Old Aug 03, 2015, 08:56 PM
hog2soar is offline
Find More Posts by hog2soar
hog2soar's Avatar
Central California
Joined Jan 2010
Help!
Loose screw on horizontal stabilizer need fix
I have a loose screw on the front of the removable horizontal stabilizer on my Predator II.
The threads on the screw appear to be good, but won't tighten up. I really don't want to fill the hole in the pedestal, re-drill and tap.
The screw is holding, you can't pull it out without turning the screw, but you can't tighten it.
Anyone have a simple fix for this? I thought possibly silicone on the threads., so it could still be removed if necessary, but the screw would be seated.
Any help would be appreciated.
Eddie
hog2soar is offline Find More Posts by hog2soar
Old Aug 03, 2015, 09:44 PM
bbbp is online now
Find More Posts by bbbp
a.k.a. Bob Parks
Glendale, AZ
Joined Jun 2008
remove the screw and put a drop of thin CA glue on the threads. Let it dry then re-thread by inserting the screw a bit, backing out and in a bit more, until it is in all the way.
If you have a metal screw to use for re-tapping that is better.
BP
bbbp is online now Find More Posts by bbbp
Old Aug 04, 2015, 10:55 AM
Roy_N is online now
Find More Posts by Roy_N
Roy_N's Avatar
United States, WA, Burien
Joined May 2014
Wax the screw. Car wax will work. Place a drop of epoxy on the threads near the tip of the screw and install the screw in the hole with the loose threads. Let the epoxy cure and remove the screw. You mat need to trim the epoxy to get the stab to sit flat on the pedistal when cured.
Roy_N is online now Find More Posts by Roy_N
For Sale Vapor Horizontal Stabilizer (old vapor) Brand New In Box HelicopterHeav Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Jul 22, 2015 04:18 PM
Discussion Fixing Crooked Horizontal Stabilizer waiweng83 Fuel Plane Talk 7 Feb 26, 2014 09:38 AM
Help! Need Blaster 1 Screw for Horizontal Stab LSF226 Hand Launch 5 Sep 07, 2011 07:43 PM
Wanted Alfa Sabre horizontal stabilizer needed... Algon Aircraft - General - Miscellaneous (FS/W) 0 May 31, 2009 11:54 PM
fixing a snapped horizontal stabilizer??? gabe6090 Beginner Training Area (Fuel) 5 Oct 05, 2005 11:10 PM
