Old Aug 14, 2015, 05:53 AM
egall232 is offline
Find More Posts by egall232
England/uk
Joined Oct 2007
Originally Posted by SteveR View Post
Thanks Euan, very neat. Do you recall your CG location?
Also, when you installed your carbon tube reinforcements, did you glue them against the spars? Did you install both a top and bottom carbon tube on each inner wing?
Regards,
Steve
Steve,
I will check the cof g for you, the spars are 12mm x 3 mm Cyparis top and bottom front and rear glued to the existing spars .3 mm lite ply is used as full depth shear webbing with around half a litre of aliphatic glue per panel to hold it all together ?
The wing was simply slotted for the new spars with a razor saw and only took around two hours per panel, I have modified both the original panels and the so called factory modified panels and have had no reported failures,
cheers Euan.
egall232 is offline Find More Posts by egall232
Old Aug 14, 2015, 11:20 AM
Charlescd is offline
Find More Posts by Charlescd
Quebec Aerotow Association
Charlescd's Avatar
Canada, QC, st-jean-sur-richelieu
Joined May 2010
Last time I checked, Hobby Club had them in stock.
Charlescd is offline Find More Posts by Charlescd
Old Aug 14, 2015, 12:29 PM
pmccleave is online now
Find More Posts by pmccleave
USA, KS, Wichita
Joined Sep 2002
I just looked on the Hobby Club site and do see they sell the 6M version but did show the small one. Do you happen to have a link to where they show them in stock?
Pat
pmccleave is online now Find More Posts by pmccleave
Old Aug 14, 2015, 05:26 PM
Charlescd's Avatar
Joined May 2010
Hi,
You're right, it is no longer there.
Call Alberto directly: (949) 425-1362 . I'm sure he can still get them.
Phoenix also has an online store.
http://zigirc.com/gl04-k8b-6000-3#pa...ulldescription
Alert Phoenix 6 Meter K8 One Time Special Order SteveR Scale Sailplanes 393 Jul 19, 2012 07:40 PM
Discussion PHOENIX Evolution 2.6 dougind Electric Sailplanes 1 Jun 16, 2012 08:40 AM
For Sale Hitech Eclipse tranmitter and 8 Receivers on 6 meters for sale or trade. model medic Aircraft - General - Radio Equipment (FS/W) 0 Apr 02, 2012 08:06 AM
Alert Last Call for the Phoenix 6 Meter K8 Sailplane SteveR Scale Sailplanes 5 Nov 22, 2011 06:24 AM
