Old Dec 11, 2014, 08:02 AM
United States, MA, Boston
Joined May 2008
Brain FPV Flight Controller - Full Graphic OSD - Open Source - Made in USA - 36x36mm
The Brain is a next-generation flight controller that is specifically designed for first person view (FPV) flying and includes a full-graphic on-screen display (OSD). The Brain is small and light (36mm x 36mm, 8 grams), so it is ideally suited for FPV mini quads but it can fly anything, from mini quads to large octo-copters and fixed-wing planes.
The firmware running on the Brain is open source (GPL V3) and based on Tau Labs, which gives you many exciting features and also a great cross-platform (Linux, Windows, OS-X) ground control software to configure your flight controller using USB.
Importantly, open source firmware gives you complete freedom to do whatever you want with your flight controller; don't like the way the home direction is displayed in the OSD? Improve the code and contribute it back for everyone to benefit. Naturally, this does not mean you have to be a programmer or know programming to use the Brain, but you are free to modify the code if you want. It can be found on GitHub.
The Brain is made in the United States according to the highest industry quality standards.
FPV Specific Features:
  • Full-graphic OSD (360x266 for PAL):
  • Software adjustable black and white levels
  • PAL/NTSC autodetect
  • 4 fully user configurable OSD pages, selectable using switch on transmitter
  • Audio output (not yet supported by software)
  • 3 analog inputs for voltage, current, RSSI measurement
  • RSSI measurement using PWM, PPM, or analog input
Other Features:
  • CPU: STM32F405RG (32bit, 168MHz, 192kB RAM, 1MB Flash)
  • 64Mbit flash for settings, way points, logging
  • InvenSense MPU-9250 latest generation 3-axis gyro/accel/mag
  • Barometer: MeasSpec MS5611
  • Receiver compatibility: PWM, PPM, S.Bus, DSM2, DSMX, HoTT SUMD/SUMH
  • Up to 10 PWM outputs (up to 400Hz update rate)
  • Up to 3 serial ports for telemetry, GPS, RC receiver, etc.
  • External I2C port, can e.g. be used with an external HMC5883 compass
  • Micro USB port for configuration via PC
The Brain will be available soon! You can sign-up here to get notified or watch this thread for updates! Below is a video of a test flight on a tricopter.
EDIT: The Brain is now available. You can get it HERE
BrainFPV flight controller w/ Integrated OSD - Tricopter Test (2 min 54 sec)
HeliShredder is offline Find More Posts by HeliShredder
Old Dec 11, 2014, 12:17 PM
Kauai
Joined Jan 2011
Subscribed!
Kauaiguy is offline Find More Posts by Kauaiguy
Old Dec 11, 2014, 01:45 PM
United States, NJ, Colts Neck
Joined Jul 2014
Subscribed
PoohBear is online now Find More Posts by PoohBear
Old Dec 12, 2014, 07:36 AM
Portugal
Joined Nov 2009
Looking good. Plus for being an open-source OSD.
HF_ATL is offline Find More Posts by HF_ATL
Old Dec 12, 2014, 02:58 PM
Nobert's Avatar
Tucson Avra Valley, Arizona, United States
Joined Jul 2002
Subscribed
Nobert is offline Find More Posts by Nobert
Old Dec 16, 2014, 04:35 PM
San Antonio, Texas
Joined Sep 2003
Subscribed
ozzie111 is offline Find More Posts by ozzie111
Old Dec 17, 2014, 09:55 AM
Joined May 2008
Update: The Brain is now available, you can get it here: http://www.brainfpv.com/products/
Old Dec 17, 2014, 01:24 PM
Smasher of foam
FunkeyMonk's Avatar
United States, OH, Stow
Joined Sep 2012
I'm really looking forward to seeing some reports from people about this FC. I hope it's a solid open-source competitor to the Vector.
FunkeyMonk is offline Find More Posts by FunkeyMonk
Old Dec 19, 2014, 12:10 PM
Joined Sep 2014
subscribed
FireLikeIYa is offline Find More Posts by FireLikeIYa
Old Dec 19, 2014, 06:00 PM
United States, WA, Vancouver
Joined Jun 2013
subscribed
SirRexAlot is online now Find More Posts by SirRexAlot
Old Dec 19, 2014, 07:37 PM
Joined Jun 2006
good
titeuf007 is offline Find More Posts by titeuf007
Old Dec 19, 2014, 10:38 PM
foobly's Avatar
United States, TX
Joined May 2014
I'd be interested but does not seem available yet. Is there an estimated date?
foobly is offline Find More Posts by foobly
Old Dec 19, 2014, 10:48 PM
Joined May 2008
It has been on sale since a few days, you can get it here
Old Dec 19, 2014, 11:16 PM
foobly's Avatar
United States, TX
Joined May 2014
Ahh, thanks! I should have looked closer.
BTW, that hardware setup drawing is one of the best I've seen. Most products in this arena seem to come without directions or are written assuming the user has a phd in physics! Nice job.
Old Dec 20, 2014, 07:45 AM
Joined May 2008
Thanks for the compliment . IMO, providing good instructions on how to wire things up is key. It's not exactly difficult (at least from my perspective ), but it definitely helps new users to avoid common mistakes.
Discussion CL-OSD a open source osd software for E-OSD and G-OSD callelj FPV Equipment 4097 Feb 15, 2015 01:32 AM
Discussion Open Source Toriodal Core Winder for Open Source CDI Ignition 12F1840 Tee One Dee DIY Electronics 61 Nov 13, 2014 01:53 PM
Sold Open pilot CC3D w/Open source Brushless gimbal controller Kopterkat Aircraft - Electric - Multirotor (FS/W) 2 Jun 22, 2014 08:22 AM
Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video tom66 FPV Equipment 1928 May 24, 2014 12:07 PM
Discussion Open source OSD for FPV UFO_MAN FPV Talk 75 Sep 07, 2011 03:03 PM
