Old Jan 31, 2013, 06:00 AM
United States, WI, Slinger
Joined Mar 2006
Originally Posted by Rodney View Post
Weidmark, your computer power supply is capable of the 15 amperes but, it may require that you put a load on the 5 volt buss as well in order to get the 15 amperes on the 12 volt buss. Most computer supplies (at least the older ones) get their regulation off the 5 volt buss and, it it is not loaded, will not provide full output on the other buss's. If you can not get the high output off the 12 volt buss, just put a 5 ohm 10watt or higher resistor on the 5 volt buss and see if that lets you draw more current off the 12 volt buss
You need to check the spec sheet for the PSU. Some older ones required a 50% load on the +5, many newer ones only require an amp or two.
MikeCr is offline Find More Posts by MikeCr
Old Jan 31, 2013, 06:35 AM
That's a funny word
NE Ohio
Joined Apr 2003
Many of the higher power chargers will run from 11 volts or so. As for your existing problem , it cannot be the ps.
gulio is offline Find More Posts by gulio
Old Jan 31, 2013, 12:02 PM
So. Cal.
Originally Posted by weidmark View Post
I believe the charger I received was faulty. With this charger, when I start it up, it will give me the current voltage of the battery that is being charged, then it will immediately change to 8.4V and begin charging the pack. It charges a 2S pack to 8.25V
I just charged a battery and this is what I got. 2S 5300mAh Gens Ace.
Started at 6.9V and initially was charging at 3.2A
After 10 minutes charging at 2.2A
After 30 minutes charging at 1.9A
After 60 minutes charging at 1.7A
After 90 minutes charging at 1.5A
After 135 minutes charging at 1.1A
After 170 minutes charging at 0.6A
This was using the computer PS
Charge finished at 212minutes and put 4722mAh into the pack.
What is the output voltage as reported by the charger when it begins tapering current? If it shows cell count x 4.2 volts, you then have a high impedance somewhere in the output chain. This could be within the charger, the charge lead or connections, or the battery itself. You'll have to rotate parts to further isolate, ensuring that you only change one variable at a time so you can isolate the culprit.
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Jan 31, 2013, 04:35 PM
Joined Jan 2012
I think the charger is the problem. I will test charging vs another accucel 6 later tonight.
I think I am going to pick up an icharger 106b. I would like more reliability when im charging and 10A should be plenty for me.
weidmark is offline Find More Posts by weidmark
Old Jan 31, 2013, 05:03 PM
So. Cal.
Very wise decision. In my experience, there is no better charger in the sub-$100 range.
Mark
Old Feb 01, 2013, 10:13 AM
Joined Jan 2012
So I got my friend's accucel 6.
with a gens ace at 7.80V i started charging with mine, and it was charging at 1.3A. I swapped his in and I still got 1.3A. I swapped power supplies, and banana cables and i always got 1.3A.
So i really do not know what the problem is. My concern now is if I get the icharger, will I be limited to this low charged rate still? Considering the accucel should be able to charge faster and I am getting the same result on two of them.
Old Feb 01, 2013, 10:18 AM
So. Cal.
What was the voltage readout on the screen after you started the charge and the current rose to 1.3A?
Old Feb 01, 2013, 10:51 AM
Joined Jan 2012
On both chargers it reads 8.4v
Old Feb 01, 2013, 11:01 AM
So. Cal.
...and there's your answer.
Your charger is immediately entering CV mode due to high impedance in the charger output chain. You either have a bad charge lead or a bad battery, plain and simple.
If it's voltage drop in the charge lead, an iCharger will indeed charge faster as they compensate for charge lead voltage drop. However, the fact that you have .6V drop at 1.3 amps points to a rather significant issue with your battery or your charge lead.
Mark
Old Feb 01, 2013, 03:35 PM
Joined Jan 2012
Mark
Oh I see!
I just found some 10AWG wire in the garage and soldered it to some banana plugs and voila. Now I am getting 5.3A charge rate.
Thank you all for the help.
Old Feb 01, 2013, 04:27 PM
So. Cal.
Yay!
Mark
Old Feb 01, 2013, 04:40 PM
Joined Jan 2012
Yea. The only thing I dont understand is why the thin yellow 12v wire in the PSU is fine, but the thin charge leads cause problems.
I think ill still get an icharger, although ill probably wire 3 or 4 of the yellow wires in the PSU for this.
Old Feb 01, 2013, 04:54 PM
That's a funny word
NE Ohio
Joined Apr 2003
Your input may handle a 2 volt drop without any consequence , but with a cv limit of 8.4 volts ANY drop shows up as a current drop (hitting the cv early) 16 gage wire should be adequate. Sounds like your good to go anyways.
Old Feb 01, 2013, 05:23 PM
So. Cal.
One of the nice features about higher quality chargers (FMA, iCharger) is that they will compensate for charge lead voltage drop when balance charging. This allows them to stay in CC mode for a much longer time than lesser chargers and thus have shorter charge times, even when charging at the same current.
One of the many reasons why recommend nothing less than the 106B+.
Mark
Old Feb 01, 2013, 06:07 PM
Joined Jan 2012
Mark
Good to know. Looks like that will definitely be my next purchase. Are the the ones sold at hobby king authentic? Or am I better of getting one from progressiverc
Discussion 1 cell in a 5s Charges too fast!! tlh101 Batteries and Chargers 8 Jan 20, 2013 05:08 PM
Discussion Dual Miracle Fuel Dot/Charging Ports too big for a .60? xray328 Fuel Warbirds 3 Jan 12, 2013 08:04 AM
Discussion Dual Rates - How To Establish Airplane High & Low Rates? itsme2 Electric Plane Talk 7 Jan 06, 2013 09:52 AM
Question parkzone lipo max charge rate? duker733 Batteries and Chargers 14 Jan 05, 2013 03:01 PM
Discussion LIPO PROBLEM: Discharge Rate seems too low??? rapscallion Batteries and Chargers 3 Aug 03, 2006 10:31 AM
