Old Oct 15, 2005, 10:12 PM
mode101 is offline
Find More Posts by mode101
mode101's Avatar
Wellington, Florida
Joined Oct 2005
Ammo Box Lipo Storage Question
I have a military surplus air/water-tight Ammo Box and I want to know if it's okay to leave the lid locked and sealed with lipos inside when being stored. Assume they will be fully charged. Thoughts or suggestions?
mode101 is offline Find More Posts by mode101
Old Oct 15, 2005, 10:28 PM
thinair7000 is offline
Find More Posts by thinair7000
thinair7000's Avatar
Flagstaff, AZ
Joined Dec 2004
I drilled a hole for the wires in mine to charge. Don't know the science but it seems the Lipo explosions are more of a flare burning than an explosion. Vent good or bad?
thinair7000 is offline Find More Posts by thinair7000
Old Oct 15, 2005, 10:33 PM
mode101 is offline
mode101's Avatar
Wellington, Florida
Joined Oct 2005
I won't be charging them in it, but I'm worried about the results of being in a airtight environment. No Oxygen is a good thing but any gas build up to worry about? Don't want any suprises when I open the lid after a week.
Old Oct 15, 2005, 11:48 PM
jbatch is offline
Find More Posts by jbatch
Lawn darts, anyone?
Long Island, NY U.S.A.
Joined Oct 2003
A tightly sealed and locked ammo box may or may not be effective as
a means to confine the outgassing or explosion of a large LiPoly pack.
By confining the batteries that way, you have the makings of a bomb
whose potential explosive force depends on how many packs are in it.
I use a Brinks mini-safe and always leave the lid unlocked, so if one of
the batteries should self-destruct, gas pressure can escape by lifting
the lid, without bursting the box.
jbatch is offline Find More Posts by jbatch
Old Oct 15, 2005, 11:53 PM
PGR is online now
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
In the unlikely event that you should have a vent with flame event in a sealed ammo box, the event will probably blow the box open rather forcefully. RD Blakeslee did some comprehensive testing of vented ammo boxes and the result can be reviewed in the thread Experimental Ignition of a Large LiPo Pack in a Vented Ammo Box.
He also performed the same test in a Brinks Box and reported the results in the thread Experimental Ignition of a LiPo in a Brinks Box
Bottom line: These boxes proved no match for a LiPo vent with flame event.
Pete
PGR is online now Find More Posts by PGR
Old Oct 16, 2005, 07:59 PM
mode101 is offline
mode101's Avatar
Wellington, Florida
Joined Oct 2005
Although I don't know all the details, I read another post on here about Ammo Box strength, the person claimed they had 500 rounds of .45 caliber ammo in a ammo box stored in a garage or house and when a fire destroyed the building(s) the Ammo box was found albeit charred still intact, when opening the box it was noticed that all the shells exploded but the box never lost integrity.
I read the threads on the testing, the one on the Ammo box was for a 4S3P 6000 mah, I only have a couple 3 cell 640 mah packs for now. And I won't be charging them in it, only for storage.
Old Oct 16, 2005, 08:33 PM
ElectRick is offline
Find More Posts by ElectRick
Eye Drather Beef Lying
ElectRick's Avatar
Jacksonville, FL
Joined Aug 2002
I have a smallish ammo box of the type described here (forget what caliber ammo it's for--7.62 IIRC) that I keep my LiPos (about 10-12 packs of various sizes) in. I've noticed a couple times, when I've opened it up after a road trip (lid sealed), there was a faint, but noticeable sweet smell inside when I opened it. Having never vented a LiPo, I presume this is the characteristic electrolyte smell.
None of my packs are leaking that I can see, none have ever been crashed, and none are charging/discharging abnormally. Maybe it's just the nature of the plastic battery cell bags to 'breathe' a little?
Rick
ElectRick is offline Find More Posts by ElectRick
Old Oct 16, 2005, 08:42 PM
PGR is online now
PGR
PGR
Low AltiDude
PGR's Avatar
Joined Jun 2004
Originally Posted by mode101
...when opening the box it was noticed that all the shells exploded but the box never lost integrity.
And you believe that?
The trap house at the trap and skeet club I used to belong to burned to the ground several years ago when the oil heater malfunctioned. In that trap house was a .50 cal. ammo box with about half a box (500 or so) of primers in it. No powder, no loaded rounds .. Just primers. I know because it was my ammo box and my primers.
They went off and opened that ammo box up like it was made of cardboard. The idea that 500 rounds loaded .45 ammo could go off in a like-&-kind box and not blow it apart is absurd.
Pete
Old Oct 16, 2005, 09:30 PM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
So what about some small holes in the box to let the gasses escape or the use of a small engine muffler to let the gases escape and try and contain any flames?
Ohmic is offline Find More Posts by Ohmic
Old Oct 16, 2005, 09:47 PM
PGR is online now
PGR
PGR
Low AltiDude
PGR's Avatar
Joined Jun 2004
I think the most sensible approach to LiPo storage that I've seen is in my friend's basement. It has a cement floor, cinderblock walls, and double-thick 5/8 sheet rock ceiling. He cleared a corner of this basement of combustable materials and layed a half-dozen cinder blocks on their side so the openings were facing up. This makes 12 individual concrete chambers with open tops. Into each of these chambers he put an inch of sand to keep any flame from migrating from chamber to chamber under the block. On top of each individual chamber he put a piece of 12 gauge sheetmetal which just lays there.
Into each chamber goes one battery pack. Should he ever have a vent with flame event, it will be confined to a single pack in a single chamber. By design, the event will displace the piece of sheetmetal over the chamber but the sheetmetal over the surrounding chambers will keep out most if not all burning debris.
He's never had an event and doesn't expect to but the above approach gives him piece of mind. From an engineering standpoint, I think that peace of mind is well deserved.
Me? I just keep my LiPos in my flight box.
Pete
Old Oct 16, 2005, 10:24 PM
jbatch is offline
Lawn darts, anyone?
Joined Oct 2003
I'm with PGR on that ammo box that supposedly contained the blast of
500 live .45 caliber shells. Fragments of brass shell casings flying in all
directions with the sudden release of burning "smokeless" powder would
enough to turn any ammo box into a monster grenade.
An ammo box with a vented lid fitted with a lawn mower muffler would
allow combustion products to escape without destroying the container.
Make sure that, whatever kind of storage box you use, it's kept away
from flammable materials, like glow fuel - or your plane hangar!
Old Oct 17, 2005, 12:18 AM
PGR is online now
PGR
PGR
Low AltiDude
PGR's Avatar
Joined Jun 2004
Originally Posted by jbatch
An ammo box with a vented lid fitted with a lawn mower muffler would allow combustion products to escape without destroying the container.
The ammo box in RD Blakeslee's test was vented with a 3" flex pipe but the event still blew the lid open and released a substantial ball of fire. Yeah, it was a big LiPo pack but I suspect a smaller pack would produce the same results in a box vented with a mower muffler.
Pete
Old Oct 17, 2005, 02:24 AM
EricSoar is offline
Find More Posts by EricSoar
Slope and thermal
Christchurch, New Zealand
Joined Apr 2003
I have an ammo box. I don't charge in it. I store in it. When storing I do not lock the lid down. I just push it down. In the event of a fire/smoke release the lid would easily lift up to release the smoke/fire.
The only purpose for the ammo box is to provide a carry case and possibly direct the fire ball upwards through the lid that would fly open. In the car, should smoke start while driving I can reach the box and throw it out the window. At the field I keep the ammo box outside the car.
I suspect that the purpose of the rubber seal on the ammo box is to protect ammo from the outside world rather than to protect the world from the ammo. Protecting ammo from water keeps it good and protecting it a bit from fire reduces the chance of an explosion. Lipos of less need for protection from the outside world than ammo does.
I did not drill a hole in my ammo box. I just don't lock the lid down.
Eric.
EricSoar is offline Find More Posts by EricSoar
Old Oct 17, 2005, 08:34 AM
mode101 is offline
mode101's Avatar
Wellington, Florida
Joined Oct 2005
Pete
No not really, the claim seemed impossible with all the variables. I was hoping the original poster would answer my post.
Old Oct 17, 2005, 09:48 AM
PGR is online now
PGR
PGR
Low AltiDude
PGR's Avatar
Joined Jun 2004
And there you have it, people!
Pete
Discussion Lipo storage question kenmalecki Batteries and Chargers 3 Nov 05, 2006 09:21 PM
Lipo storage question splatman Batteries and Chargers 1 Jul 15, 2005 11:36 AM
Short Term Lipo storage Question Fast Fly Batteries and Chargers 1 May 22, 2005 10:39 PM
Another Lipo storage question...??? Jim_W Batteries and Chargers 2 Nov 09, 2004 11:14 AM
A different lipo storage question...collateral damage? David Hogue Batteries and Chargers 11 Mar 29, 2004 11:35 AM
