Old Nov 26, 2013, 04:35 AM
Joined May 2013
Version 2.4 Telemetry Reader App
Version 2.4 available
see information here:-
http://www.helifreak.com/showthread.php?t=534058&page=2
Kevin
kevinww is offline Find More Posts by kevinww
Old Dec 02, 2013, 06:59 PM
Joined May 2013
Version 2.5 Telemetry Reader App
Version 2.5 available
Kevin
Old Dec 24, 2013, 08:09 AM
Joined May 2013
Version 2.6 Telemetry Reader App
Version 2.6 available
http://www.helifreak.com/showthread....52#post5515952
Kevin
Old Dec 24, 2013, 09:08 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
That's a nice update. Adding the flight time to the Model and Session drop-down is a real bonus.
davidmc36 is offline Find More Posts by davidmc36
Old Dec 24, 2013, 09:52 AM
Joined May 2013
You requested it and it was a minor change so no problem.
Old Jan 18, 2014, 10:06 PM
AMA member since May 2013
Supreme Balloon's Avatar
United States, CA, Petaluma
Joined May 2013
Hello,
I downloaded and installed v 2.16 of your telemetry reader. I'm getting a dump when trying to view the data. The program loads and executes fine, but when I select my model, it disappears.
I have a DX9/AR8000 but don't have any other telem modules, I was hoping to see if the TX/RX delivered any frame data and am thinking of getting a TM1K and the GPS for my multirotor.
Here is the error log:
Code:
Config file not found, using default values.
java.lang.NullPointerException
	at com.kw.telemetry.app.TelemetryAppWindow$2.widgetSelected(TelemetryAppWindow.java:350)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
	at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
	at com.kw.telemetry.app.TelemetryAppWindow.open(TelemetryAppWindow.java:122)
	at com.kw.telemetry.app.TelemetryAppWindow$1.run(TelemetryAppWindow.java:98)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
	at com.kw.telemetry.app.TelemetryAppWindow.main(TelemetryAppWindow.java:94)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
	at com.exe4j.runtime.WinLauncher.main(Unknown Source)
This is a HP Pavilion dv6 running WIN7. It is an OK machine, does video rendering pretty well.
Thanks very much for your work, it appears to be quite useful!
John
Supreme Balloon is offline Find More Posts by Supreme Balloon
Latest blog entry: Herd the Birds
Old Jan 18, 2014, 10:34 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
If you don't have a TM1000 you will not get any telemetry data. The Rx does not do it on it's own.
Old Jan 19, 2014, 03:35 PM
Joined May 2013
You have model data but no telemetry data to link to the model data as you dont have a TM module to send any data, hence the error. This case could be handled better by the app and has already been reported and will be looked at in the next version.
Old Feb 18, 2014, 03:08 AM
Joined May 2013
Version 2.7 Telemetry Reader App
Version 2.7 available
Major highlights, First release of MAC version.
http://www.helifreak.com/showthread.php?t=534058&page=3
Post #44
Kevin
Old Mar 30, 2014, 01:46 PM
Joined May 2013
Version 3.0 Telemetry Reader App
Version 3.0 available
Major highlights, Vario Support and Custom Graphs.
http://www.helifreak.com/showpost.ph...2&postcount=54
Kevin
Old Apr 16, 2014, 04:36 PM
seattlebuoy's Avatar
United States, AZ, Flagstaff
Joined Sep 2011
Very nice utility. Thanks so much for sharing.
seattlebuoy is offline Find More Posts by seattlebuoy
Old Apr 26, 2014, 02:53 AM
Joined May 2013
Version 3.1 Telemetry Reader available
Minor update available, see info here :-
http://www.helifreak.com/showpost.ph...5&postcount=67
Old Apr 26, 2014, 08:31 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
You'll need to do more updates with the latest 18 codebase changes.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Discussion Format of DJI Wookong Ground Station log files ? sPiKes777 Multirotor Electronics 28 Aug 23, 2014 08:08 AM
Sold NEW Spektrum DX8 Transmitter DSMX W/charger and sd card HD Hucker Aircraft - General - Radio Equipment (FS/W) 0 Aug 28, 2012 01:59 PM
Sold NEW Spektrum DX8 Transmitter DSMX W/charger and sd card HD Hucker Aircraft - General - Radio Equipment (FS/W) 3 Aug 27, 2012 07:55 PM
Sold Spektrum DX8 Transmitter w/Charger and SD Card! NEW HD Hucker Aircraft - General - Radio Equipment (FS/W) 2 Aug 24, 2012 12:28 PM
Discussion DX7s (perhaps DX8) SD card storage format editor? A Useless Geek Radios 54 Jan 03, 2012 12:27 AM
