View Poll Results: Which programmers are you using
AVRisp mkII 14 23.73%
usbasp 34 57.63%
mySmartUSB light 4 6.78%
USBtiny 8 13.56%
other 2 3.39%
Multiple Choice Poll. Voters: 59. You may not vote on this poll
Old Aug 09, 2015, 04:54 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Looks like your firewall is blocking the flashtool or java to access the internet.
Best christian
LazyZero is offline Find More Posts by LazyZero
Old Aug 09, 2015, 07:03 AM
mifmof is offline
Find More Posts by mifmof
Joined May 2015
Ii have turn my firewall off how do I set Java to go on the internet thanks
mifmof is offline Find More Posts by mifmof
Old Aug 21, 2015, 05:39 PM
joeypurple7 is offline
Find More Posts by joeypurple7
Joined Feb 2015
I saw someone else had this problem, but other problems had overridden the first problem. When I try to flash the latest firmware onto my kk2.1.5, I get the error message : could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
I've used both the normal and beta version of the flashing software. Any idea what's wrong?
I suspect it's the driver for my usbasp
UPDATE: I fixed it; Windows was telling me it wouldn't use the driver because its signature was untrustworthy. I restarted my computer, and while it was booting, I repeatedly pressed f8 to bring to a start up menu where I disabled the valid signature requirement. It then let me use the driver, but was still giving me the error message.
In the tool menu where I selected my device, I used USBasp clone instead of the normal one, and that seemed to be the key to success!
joeypurple7 is offline Find More Posts by joeypurple7
Old Aug 22, 2015, 05:36 PM
guytranspo is online now
Find More Posts by guytranspo
United States, CA, Santa Clarita
Joined Jan 2014
Can't flash KK mini.
I've been trying to flash my mini with Open Aero. Using Lazy Zero tool, but I keep getting error messages. I've attached a screen shot of the error.
Can anyone help.
Thank you
guytranspo is online now Find More Posts by guytranspo
Old Aug 22, 2015, 05:37 PM
Joined Jan 2014
kk mini help
I should add that the board power up and shows safe mode when it is attached to the laptop. I'm using a mac.
Old Aug 30, 2015, 04:04 AM
LazyZero is offline
Master of Flash
LazyZero's Avatar
Joined Jun 2005
Hi,
sorry for the late reply, but I am a bit offline (vacations)
If it powers well, check if the other four lines are well too.
Christian
Old Sep 08, 2015, 12:46 AM
Thoemse is offline
Find More Posts by Thoemse
Austria, Vorarlberg, Dornbirn
Joined Aug 2015
Is anyone familiar with this error:
Flash the firmware file.
Flashing firmware from file.: C:\Users\Thomas\Desktop\KK 2.1.5 Flashtool\rc911 f\kk2++.hex
C:\Users\Thomas\Desktop\KK 2.1.5 Flashtool\lib\avrdude\windows\avrdude.exe -C C:\Users\Thomas\Desktop\KK 2.1.5 Flashtool\lib\avrdude\windows\avrdude.conf -p m644p -P usb -c usbasp-clone -e -U flash:w:C:\Users\Thomas\Desktop\KK 2.1.5 Flashtool\rc911 f\kk2++.hex:i
avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update.
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude.exe: Device signature = 0x1e9609
avrdude.exe: Expected signature for ATmega644P is 1E 96 0A
Double check chip, or use -F to override this check.
avrdude.exe done. Thank you.
Error during writing flash.
I am using an rcx usbasp flasher i bought at myrcdrones. I try to flash a kk 2.1.5 with the latest RC911 firmware.
I installed the driver (disabled win 10 driver signaturing) and it shows the usb device as working.
I tried a differned usblib32 driver too but no success.
After that i tried on two different computers. Allways the same error. One PC was a trusted old Win XP setup.
It should be plugged in correctly because the FC powers on.
Am i doing something wrong?
Could it be that they used an A Chip instead of a PA on my KK board?
It runs Steveis latest FW so it is not all that bad but i'd rather flash RC911's for mixed mode.
Thoemse is offline Find More Posts by Thoemse
Old Sep 08, 2015, 01:00 AM
Steveis is online now
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
@Thoemse looks like you are trying to flash the kk2 version of RC911's code. You need the AIO version for the kk2.1
Steveis is online now Find More Posts by Steveis
Old Sep 08, 2015, 01:14 AM
Thoemse is offline
Joined Aug 2015
Thanks for your reply!
I got the 2.1 version though. I also tried flashing versions of your firmware. I get this message no matter what i try to flash.
Edit: The USBasp device has a red led active when i plug it into the USB port. The KK 2.1.5 boots so i guess there should be enough juice right?
Old Sep 13, 2015, 03:49 PM
Thoemse is offline
Joined Aug 2015
Thanks to rc911 i am getting closer to the cause of my problem: He showed me how the chip should look like. It seems like they started using different chips on the kk 2.1.5:
Do you think i should force flash or will i brick my fc?
Anyone else has an A chip instead of PA?
Old Sep 14, 2015, 04:54 AM
LazyZero is offline
Master of Flash
LazyZero's Avatar
Joined Jun 2005
Hi can you please test with the following command:
C:\Users\Thomas\Desktop\KK 2.1.5 Flashtool\lib\avrdude\windows\avrdude.exe -C C:\Users\Thomas\Desktop\KK 2.1.5 Flashtool\lib\avrdude\windows\avrdude.conf -p m644 -P usb -c usbasp-clone -e -U flash:w:C:\Users\Thomas\Desktop\KK 2.1.5 Flashtool\rc911 f\kk2++.hex:i
if it is working then?
Best Christian
Old Sep 14, 2015, 03:08 PM
Thoemse is offline
Joined Aug 2015
Best Christian
Sadly not. I get this error:
Microsoft Windows [Version 10.0.10240]
(c) 2015 Microsoft Corporation. Alle Rechte vorbehalten.
C:\Users\Thomas>C:\Users\Thomas\Desktop\Flashtool\ lib\avrdude\windows\avrdude.ex
e -C C:\Users\Thomas\Desktop\Flashtool\lib\avrdude\wind ows\avrdude.conf -p m644
-P usb -c usbasp-clone -e -U flash:w:C:\Users\Thomas\Desktop\Flashtool\rc911 f\k
k2++.hex:i
avrdude.exe: invalid file format '\Users\Thomas\Desktop\Flashtool\rc911' in upda
te specifier
avrdude.exe: error parsing update operation 'flash:w:C:\Users\Thomas\Desktop\Fla
shtool\rc911'
C:\Users\Thomas>
Old Sep 18, 2015, 11:25 AM
Thoemse is offline
Joined Aug 2015
Did i do it wrong? I entered it in the command terminal. I vhanged folder because it originally said there is no KK (had issues with dolder name qith spaces).
Old Mar 21, 2016, 12:54 PM
mediumendian is offline
Find More Posts by mediumendian
Joined Mar 2016
Hello,
I cannot get the flashtool to actually flash
avrdude fails with following text:
Flash the firmware from repository.
Flashing firmware from file.: /home/ra/kkflash/tmp/OpenAero2_B10_KK21.hex
/home/ra/kkflash/lib/avrdude/linux64/avrdude -C /home/ra/kkflash/lib/avrdude/linux64/avrdude.conf -p m644p -P usb -c avrispmkII -vvvvv -e -U flash:w:/home/ra/kkflash/tmp/OpenAero2_B10_KK21.hex:i
avrdude: Version 6.0.1, compiled on Jan 12 2014 at 12:51:49
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/home/ra/kkflash/lib/avrdude/linux64/avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : avrispmkII
avrdude: usbdev_open(): cannot open device: Input/output error
avrdude: usbdev_open(): did not find any USB device "usb"
The settings in the tool(programmer, controller and firmware) are correct and compatible as far as I understand it. I have messed around with udev rules and groups, but didn't manage to get it working. I would be very thankful if someone here could point me in the right direction.
mediumendian is offline Find More Posts by mediumendian
Old May 21, 2016, 09:08 PM
chung1608 is offline
Find More Posts by chung1608
Joined May 2016
I want increase max speed, who know how can I edit what variable to increase speed
chung1608 is offline Find More Posts by chung1608
