Old Sep 08, 2014, 02:41 PM
Joined Apr 2005
AXN Cloud Fly CG - setup to glide?
Hey guys I picked up an AXN. Problem is, it's nose diving on the toss, bad. It flys fine once I get it airborne but I'm having to javeline toss it and even then it swoops to almost the ground before it sails off. I've tried various throttle settings (1/4, 1/2) due to the high mounted motor with the same result.
I found this video showing the proper toss, but with his, it glides forever with a power off toss.
How to launch the AXN Clouds Fly Floater Jet RC plane (1 min 46 sec)
If I did that toss it'd go about 10 feet and nose into the ground. Should I set mine up like that? That would require a pretty big adjustment from the recommended 51.5mm CG location. Per this wiki:
http://beta.ivc.no/wiki/index.php/AXN_Clouds_Fly_Setup
I'm not really worried about a minimal loss of performance, I just don't wanna keep tossing it into the dirt.
To make it more tail heavy I need to move CG forward right?
Thanks!
xray328 is offline Find More Posts by xray328
Old Sep 10, 2014, 05:03 AM
The original Flybaby
flybaby747's Avatar
Joined Mar 2004
what battery are you using , i have modified the internals to take a 2200 mah 3s , and it balances perfectly and glides great .. I also followed the wiki when i got mine and its had more flights than any other plane...
Great for fpv too
flybaby747 is offline Find More Posts by flybaby747
Old Sep 10, 2014, 08:12 PM
United States, NJ, Frenchtown
Joined Mar 2003
I always take the plane to a tall weeded field. SOFT weeds. Always for a first flight.
COG might be perfect. But the angle of wing & tail incidences could be way off.
Did that more than 1 time with ARFs.
WE ARE the final aircraft designers of each plane we buy.
cyclops2 is offline Find More Posts by cyclops2
Sold Canopy For AXN Floater Jet Clouds Fly Remote control Airplane dereelmatts Aircraft - Electric - Airplanes (FS/W) 0 Jul 16, 2014 02:26 PM
Discussion Hand Launch AXN Clouds Fly bachynski Beginner Training Area (Aircraft-Electric) 12 Jul 09, 2014 12:48 AM
Video Modified AXN Floater-Jet (aka Cloud Fly) for slope flying Nimbus Dave Foamies (Kits) 0 Feb 15, 2014 06:21 AM
Discussion flysky fs-r6b/a problem with esc and axn clouds fly glider cukovanny Power Systems 2 Jan 24, 2014 12:39 AM
Help! AXN Clouds Fly Aoxan ae-25a esc servo wires soldering Jyffe76 Power Systems 0 Dec 15, 2013 03:46 AM
