Old Feb 03, 2013, 08:25 PM
tupeloflyer is offline
Find More Posts by tupeloflyer
Dixie Sky Devils AMA# 1015548
tupeloflyer's Avatar
United States, MS, Tupelo
Joined Oct 2012
capacitor on the ORx?
Been seeing these little capacitors on ebay and they say it will keep voltage stable in the event you have alot of amp draw preventing a brownout. does it really work? 3 to 5 bucks is cheaper than a new airframe.
tupeloflyer is offline Find More Posts by tupeloflyer
Old Feb 03, 2013, 08:59 PM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Spektrum advertises these for 4-cell race cars, not recommended for aircraft use. I use $20 add-on switch-mode Park BEC's for my speed controls that have linear BEC's to prevent brownouts when using 3S lipos and four or more servos.
http://www.spektrumrc.com/Products/D...ProdID=SPM1600
E-Challenged is online now Find More Posts by E-Challenged
Old Feb 03, 2013, 10:07 PM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
Those little capacitors are useful only to smooth out any high-frequency ripple in the input voltage. They might be able to buffer a current surge that lasts less than a millisecond or thereabouts. If you want a capacitor that is useful as a power source buffer, it would need to be the size of a soda can.
jkettu is offline Find More Posts by jkettu
Old Feb 03, 2013, 10:56 PM
Evan D is online now
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Waste of money.
Evan D is online now Find More Posts by Evan D
Old Feb 03, 2013, 11:20 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Spend the money on a BEC unit that can provide plenty of overhead power to run your servos. Instead of using a band-aid, just fix the problem at the source... Of course, the "problem" isn't really a problem for the vast majority of planes, so you don't need to worry about it anyway.
Piece is offline Find More Posts by Piece
Old Feb 04, 2013, 01:50 AM
600Bob is online now
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
Not true, this will run the RX and 4-5 HS 645mg servos, on the ground, for about 5 sec. after the power is turned off. At least it took that long before the RX would power down while moving all the servos before I could turn of my TX. And it is a lot smaller than a soda can.
http://www.fromeco.org/categories/Su...Equipment/DCUP
600Bob is online now Find More Posts by 600Bob
Old Feb 04, 2013, 10:48 AM
Wintr is offline
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
While it doesn't appear as large as a soda can, it does look as big as a 2 or 3 cell LiPo (and probably weighs as much). A good BEC is usually no larger than a receiver.
Wintr is offline Find More Posts by Wintr
Old Feb 04, 2013, 12:07 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
In all but the briefest (a few microseconds) of voltage depression, such capacitors are a total waste of your money, time and space. Do a simple energy calculation of what size a capacitor you would have to have to provide any reasonable time of protection. You will find it is much to large to be of any practical use.
Rodney is offline Find More Posts by Rodney
Old Feb 04, 2013, 12:15 PM
Joined Oct 2000
Go to Dimension Engineering's Website and read the FAQ's and installation guides. I use their $20 Park BEC's, switch-mode 1.5 amps, for all my small to medium 3S lipo-powered, 4 or more servo models. These BEC's as small and weigh almost nothing, easy to install, no need to disconnect red wire from ESC due to "bypass" feature.
Old Feb 04, 2013, 08:52 PM
Joined Aug 2011
It is about 2.5"x1"x1/2". Not something I would use on a small foamy but my 1/4 scale Tiger Moth doesn't know it's there, size is relative.
Old Feb 04, 2013, 11:40 PM
Dcope17 is online now
Find More Posts by Dcope17
Co-heir with Christ
Dcope17's Avatar
United States, CA, San Juan Capistrano
Joined Feb 2013
Why not install a 5 cell AAA NiMh pack? On its own switch and usually 1000mAh. Will last longer than any capacitor will...
Running it parallel to the BEC, they might fight each other a bit unless you install a diode so that one won't try to charge the other...
Dcope17 is online now Find More Posts by Dcope17
Help! Burned out tantalum capacitor - RMRC 480 - help? Mochaboy FPV Talk 4 Aug 30, 2013 01:49 AM
Discussion Lightweight covering for rubber or capacitor power dayhead Free Flight 18 Jan 19, 2013 08:27 PM
Discussion Capacitors for Spektrum aircraft Rx Daytonarc Radios 10 Jan 19, 2013 01:41 PM
Discussion 9XR + ORx Module + E-flite BNF = No Prob harrye Radios 3 Jan 02, 2013 06:59 PM
