Old Yesterday, 04:38 AM
Blisters is offline
Find More Posts by Blisters
Blisters's Avatar
Australia, QLD, Thorneside
Joined Feb 2013
F002 retract upgrade
I have a question for Davy101 and Dambit. I have my new retracts but the bend in the leg jams hard against the retract motor when in a closed position. I notice in Davy101's photo the trunnion is not parallel with the mounting plate in the retracted position but slightly short of its full travel. How did you get it to stop short. I can't get the leg into the trunnion while in the retracted position because the further in it goes the harder it jams against the motor . I must be missing something simple Here is a photo to show what I mean. Thanks Scott
Blisters is offline Find More Posts by Blisters
Old Yesterday, 06:53 AM
Davy101 is online now
Find More Posts by Davy101
Davy101's Avatar
United States, KS, Leavenworth
Joined Jan 2012
Put the retract in the down position (using a servo tester or by hooking up to your Rx) and then insert the leg. Make sure you grind flats in the right spots for the two set screws. Now with the leg installed, retract the gear to see if it works well. It it hangs up anywhere, adjust the leg as needed. The bend in the leg causes the trunnion to not close perfectly parallel but the control board in the retract has an over voltage cutoff that will stop the leg when the wheel is in the wheel well. After it is working well, secure the screws with a thread locker. Works for me that way.
Davy101 is online now Find More Posts by Davy101
Old Yesterday, 08:29 AM
dambit is offline
Find More Posts by dambit
Most people are stupid!
dambit's Avatar
Australia, QLD, Gold Coast
Joined Oct 2011
Scott, Do not worry about the bend in the leg. I too was concerned about this, but once it is installed in the plane, the wheel contacts the wheel well first and triggers the cut-off.
No need to bend the legs.
dambit is offline Find More Posts by dambit
Old Today, 07:48 AM
Blisters is offline
Blisters's Avatar
Joined Feb 2013
Thanks Davy101 and Steve ! I really wasn't game to rely on the over current protection but gave it a go tonight and nothing smoked I do like how firmly they pull the wheels into the wells. So here is a photo of the repair so far. Not much left to do now
Old Today, 11:09 AM
studioRS is offline
Find More Posts by studioRS
Klassische Segelflugzeuge
studioRS's Avatar
Northern Vermont
Joined Jul 2010
Tried PM'ing Orion Pax to update the first posting links, but just an FYI, I swapped stores and new links are here gents, enjoy.
Available in black or white T-Shirts.
http://www.zazzle.com/focke_wulf_190...31963358871253
http://www.zazzle.com/focke_wulf_190...78315249029482
studioRS is offline Find More Posts by studioRS
Discussion FW 190 1400mm by FlyFly ...wow it's NOT FMS! jbc Electric Warbirds 238 Jul 08, 2015 02:02 PM
Discussion FMS FW-190 800mm range flyball Electric Warbirds 131 Apr 09, 2015 02:30 PM
Discussion fms warbird owners thread warbird_cowboy Electric Warbirds 126 Mar 11, 2015 08:13 PM
New Product FMS 1400mm FW-190 Part II Tommy D Electric Warbirds 647 Jul 26, 2012 03:23 PM
Video Formation Flying - FMS Stuka, Hobbico FW-190, Velocity-RC T-33s, and Tsunamis bwoollia Electric Plane Talk 0 Oct 23, 2011 02:45 PM
