Old Aug 27, 2013, 12:40 PM
Portugal, Braga, Vila Nova de Famalic„o
Joined Oct 2009
Help with Griffon - handling problems
Hi
Recently finished building a griffon using mark porters plans.
I am strugling with the handling of the hovercraft. I cant seem to make it turn (180ļ), it just keeps widening the curve and sliding..
The skirt looks ok to me, is it weight diistribution? Maybe relocate the batteries a few inches to the back?
Thanks for your time
JS - Portugal
oacilamaf is offline Find More Posts by oacilamaf
Old Aug 27, 2013, 12:56 PM
Joined Aug 2007
improving the turning movement of model hovercraft
Hi, you will need to move the weight a bit more to the front to get better turning ... but not a few inches, moving the CG about half an inch might already be sufficient.
Check which part of your model lifts first: the rear end should lift a little earlier than the bow.
If your craft has difficulties turning at high speeds, that is quite normal. The bow wave (hump) moves to the stern and the back piece of the skirt sticks more to the water's surface than the bow does.
Send some photos!
mluthard is offline Find More Posts by mluthard
Old Aug 27, 2013, 01:02 PM
Joined Oct 2009
Move the weight to the front? I was thinking all wrong...
I will try that but i dont have much room to do that...
I believe the front lifts first but i will confirm that tomorrow and then post some pictures or a video.
Thanks for your help
Old Aug 28, 2013, 01:56 AM
MHA webmaster
United Kingdom, England, Reading
Joined Mar 2011
Experience with Griffons is that they will nearly always lift front first because of the weight of the duct assembly and relative position of the lift fan. You may find that your lift fan is generating too much torque which is counteracting the turn of the craft. This can be reduced by using a low pitch prop and a lower power motor - if your skirt is correctly set up you won't need much power to lift the craft. Another thing to look at is the thrust and rudder arrangement. Do you have 2 or 3 rudders? What prop and motor combination are you using? What size is it?
jpcwebb is offline Find More Posts by jpcwebb
Old Aug 28, 2013, 05:37 AM
Joined Oct 2009
Hi,
The motors are:
Lift: KV 1400 with 6x4 propeller - 3 blade
Thrust: KV1900 with 7x4 propeller - 3 blade - 3 rudders
I will try moving the weight a little forward and reduce the lift power and see if it works.
Any other suggestion?
I will add pictures in the afternoon
Old Aug 28, 2013, 06:32 AM
MHA webmaster
Joined Mar 2011
Hmm, I would say that your thrust is a little underpowered - most of the Griffons I have seen running successfully (mine included) have 8 or 9 inch props with higher kVs on 11.2v or higher. Also, the rudders need to be quite long and placed widely enough to generate good turning moment. Your lift setup sounds fine. How heavy is the model?
Old Aug 28, 2013, 01:18 PM
Joined Oct 2009
Its about 3800 grams
Today i noticed that i had only 50% of the travel in the rudders because i had the dual rate switch on (dumb). After turning it to 100% travel it improved but the batteries died before i could test it more in detail.
The rudders are about 5 cm wide and they go all the height of the propeller...
Old Aug 28, 2013, 02:19 PM
MHA webmaster
Joined Mar 2011
That would certainly account for some of your problem. 3.8Kg is a pretty good weight for a Griffon, but if you can reduce it in any way, that will also help. I replaced the side decks and cabin with Depron for instance and a few other mods which got it down to 2.5kg and that made a big difference in performance.
Old Aug 29, 2013, 01:17 PM
Joined Oct 2009
Actually its "only" 2974 grams.
Here are some pictures. (click to enlarge) What do you think about it?
Old Aug 29, 2013, 04:27 PM
MHA webmaster
Joined Mar 2011
Nicely built model and that is a good weight! It does look as though your rudders may be a little on the slim side though - I'd have probably made them at least 50% wider I think (based purely on the photos so I can't really judge properly) and this may account for some of your steering issues.
Old Aug 31, 2013, 04:56 AM
Joined Oct 2009
Gluing the hinges to the thurst structure was a nightmare...
If it comes to make changes, the rudders will be the last place i am going to make changes.
I havent tryed yet with the weight more balanced to the front and with the servo movement to 100%. I am confident that this will make a big difference but if it is still not enough i will first change the motor
Old Sep 07, 2013, 03:05 PM
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
tape some depron to the rudders as a test to see if they do need to be enlarged. that way you dont need to do any major reworking to see if it is needed.
derk is offline Find More Posts by derk
Old Sep 08, 2013, 01:54 AM
MHA webmaster
Joined Mar 2011
Agree this is a good approach for testing. Some folks use clear plastic to extend rudders to minimise spoiling the look (especially for scale craft). Can you not remove the rudder hinge pins? Or detach the rudders from the hinges themselves? Always a good idea to make rudders detachable as a rule in case of damage.
Old Sep 15, 2013, 02:02 PM
Joined Oct 2009
Hi again
Today i went to try it with the longer rudders as suggested but i blew the lift esc.
I usually use 11.1v 800mah lipos (from an Esky big Lama). Today i pluged a zippo Lipo with 11.1v 2200mah and 25c. Do you think it blew because of the battery or it was just a coincidence?
Can anyone suggest an esc good for the motor i mentioned and the zippo batery? A link from hobbyking or other online store would be nice... (dont want to spend more than 15 to 20 $ on the esc)
Old Sep 15, 2013, 02:15 PM
Joined Oct 2009
What do you think about this one? http://www.hobbyking.com/hobbyking/s...k_50a_esc.html
Help! X Quad with Motor4 problems. HELP! rubinstudios Multirotor Talk 2 Aug 11, 2013 05:35 AM
Help! problem with my hubsan X4 - Any help at all would be appreciated rctech96 Mini Multirotors 6 Feb 21, 2013 06:32 PM
Discussion I Need Help with a Mental Problem Chophop Life, The Universe, and Politics 51 Feb 20, 2013 05:07 PM
Need help with Brake on Castle Creations griffon 55 ESC!!! bwaltz Castle Creations 5 Apr 05, 2004 02:30 PM
Need help with Brake on Castle Creations griffon 55 ESC!!! bwaltz Power Systems 0 Apr 01, 2004 02:44 PM
