Old Jan 29, 2015, 12:48 PM
xmech2k's Avatar
United States, CA, San Diego
Joined Jun 2007
Originally Posted by Ta152 View Post
I bought this airplane soon after it came out because I have always loved the look of the PC6. Upon opening the box I discovered it was missing the battery hatch. Contacted Towers and ask if they would send a replacement and they said they had no replacement parts so I ask if they could send me one from another kit and the answer was no. So much for customer service.
Then came the first flight where I became highly disappointed. On a landing I broke the plastic landing gear strut. Again no replacement parts but I learned a lesson.
No more Multiplex airplanes for me and no more orders from Towers Hobbies.
This plane seems an odd one out for Multiplex. Can't blame you for feeling that way, but my Multiplex Mentor is a durable, great flyer. The Toucan I'm still putting together seems solid as well. Perhaps better than the Mentor.
As far as Tower, if they wouldn't send me a hatch, I would have returned the plane for another (With all the pieces) or a refund.
xmech2k is offline Find More Posts by xmech2k
Old Jan 29, 2015, 02:15 PM
What stalls falls
Ta152's Avatar
Joined Jul 2006
I should have but had thrown the box away so I just chalked it up as a learning experience. Hopefully Multiplex will come up with a fix for the broken struts and I can get mine flying again. Until then it is just gathering dust with the broken struts.
Ta152 is offline Find More Posts by Ta152
Old Jan 29, 2015, 09:04 PM
United States, PA, West Chester
Joined May 2012
Have you tried contacting Hitec directly? They might be able to set you up with what you need.
Regarding the landing gear struts, I don't think anyone will disagree that they're essentially junk and counter to Mutiplex's normally decent quality but there are some great solutions on this thread. I ended up replacing the upper struts with aluminum tubing and when the plastic broke down near the wheels (each side), I drilled them out and inserted some steel rod (could have used carbon like others have) and have not broken the gear in at least a dozen flights. Its a frustration but nothing a little bench time can't fix.
This is a fun airplane and I hope you get yours flying soon.
Citationfxr is offline Find More Posts by Citationfxr
Old Jan 30, 2015, 04:56 PM
Lower AL
SeeMeDo's Avatar
Joined Feb 2013
Tower had the landing gear in stock at least they did Wednesday when I was checking for parts for another plane. I was going to order a spare set but decided to just keep landing right.
Just checked they are in stock $17.95 http://www3.towerhobbies.com/cgi-bin...I=MPUA2690&P=Z
JB Quick wield can fix almost any breakage on the plastic with a little whipping.
The landing gear are hard to figure out bang it in and no damage but hit just right and the plastic with the spring snaps at the retainer ridge for the spring, this is where I used the whipping and JB Quick.
Jeff………
SeeMeDo is offline Find More Posts by SeeMeDo
Old Jan 30, 2015, 06:01 PM
xmech2k's Avatar
Joined Jun 2007
My floats finally arrived! Backordered them from Horizon on Cyber Monday! At least she'll be ready for next month's float fly. No instructions so I'll have to look at their pictures for which strut goes where. No brainer beyond that.
As for my broken landing gear, I think I'll be making some metal upper struts. To each their own, but I'm not going to spend my money on more of the same landing gear.
Old Yesterday, 05:58 AM
Switzerland, BL, Reinach
Joined Nov 2012
Landing gear
The original landing gear is a kinematical faulty design. It is missing a hinge at the axle carrier.
For this reason there is genarated bending stress onto the struts at landing gear shock strut compression
--> the strut breaks.
Therefore I made new struts and axle carriers.
The axle carriers are made of composite sheets, the struts of aluminium tubes and carbon composite rods. The springs and the wire brackets are from the original landing gear.
Additionally I have installed a rebound stop.
Meanwhile I have made over 100 landings without any problems.
Rolf
topsecret1 is online now Find More Posts by topsecret1
Old Yesterday, 12:07 PM
xmech2k's Avatar
Joined Jun 2007
Very nice! Way better than the Multiplex ones. They should be ashamed of themselves.
Old Yesterday, 12:31 PM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Rolf
Nicely done Rolf
Cheers!
Gary
GLM is offline Find More Posts by GLM
Old Yesterday, 12:42 PM
Salome, AZ
Joined Jun 2010
Rolf
I see a Cottage industry in your future, I will take a set! How much?
In sunny Arizona
Jim
Jamesxii is offline Find More Posts by Jamesxii
Old Today, 09:50 AM
Lower AL
SeeMeDo's Avatar
Joined Feb 2013
Nice Rolf, I'm going to rig up a set when I can chase down the materials, so for now I just keep gluing and whipping. I'm going to trim off just a little bit off the plastic rod with the spring and poke a bead of foam into the base as a damper.
I like your design Rolf.
Flite-Test uses landing gear simular to the Pilatus on its Stork which should work well too.
Old Today, 12:50 PM
LSF 004 - AMA 5055
bobandris's Avatar
United States, CA, Saratoga
Joined Dec 2000
Landing Gear Mods
Hey guys,
I think Rolf's mods are much more scale like than what I did. But if you want an easier solution to get improved performance take another look at my post #752.
Bob
bobandris is offline Find More Posts by bobandris
Gallery Pilatus PC-6 Porter wizard of odd Scale Drawings and Three Views 2 Nov 04, 2014 12:11 PM
Build Log Guillow's Pilatus Porter PC-6 Bill Smudge Scale Kit/Scratch Built 51 Jan 13, 2014 08:01 AM
Sold PC-6 Pilatus Porter 60" wingspan UV-20 Golden Knights version payne9999 Aircraft - Electric - Airplanes (FS/W) 12 Dec 15, 2013 01:15 PM
Discussion Pilatus PC-6 Porter DXF file wizard of odd Scale Drawings and Three Views 2 Nov 16, 2013 01:52 AM
Pilatus Pc-6 Turbo Porter Parkflyer kestrel2003 Parkflyers 23 Jan 02, 2004 06:19 PM
