Old Feb 05, 2002, 02:22 AM
ultramega super star
stealthy's Avatar
Tucson,AZ 365 days of Sunshine
Joined Sep 2000
Rave
Lite Stick CG
I Lost my Lite Stock instructions(Buried under lots of Plane and foam parts) and need the CG location.
Jim
stealthy is offline Find More Posts by stealthy
Old Feb 05, 2002, 08:22 AM
HoleDigger
firstdegree's Avatar
Darwin
Joined Oct 2001
jim
I've got the instructions in .pdf format but can't remember where I got them now
anyway, the cg is 60mm back friom the wing leading edge - here's a lift from the instructions:
Balance Point (C.G.)
1. It is CRITICAL that the Lite Stik be balanced properly!
Please read this section carfully.
2. Slide the wings dowels into the wing mounts. The
dowels should fit quite tightly the first time you install
them. You may also have to move the mounts slightly to
perfectly align them with the wing dowels.
3. If you have not already done so, install the pro-peller,
the spinner, and the battery pack. There is NO
need to connect the battery or turn on the radio system.
4. On the bottom of the wing, make a mark 60 mm
back from the wing’s leading edge.
5. Pick up the plane with your finger tips on the
mark. The plane should rest level. If the tail dips, move
the wing back on the fuselage stick. If the nose dips,
move the wing forward on the fuselage stick. Do this
until the plane rests level.
6. Once the correct balance has been found, attach
the receiver mount with a small dab of glue.
hope that helps, email me if you want me to send the full .pdf file
firstdegree is offline Find More Posts by firstdegree
Old Feb 05, 2002, 11:52 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
http://www.parkfliers.net/manuals/litestik.pdf
Gene Bond is offline Find More Posts by Gene Bond
Old Feb 06, 2002, 12:26 AM
stealthy's Avatar
Joined Sep 2000
Thanks.
I saw a link to someones website for rigging with string to strengthen the wing up, does anyone know the link, if not , I'm sure it can't be to hard to figure out were to place the string.
Jim
sky scooter or lite stick DeaninMilwaukee Beginner Training Area (Aircraft-Electric) 9 Jul 05, 2001 03:00 PM
CG on Pico/Lite Stick??? deadcell Parkflyers 1 May 20, 2001 05:32 AM
Lite Stick its growing on me. Sparkie Electric Plane Talk 18 May 01, 2001 04:37 AM
What's better Regular Litestick of Full Fuse Lite Stick? mrebman Parkflyers 1 Apr 27, 2001 02:23 AM
2 channel lite stick? e-flyer Parkflyers 3 Apr 21, 2001 01:05 AM
