Old Aug 30, 2012, 01:50 AM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
What range are you getting with your Immersionrc 600mW 5.8ghz tx?
I am curious what others are getting with the immersionrc 600mW 5.8 tx. If you have that tx and an OSD, I and others would love to hear the following:
Range:
Antennas used:
video quality:
RX used:
Video available:
here is my data,
range: 500M
antennas: stock dipoles
video quality: generally good but random noise and choppiness. Rapid loss of reception in about 100M span.
RX: UNO5800
video:
Super Sky Surfer FPV (27 min 2 sec)
compuatic is online now Find More Posts by compuatic
Old Aug 30, 2012, 05:32 AM
wayneuk's Avatar
Joined Apr 2012
your getting a better pic than i ever got with my dipoles !...change the antennas..what osd is that you have ?
range so far 2090m on my first outing with the duo5800 it stared to rain so turned back "plenty more "m" to go i think"
antennas x 2 home made 4 turn helical "ib crazy /jason temper "
duo5800 immersionrc
v q ..very good imo
immersion rc duo 5800 v2 diversity box fpv chair with two home made rhcp helical's hornet osd &gps (9 min 5 sec)
wayneuk is offline Find More Posts by wayneuk
Old Aug 30, 2012, 07:54 AM
Artic jetflyer
sap_2000's Avatar
Stabekk, Norway
Joined Sep 2004
I have been about 1000 meters out with my F450 Quad.
This is with the Duo5800 RX and 1 whip + 1 clover on the RX. Clover on TX (IBC)
With the FS Dominators and clovers, i get about 7-800 meters, but with far more noise.
Range: 700/1000+ meters
Antennas used: IBCrazy clovers
video quality: Fair. The duo has much less noise at hi range
RX used:FS Dominators/ IRC Duo5800
sap_2000 is offline Find More Posts by sap_2000
Old Aug 30, 2012, 02:54 PM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
wayne, i'm using the nova osd and a sony ccd HAD 600tvl camera. I would be curious to know how far you can go with the helicals. What range did you get on the dipoles?
sap_2000, seems like you should be getting more than 1000m, unless you didn't intentionally go further.
Old Aug 31, 2012, 03:11 PM
The Netherlands, ZH, Gouda
Joined Jun 2011
Hi,
Got 9.1 km (have flown 9 and 9.1 km on same day)
Due to lack of batt capacity must return before reaching the goal of 10 km.
On Tx IBC CL
5.8 Uno with homemade 14 turns Helical
plane Easystar
EZosd
EZuhf
EZ tracker
600TVL cam
Fatshark base
FPV Japan rec.
Environment .. sealevel flat area, rel. high humidity (Netherlands)
Video.. above 6km some noise, but at max range still good flyable picture.
jacq1954 is offline Find More Posts by jacq1954
Old Sep 16, 2012, 09:49 AM
"Watch this!.... Oh crap"
jhebbel's Avatar
United States, FL, Seminole
Joined Jan 2012
Wanted to jump in here and ask a general question and hope somebody can educate me a little bit. I fly FPV helicopters quite a bit from 200 - 600 size and have never really though much on this point, but the cameras i buy are usually 520-600 tvl and i use in conjunction with imersionrc 5.8ghz 600mw v2 tx and fatshark aviators and will soon also be using a 5800 diversity rx for my lcd screen i carry, But my question is if the camera is 600tvl will my picture on the lcd be 600tvl??? i know the fatsharks are only 480 so ill never see a difference there but will my lcd be more crisp of a picture??? the reason i ask is i never see a video recorded and uploaded with a resolution higher than 480, so whats the point of the extra $$$ ona 600 res camera????
jhebbel is offline Find More Posts by jhebbel
Old Sep 16, 2012, 10:58 AM
Edmonton, AB, Canada
Joined Oct 2002
So far, 1600m (1.6km) with a pair of SPW antennas. One on the plane, one on the Fatshark goggles (Dominators with integrated 5.8ghz receiver).
anixs is online now Find More Posts by anixs
Old Jan 25, 2014, 12:03 PM
Joined Jul 2013
Digging up an old threat as I am rather dissapointed with my results:
About 300 meters using the 5.8ghz 600mw immersion video transmitter and a fatshak rcv922 with integrated receiver. This is with cloverleaves, 3 leaves on TX, 4 on receiver.
As radio control I have 433mhz Openlrs with 1watt (400mwatt really).
As Anixs has has at least four times the range with the same kind of antenna's there is certainly something wrong.
I will do some further testing, if anyone got tips let me know.
ShiftyPK is online now Find More Posts by ShiftyPK
Old Jan 25, 2014, 02:19 PM
United States, NJ, Trenton
Joined Sep 2006
Range: 1.08 miles
Antennas used: Spironet
video quality: Good
RX used: Fatshark Predator 1 (with Aiwave receiver)
Video available:
1.08 Mile+ on DSMX and AR7010 FPV Quadcopter (2 min 56 sec)
I believe the tree's got in the way of my video link because I stayed at 400ft alt.
joop1987 is offline Find More Posts by joop1987
Old Jan 25, 2014, 02:39 PM
Joined Sep 2013
Upgrade to something with a Nexwave RX or comparable, makes all the difference.
crtek is offline Find More Posts by crtek
Old Jan 25, 2014, 02:45 PM
smoothvirus's Avatar
United States, VA, Franconia
Joined Sep 2010
5400 feet no problem
One mile FPV flight with Finwing Penguin (7 min 2 sec)
smoothvirus is online now Find More Posts by smoothvirus
Old Jan 25, 2014, 04:39 PM
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
I went out 5,5 km with IBcrazy clover leaf on plane and 5 turns helical on goggles. DOSD, dragon link UHF, Skywalker.
carguy1994ca is online now Find More Posts by carguy1994ca
Latest blog entry: DTF-UHF 200mm mini quad
Old Jan 26, 2014, 03:15 AM
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
Ive got viewable signal from a 600mw VTX to my Nexwave (Fatshark attitude stock VRX) with Spironet antenna from 4.5km, around 2.8 miles
ChrisJ800 is offline Find More Posts by ChrisJ800
Old Jan 26, 2014, 04:03 AM
Joined Oct 2013
2.2 miles with the spironet antenna's
sky surfer pro FPV 2.2 miles (11 min 31 sec)
lbcr1 is offline Find More Posts by lbcr1
Old Jan 27, 2014, 06:33 PM
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
I just bought the Boscam D58-4 5.8GHz 4CH diversity vRX and the 5.8GHz 32CH A/V 600mW Transmitter so I am hoping for a very solid reception up to 1 mile.
WBFlyer is offline Find More Posts by WBFlyer
Question ImmersionRC 5.8ghz 600Mw Tx gets warm omer921 FPV Talk 11 Jun 21, 2013 06:32 AM
Sold immersionRc 5.8Ghz 600mW and 5.8Ghz FatShark Module + CP Antenna's Jessestr FPV Equipment (FS/W) 1 Sep 04, 2012 05:04 PM
Sold Fat Shark Dominators with 5.8Ghz ImmersionRc 600mW + 5.8Ghz Rx FS Module and CP Ant. Jessestr FPV Equipment (FS/W) 8 Sep 02, 2012 12:35 AM
Sold Haier 7" LCD.....Fatshark 5.8ghz RX module.....Immersion RC 600mw 5.8ghz TX crd FPV Equipment (FS/W) 7 Jul 24, 2012 11:42 AM
Off Site ImmersionRC 5.8Ghz Audio/Video Transmitter - FatShark compatible (600mw) dssaction FPV Equipment (FS/W) 0 Jun 28, 2012 08:05 AM
