fuse.
Links:
Senior pattern Association
http://www.seniorpattern.com/
Bluejay Airplane Kits. They have most of the classic Bridi kits.
http://www.bridiairplanes.com/
MorrisM is offline Find More Posts by MorrisM
Old Jan 02, 2009, 04:45 AM
MorrisM is offline
MorrisM's Avatar
Oklahoma City
Joined May 2004
The fuse is coming along. I need to get the wing and stab done before I can do much more on the fuse.
Old Jan 02, 2009, 04:50 AM
MorrisM is offline
MorrisM's Avatar
Oklahoma City
Joined May 2004
The motor and battery. I decided to make a bottom hatch. I didnt think a top hatch would work because of the long canopy.
Old Jan 02, 2009, 12:21 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Looking good Morris!
jrb is offline Find More Posts by jrb
Old Jan 02, 2009, 03:26 PM
MorrisM is offline
MorrisM's Avatar
Oklahoma City
Joined May 2004
Thanks JRB. You may have noticed this is the same battery/motor I recommended in the Intruder thread. The 10S A123 is about 4oz heavier than the 6S 3700 lipo I used in the intruder.
I went to a friends house today and cut the stab cores. I haven't done any hot wire foam cutting in 15+ years. They turned out fine. The same friend gave me the wing cores. They were purchased in 1983 from Wing Manufacturing. They are still in good shape after 25 years in the attic.
The next step is sheeting the wing and stab cores.
Old Jan 02, 2009, 06:45 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
I too have a 25year old Wing Mfg wing kit -- generic, not for anything specific!
Old Jan 02, 2009, 07:57 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Subscribe - looks good.......
Old Jan 02, 2009, 08:35 PM
Ed Lyerly is offline
Find More Posts by Ed Lyerly
Recruiter - 60 Amp Club
Ed Lyerly's Avatar
Rutherfordton, North Carolina, United States
Joined Apr 2001
Hi Morris,
Thanks for doing this build thread . The one concern I have is that you will be nose heavy. I think you need to get those batteries further back. A top hatch or a pocket in the center of the wing would allow that.
I'll be following with great interest .
Ed
Ed Lyerly is offline Find More Posts by Ed Lyerly
Old Jan 03, 2009, 12:03 PM
MorrisM is offline
MorrisM's Avatar
Oklahoma City
Joined May 2004
Hi Ed.
I really don't want to move the batteries back past the leading edge of the wing. It would be alot more work. How about I put a pair of elevator servos in the tail? I will also have a receiver battery I can put aft of the CG.
Morris
Old Jan 03, 2009, 03:57 PM
Ed Lyerly's Avatar
Joined Apr 2001
Originally Posted by MorrisM
Hi Ed.
Morris
Morris,
It may not be a problem, but I'm pretty sure you will end up adding lead to the tail. If I were you, I would put rudder and elevator servos under the stab, then maybe add a hatch to the fuselage bottom (as far back as you can) and put the receiver pack there too. You might also consider a 4020 motor .... they are good for a 1.75 oz weight savings in the nose and are good to 1500 watts.
Hope that helps.
Ed
Old Jan 03, 2009, 06:39 PM
MorrisM is offline
MorrisM's Avatar
Oklahoma City
Joined May 2004
Ed, I wasn't too worried about balance, but now I am a bit concerned. I will certainly keep all your suggestions in mind. Thanks for the input.
I tried something new. I sheeted the stab with polyurethane glue instead of epoxy like we used to do. I think it came out OK, but I'm not sure I like the method. I probably just need more practice.
Here's some pics..... More to come, hopefully tomorrow.
Morris
Old Jan 04, 2009, 04:32 PM
MorrisM is offline
MorrisM's Avatar
Oklahoma City
Joined May 2004
Bad news. One of the stabs had a slight bend. Deciding if I want to use it anyway, cut new cores and try it again, or build up the rib stab from the kit.
I have been rounding off and hollowing out the nose. I have the motor mounted, but I am really having to hollow out the bottom block to make it fit.
Morris
Old Jan 04, 2009, 04:42 PM
Ed Lyerly's Avatar
Joined Apr 2001
Looking good Morris ! There is a LOT of sanding and carving with the older kits.
I would get a new set of foam stab cores. You can get them here:
http://www.eurekaaircraft.com/
Ed
Old Jan 10, 2009, 08:48 AM
MorrisM is offline
MorrisM's Avatar
Oklahoma City
Joined May 2004
Ed, I almost ordered new cores from Eureka Aircraft. After much thinking, I decided to go with the stabs I have. There is a slight bend, but no twist and I don't think it will have much adverse effect. I hope not anyway...
So here is what I have done with the stabs.
Morris
Old Jan 17, 2009, 07:25 AM
MorrisM is offline
MorrisM's Avatar
Oklahoma City
Joined May 2004
I have started the wing sheeting. I used up the last of my Hobbypoxy formula 2 epoxy. Hobbypoxy glue and paint was good stuff, I wish they were still in business. I used a syringe to apply the epoxy to the foam. It's applied in a crosshatch pattern, then around the edges, and onto the carbon fiber. I used a squeegee to force the epoxy into the carbon.
I haven't sheeted a wing in a long time. I forgot how soft the 1/16 AAA 4-6lb balsa is. The carbon is necessary as the balsa does not have enough strength.
I will have more pics when the wing sheeting is finished.
Morris
Discussion needed. plans for a dirty birdy 40, i am looking for plans to fix my wounded bird tr miller Competition Aerobatics 1 Nov 10, 2008 08:28 AM
Wanted Dirty Birdy plans, 40-60 size scififlyer Aircraft - General - Miscellaneous (FS/W) 1 May 21, 2006 06:29 AM
Sporty Ep for sale JStory Aircraft - Electric - Airplanes (FS/W) 3 Oct 29, 2001 08:49 PM
