Old Aug 08, 2015, 02:39 AM
Ruebs is offline
Find More Posts by Ruebs
Joined Aug 2015
Help!
Fired my Transmitter module with a High gain Antenna. =/
I've recently gotten into FPV, but was having problems with the range for my RC TX.
The DX4 that came stock with my Blade 350QX3 (RTF) only gave me about 1Km which really isn't much since I've tested my 5.8ghz FPV gear to well over 3km (in my car).
I saw a thread on here - How to modify Spektrum TX with a booster- I followed the steps, but since I'm still waiting on my booster I decided to just try a higher gain antenna (5dbi).
On my second flight with the new antenna I noticed a burning metallic smell coming from my DX4, and now it's completely useless, with a maximum range of about 20 meters... lol
Could anyone tell me off the bat, what I might have done wrong? I used all the appropriate connectors, cables ect and made sure all connections were tight. I can't work out where I f##ked up...
Your help would be hugely appreciated.
Cheers
Ruebs
Ruebs is offline Find More Posts by Ruebs
Old Aug 08, 2015, 03:14 AM
aerocal is online now
Find More Posts by aerocal
Central California
Joined Dec 2006
You went wrong by making modifications to a system you do not understand.
Do not use a booster. What you are doing is outside the scope of unlicensed use. It is also not legal for good reason. There are likely unintended consequences for yourself and others around you by doing this.
aerocal is online now Find More Posts by aerocal
Old Aug 08, 2015, 03:45 AM
Ruebs is offline
Joined Aug 2015
Mate, I live in a VERY rural area of the Australian out back... To give you an example, my closest neighbor is 12.3Kms away as the crow flies... Trust me, I'm harming NO ONE.
I wish to use a longer range system to check on my live stock, fencing ect. I would use a UHF but my multirotor has an in-built 2.4ghz receiver.
I'm bored of all the self-righteous, brown nosing people associated with this hobby, with your copy and paste 'legality' reasoning.
I fly responsibly and I came here to simply ask for some advice. If you're not willing to help, please don't bother commenting.
If you feel the need to get your good Samaritan kicks, perhaps direct your scolding at people filming planes as they land on Youtube? Perhaps you could drive South and spew your crap at some gun wielding, drunk rednecks? You know, people that could actually do some damage.
Thanks for your ever-so considerate reply, but please refrain from doing so in the future.
Happy flying, and have a nice day =)
Old Aug 08, 2015, 11:11 AM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
Just a guess, but it might have been an impedance mis-match. Like sticking 2 ohm speakers on a 8 ohm amp. The driver circuit probably couldn't handle it.
Just a side note, it would have been helpful to know your usage before hand. I think it's a great use for a uav. I've seen shows about farmers using them for crop monitoring. Pretty cool stuff.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Aug 08, 2015, 11:33 AM
Warjet1950 is offline
Find More Posts by Warjet1950
RC Warjet
United States, CA, Jamul
Joined Mar 2013
Might have saved some butt-pucker if you had your location listed in your header, or at least mentioned it in your first post. Here in the states, we are having a BIG problem with morons flying FPV in urban areas, making headlines almost daily in the news.
Warjet1950 is offline Find More Posts by Warjet1950
Old Aug 08, 2015, 12:19 PM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Trying to "boost " and increase range is one of those things which seems straightforward --at first glance
One brand radio attempts this with the usual problems
You can increase range but essentially, ----the signal becomes narrower as range increases. you can easily loose the signal
the tx output is intended to provide a signal which works in a fairly large radius About the best you can do is use a rx setup which has no holes in it - (maximum diversity setup) Not a very scientific answer -but essentially -if you are using a RC tx /rx that's it - unless you are licensed to do your own radios.
richard hanson is offline Find More Posts by richard hanson
Old Aug 08, 2015, 01:22 PM
srnet is online now
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
If you want free advice perhaps your replies to people who respond should be more polite, even if you dont agree with them it does not warrent an offensive response.
Aerocal was correct, boosters of the type you are planning to use are illegal just about everywhere in the World, and its entirely appropriate that this is pointed out.
srnet is online now Find More Posts by srnet
Help! Cooked my Transmitter Module on my Spektrum with a higher gain Antenna... Ruebs FPV Talk 1 Aug 05, 2015 01:39 AM
Sold ImmersionRC EzUHF Transmitter 600mW w/ high-gain antenna endobiker FPV Equipment (FS/W) 4 Nov 02, 2014 05:24 PM
For Sale HJ 5.8G RC FPV High-gain Antenna Set/ L Shape Inner Needle Antenna davidwills Aircraft - Electric - Multirotor (FS/W) 4 Jul 04, 2014 07:49 AM
Discussion High gain antenna on the PLANE with a tracker pointing to the ground station szangvil FPV Talk 13 Nov 26, 2013 03:35 PM
Sold 5.8G RC305 Wireless AV Receiver & TS351 Transmitter with High Gain Antenna f traccer750 FPV Equipment (FS/W) 7 Jan 02, 2013 05:44 AM
