Old Dec 28, 2014, 10:56 AM
sdad is offline
Find More Posts by sdad
United States, MI, Grand Ledge
Joined Jan 2013
Balsa spar configuration
For sake of arguement lets assume that I'm going to put a full span spar into a foam wing. I slice the wing in two along the 25% line say, so that I now have two pieces, the leading edge and the trailing edge. The kerf on the saw blade for this cut relieved 1/8" from the foam. I then notch the foam at the cut to fit in a 1/4" square strip top and bottom of both the front and rear foam. This series of cuts gives me the volume occupied by an "I" beam spar which I will glue the foam onto recreating the original airfoil with the spar in place. The main portion of the spar is cut from 1/8" balsa. Here's my question: do I want the grain going up and down just like in stress webbing, or do I run spanwise? I'm leaning toward the spanwise config, but not sure. Any thoughts?
Opps! Forgot to add this in. The wing will be 1/16" balsa sheeted. The spar will be glued to the sheeting as well as the foam.
sdad is offline Find More Posts by sdad
Old Dec 28, 2014, 11:36 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Vertical grain.. Always. If going horizontal grain then fitting caps to it is close to being redundant.
Only purpose of a web in an I beam is to ensure the stringers do not buckle.
Bare is offline Find More Posts by Bare
Old Dec 28, 2014, 11:40 AM
sdad is offline
Joined Jan 2013
Gotcha!
Old Dec 28, 2014, 01:00 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Span wise.
And use 1/4" balsa
eflightray is online now Find More Posts by eflightray
Old Dec 28, 2014, 01:24 PM
packardpursuit is offline
Find More Posts by packardpursuit
Joined Jan 2009
I'm going to suggest that "sometimes vertical" may be appropriate. Only you the designer builder can say what you are trying to accomplish.
In your stated case I would bet that running the web grain spanwise is more than adequate for all practical purposes. And within that general configuration there is no obvious benefit for one practice over the other. Sometimes we tend to think we "must" be/do things a certain way, when they are are not, in reality, required.
I've repaired and flown a number of full size aircraft with I beam spars. Most seen are routed timbers with the web grain having to run spanwise. Ply webbed box and I beam spars are, as a general rule, stiffer than their timber counterparts . And yet, some of those have their ply faces aligned vertically, while others have them span wise.
In general, the purpose of the web is two fold. First and formost is to keep the upper and lower flanges of the I beam from moving past one another, span wise. The second is to keep the two flanges from deforming in their relation to each other. In most typical wing situations the upper flange wants to bend inward, toward the lower flange, while carrying flight loads. The web only needs be strong enough to resist crushing. So, 1/32" sheet web, with vertical grain orientation, may be quite adequate for your needs, yet the practicalities/ease of construction might warrant thicker material and or an alternate grain orientation.
All in all, general principles and practices of engineering are a good thing good to keep in mind, but they are not all encompassing rules. Quite often practical considerations out weigh rote thinking.
packardpursuit is offline Find More Posts by packardpursuit
Old Dec 28, 2014, 07:12 PM
LVsoaring is offline
Find More Posts by LVsoaring
Unrepentant Paragon addict
LVsoaring's Avatar
United States, OK, Moore
Joined Jan 2006
In a sheeted foam core wing, a significant portion of the structural strength comes from the sheeting, assuming it is properly, and evenly adhered to the foam substrate. So, in this case, spanwise spar webs should be adequate.
As a comparison, in a woodie sailplane wing with typical spar construction of uppern and lower caps, and a web inbetween them, vertical grain is essential in order to provide the strength needed.
LVsoaring is offline Find More Posts by LVsoaring
Old Dec 29, 2014, 10:18 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
The "in flight" stress in a spar web is always 45 degrees to the vertical or horizontal axis. As a result, it makes no difference if you are worried about flight stress. However, vertical webbing is more immune to hanger rash as that stress is usually perpendicular to the wing; i.e. dropping stuff on the wing, squeezing it when working on it etc. There have been lots of articles written on constructing home built planes and all suggest that the spar webbing be with the grain of the web be at a 45 degree angle to the span. Realize that this stress also switches 180 degrees depending on whether the stress is positive (normal flight, positive G load) or negative (landing loads or inverted flight, negative G load).
Rodney is offline Find More Posts by Rodney
Old Dec 29, 2014, 12:10 PM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Regarding the grain of the shear web...hears something I posted a while back: http://www.rcgroups.com/forums/showp...6&postcount=31
Cheers,
Brian
cpdude is offline Find More Posts by cpdude
Old Dec 29, 2014, 12:17 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
If its a foam core fully sheeted wing, no sheer webbing is my way.
Ive done everything from 25size sport models to 40% 3D models with only a foam core with 1/4" sq. balsa spars and 1/16" sheeting on the wing.
invertmast is offline Find More Posts by invertmast
Old Dec 29, 2014, 12:55 PM
AA5BY is offline
Find More Posts by AA5BY
AA5BY's Avatar
East Texas
Joined Aug 2007
I agree... just cut the 1/4 spar notches in the top and bottom... forget the webbing. My answer is somewhat predicated by the use of balsa spars, which indicated that not a lot of additional strength is anticipated. Easier yet.... a strip of carbon fiber top and bottom under the sheeting if you've got it.
AA5BY is offline Find More Posts by AA5BY
Old Dec 30, 2014, 12:31 AM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Most folks just sheet the wing and use the skin as the spar. If you're expecting serious G loads then splice the sheeting together with a middle sheet that is on the hard side to act as more of a spar. But even then I doubt anyone bothers. If you want to gild the lily this way then make the center portion of the spliced sheet about 20% chord wide and centered over the area of maximum thickness. The foam core will be your webbing.
The only real reason to do a spar the way you're describing is for a thin section airfoil. Like less than 10% and with a relatively high aspect ratio.
BMatthews is offline Find More Posts by BMatthews
Old Dec 31, 2014, 09:43 AM
T_om is offline
Find More Posts by T_om
The Junk Man
Jacksonville, Florida
Joined Jul 2006
What Bruce said.
A foam core model aircraft wing that has been completely sheeted is immensely strong for its weight and size. A spar is almost never needed.
More reasonable recommendations can be made if you give more information... span, chord, weight of finished model, etc.
Tom
T_om is offline Find More Posts by T_om
Old Dec 31, 2014, 10:56 AM
sdad is offline
Joined Jan 2013
Tom, the plane is a Kaos variant. it has a span of about 64" weight is anticipated to come in at 7 1/2 lbs, +/- . I'd guess velocity at times of 100 mph, pull both pos and neg G's. As I intend on flying pattern manoveurs with the plane, and judges are rather fussy, I'd like the plane to be as consistent as possible, so that I can blame only myself (or the judges) for my low scores. This means stiff throughout, but for now I concern myself with wing flex only. Ever see the range of motion on the B-52 wing tips? Don't want that for this one.
After reading over these posts, I am leaning toward a pair of partial span joiner spars to help pick up the gear loads and keep the wing in 1 piece. I figure on using full span cf strips top and bottom that tie to the spars, foam, and sheeting. 1/16" sheeting glued with urethane, vacuum bagged.
Old Dec 31, 2014, 11:27 AM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Your last idea of a sub spar is just what folks have done for many years of foam wing use on similar models. The carbon strip is just "gilding the lily". But if you want to use some it won't hurt other than making things a bit more complicated to make.
Old Dec 31, 2014, 11:39 AM
T_om is offline
The Junk Man
Joined Jul 2006
Originally Posted by sdad View Post
Tom, the plane is a Kaos variant. it has a span of about 64" weight is anticipated to come in at 7 1/2 lbs.
Ok, the original Kaos had a built up D-box wing and that wing is NOWHERE NEAR as stiff as a sheeted foam core.
And they never had a problem with wings folding up.
Comparing one of our small model's wings with the flex that is intentionally built into B-52 (and most airliners) wings is comparing apples to antelopes.
You would have to go to great lengths to intentionally introduce that flex. Really great lengths. Really, really great lengths.
Those spars are primarily there for transmitting landing loads to the fuselage, which is a different thing than flight load induced wing flex. I would have those there myself for that purpose.
Most modelers never build a test sample of anything to determine destruction limits. I am not an exceptional builder, and would never claim to be, but I have built MANY test wings (and other parts) to determine load carrying ability and overall stiffness and strength.
I have used balsa sheeting and bagged fiberglass (which is what I use exclusively now, no need to sheet with balsa with a proper glass layup, but that is another issue). What I found was that most foam cored model aircraft wings are grossly over-engineered (and hence way heavier than they need to be) for the loads to which they are subjected.
For example your cored, sheeted, Kaos wing will never "flex" as usually meant by the word "flex" very much (and your B-52 example). It may indeed fail, but the failure will be instantaneous with very little deflection and the failure will be in compression of the top surface (opposite the applied load). But that failure with the wing sheeted as you said you were sheeting it is almost guaranteed to never happen, even without any full span spar at all.
Tom
For Sale 2 glass spar wing kits NIB balsa usa bandit71 Aircraft - Fuel - Airplanes (FS/W) 1 Nov 12, 2014 06:23 AM
Discussion Another stangely configured balsa build- micro ultra light. Ironbowser Scratchbuilt Indoor and Micro Models 16 Jan 04, 2010 11:44 PM
Wall Foam wing bracing - struts, balsa/CF spar, or invisible thread? billystiltner Scratchbuilt Indoor and Micro Models 21 Apr 14, 2004 08:30 AM
TwinJet - Aluminium arrow replacing balsa spar TecHStaR Foamies (Kits) 0 Jan 31, 2002 05:07 AM
Alternative for balsa spar on TwinJet mush Foamies (Kits) 5 May 20, 2001 03:23 PM
