Old Jul 31, 2012, 09:33 PM
Joined Jul 2012
Settings for Naza GPS & Spektrum DX6i
I just installed the Naza GPS in my Quad. I am using a Spektrum DX6i and need help! I want to use the gear and flap switches to switch between Attitude, Manual, GPS Hold and GPS Home. I know that I need to "mix" channels to accomplish this but DO NOT have a clue on how to proceed. I have no problem configuring the gear switch by itself...the rest well I'm lost??? Help would be appreciated. I'm sure SOMEONE has the same setup?
Best Brewer is offline Find More Posts by Best Brewer
Old Aug 08, 2012, 11:40 PM
wrcfan21's Avatar
New Zealand
Joined Nov 2006
Hi try this, the guy has a NAZA GPS and DX6i
RTH Feature on DX6i (6 min 6 sec)
wrcfan21 is offline Find More Posts by wrcfan21
Old Aug 13, 2012, 12:47 PM
Joined Jul 2012
Mix Settings Unknown
This is a good example of the RTH function using the GPS on the DJI Naza, however the settings on the Spektrum DX6i are not known? What are mix settings?
Old Aug 13, 2012, 12:52 PM
United States, FL, Tampa
Joined Apr 2012
I don't know if you'll be able to get all of that. I'm using a DX6i and currently use my gear switch to activate GPS, my elev switch to switch between manual and atti, and my flap switch to do home lock. Failsafe, which is supported by my receiver, is activated if I turn off my DX6i.
Mix1:
Gear-> Gear Act
Rate D - 93% U 0%
SW ELE D/R TRIM ACT
dedfish is offline Find More Posts by dedfish
Old Sep 06, 2012, 09:22 AM
Joined Jul 2012
I was able to get it on my own...here it is
Spektrum DX6i Settings for DJI Naza w/GPS
Travel Adj
Thro - 100% Aile – 100%
Elev – 100% Rudd – 100%
Gear – 40% (SW =0) Flap – 100%
Gear – 80% (SW=1)
Flaps
Norm – 100%
Land – 100%
Mix 1
Flap -> Gear Act
Rate D+ 100% U – 0%
SW – On Trim INH
Gear Flap Mode
0 0 Manual
1 0 Attitude
1 1 GPS Hold
0 1 GPS Home
Old Oct 25, 2012, 12:43 PM
Joined Aug 2012
Goodbye Hair
I've gotta say, I'm about to pull my hair out trying to get that setup on my dx6i.. I don't see how you are instructing it to use the elev d/r switch for anything. I'm about to sell this Naza I believe.
jerbs is offline Find More Posts by jerbs
Old Oct 25, 2012, 01:31 PM
DesJardins's Avatar
United States, AZ
Joined Oct 2012
Selling the Naza doesn't solve your concern... You'll need to assign the switch that you want to use first.
I'll see if I can grab screen shots of the DX6i that was just set-up for you and see if they help.
I have already asked for those screen shots
DesJardins is offline Find More Posts by DesJardins
Old Oct 25, 2012, 08:19 PM
Joined Jul 2012
Gear & Flap Switch
No, this uses the gear switch & the flap switch
Old Oct 26, 2012, 11:20 PM
MidwestRob's Avatar
United States, KS, Gardner
Joined Sep 2011
Travel Adj
Gear – 80% (SW=1)
Flaps
Norm – 100%
Land – 100%
Mix 1
Flap -> Gear Act
Rate D+ 100% U – 0%
SW – On Trim INH
Gear Flap Mode
0 0 Manual
1 0 Attitude
1 1 GPS Hold
0 1 GPS Home
Hey Brewer, are you able to get your Naza+GPS to enter failsafe when you lose Tx signal? I'm helping a friend set up his Naza with a DX6I Tx and a AR6115E Rx. We are able to set the main control channels to the appropriate settings for failsafe, but can't get the gear switch to change to failsafe on the assistant software when the Tx is turned off. It will stay in the last mode position it was on when the Tx is turned off. Does the AR6115E Rx only save the 4 control-surface channel settings on a loss of signal failsafe?
MidwestRob is offline Find More Posts by MidwestRob
Old Oct 27, 2012, 08:52 AM
DesJardins's Avatar
United States, AZ
Joined Oct 2012
I can help with that Rob, driving right now though.
I'll pull the arm flyer Rx binding
Old Oct 27, 2012, 08:57 AM
DesJardins's Avatar
United States, AZ
Joined Oct 2012
I just looked and the only thing you can try is when you put the bind plug-in and it starts the Rx for the bind process try pulling the bind plug out before you turn your transmitter on to actually bind.
Then try turning the Tx turn off while plugged into the assistant to see if it registered the forced failsafe and minimum 10% throttle
Old Oct 27, 2012, 09:09 AM
kauaicuda's Avatar
United States, MD, Frederick
Joined Aug 2010
That Rx is no good for Naza failsafe.
kauaicuda is offline Find More Posts by kauaicuda
Latest blog entry: CC3D housing with Lexan lid
Old Oct 27, 2012, 09:18 AM
DesJardins's Avatar
United States, AZ
Joined Oct 2012
It looks like the failsafe just remember the binded throttle position which for Naza is anything over 10%
As long as it's binded with the gear channel set to the forced failsafe and 10% throttle which might have to be achieved with throttle end points for just the initial bind it might work. (Don't forget to change the throttle end point back)
Try what I posted above and let us know if that works
Old Oct 27, 2012, 11:15 AM
Fly High - Lake Tahoe
Las Vegas/Lake Tahoe
Joined Feb 2010
Spend the extra $10 and get an AR7010 with preset fail-safe.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Old Oct 27, 2012, 11:23 AM
DesJardins's Avatar
United States, AZ
Joined Oct 2012
True, that's what I had...
But if he already has the park flyer Rx :shrug:
Discussion Help With Turnigy Setting for Dji Naza GPS r2pardjo Multirotor Electronics 9 Apr 13, 2013 01:39 AM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 08:47 PM
Discussion Spektrum DX6I Transmitter Settings Preston019 Beginner Training Area (Heli-Electric) 17 Jul 11, 2012 02:39 PM
Discussion setting up GPS upgrade for naza ff954 Multirotor Talk 5 Jun 18, 2012 07:19 PM
Discussion SET: Spektrum DX6i, AR6210 + 2x AR6115e nr1 Radios 1 Jun 15, 2012 09:59 AM
