Old Sep 27, 2013, 12:44 PM
Österreich, Stmk., Graz-Umgebung
Joined Sep 2011
Build Log
F-104 Starfighter "Tetris" for 90mm with lenght 2,4m
Now it's got me again - with the "tetris flyer puzzle".
For about 10 days, piling up and piling up again yellow foam parts on a small countertop in our kitchen ...
It´s the F-104 "shortkit" from "bukvorez.ru"
http://www.rcgroups.com/forums/showthread.php?t=1953898
scale = about 1:7
L = about 2,38 m (rather longer, because the rudder!)
Wsp = approximately 1,10 m incl tiptanks
for 90mm EDF
Meanwhile, I've put most sections together and found that the inlet cross-section fits with cone for a 90mm edf - BUT without inlet cones - would also fit a 120mm edf and get enough air !!
That brings new opportunities and so my build could be a little complicated again ...
But I might also need some good advice for the floating elevator ... Since I do not know exactly how that should be supported most sense.
The fin is 18mm wide at the hing point.
The nose section should to be removeable and so the whole plane should then be in two parts. Nose cone with about 75cm length, and the back part with the wings and about 1,6 m.
Here are the first pictures:
greeting
Georg
GeorgeStyriaII is offline Find More Posts by GeorgeStyriaII
Old Sep 27, 2013, 12:56 PM
Wade Joos's Avatar
United States, UT, Salt Lake City
Joined Aug 2002
Good start
Looks like you have a good start on your puzzle.
Keep up the good work
Wade Joos is offline Find More Posts by Wade Joos
Old Sep 27, 2013, 01:01 PM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Nice work George.
Cheers,
Eric B.
AirX is offline Find More Posts by AirX
Old Sep 27, 2013, 02:02 PM
qwerty1000's Avatar
Russia, Moscow, g. Moskva
Joined Sep 2007
qwerty1000 is offline Find More Posts by qwerty1000
Site Sponsor
Old Sep 27, 2013, 02:16 PM
Joined Dec 2008
Great,
I will follow this thread with great interest..!
regds
ger
Ger v.d. Hulst is offline Find More Posts by Ger v.d. Hulst
Old Sep 27, 2013, 02:22 PM
D_FAST's Avatar
Denver CO
Joined Apr 2008
build by number.
D_FAST is offline Find More Posts by D_FAST
Latest blog entry: Dassualt Alpha Jet
Old Sep 27, 2013, 03:17 PM
Joined Sep 2011
Retract
Everybody is welcome here
For the retracts i think about this "F16 - style" from HK: http://www.hobbyking.com/hobbyking/s...4334&aff=82822
The mains should be at the end of area 29 and the front wheel at area 15/16.
We will see.
George
Old Sep 27, 2013, 10:32 PM
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Trenton
Joined Jan 2004
Looking good. I'm following this build.
CarreraGTSCS is online now Find More Posts by CarreraGTSCS
Latest blog entry: Split elevator set up JR 9303
Old Sep 28, 2013, 03:26 AM
Use your imagination....
czirh's Avatar
Turkey, Izmir, Seferihisar
Joined Oct 2007
F 104 my favorit aircraft, good luck.
Cem
czirh is offline Find More Posts by czirh
Old Sep 29, 2013, 01:22 AM
Joined Dec 2008
George, I was wondering how to assure while stacking all these parts on top of each other that you get a straight fuselage..Have you already figured out?
br ger
Old Oct 03, 2013, 05:11 AM
Joined Sep 2011
Hi Ger,
thats not so difficult, but you should always look for this "problem" while the assembling.
I glue the most section on a flat table, so that one side is always flat. An when i glue one ready section on top of the other ( about 5 sektions at one time), then i use a woodplate or glassplate with some extra weight on top of the "tower", while the glue is drying....
Here some pictures from the sektion where the fan will be...
Regards,
George
Old Oct 05, 2013, 03:11 AM
Joined Dec 2008
Hello George,
Thanks for posting the pictures..Its big!
Have you already made some thoughts how to stiffen this long fuselage? Does it get stringers inside? Or just some extra layer of glass? I understand from previous posts that you plan to stay below the 5kg all up weight..
regds
Ger
Old Oct 05, 2013, 03:34 AM
Joined Dec 2008
One more thing; would it be possible to build the fuselage in 2 halves? It looks like all sections are split at the center line. In this way you can build on a flat surface and assure it is straight in all directions..But strange thing is that I have not seen this approach in any of the Tetris builds..
Old Oct 05, 2013, 04:34 AM
Joined Sep 2011
Hi Ger, yes, thats possible and a good idea for easier sektion. I build the front sektion of my Saab and also the front from the Su27 and the MiG29/35 this way.
When you have a lot of pieces inside - than it´s not so easy to build in two halfs.
To strenghen the long fuselage i think of using a carbon tube on the top of the back - so the half of the tube you can see from the outside.
In the bottom inside of my Saab105 i use a balsa with 5x30mm glued with epoxy.
And maybe it´s strong enought with 1x 80g/m˛ and 1x 50g/m˛ layer of glass...
George
Old Oct 26, 2013, 04:08 AM
Joined Dec 2008
Hallo George,
Any news on F-104?
Discussion F-104G Starfighter, Tetris, Bukvorez qwerty1000 Foamies (Kits) 81 Sep 27, 2013 12:50 PM
Discussion Lockheed F-104 Starfighter in Tetris Bukvorez style construction 4stripes Electric Ducted Fan Jet Talk 30 Jul 14, 2013 10:14 PM
Discussion F-104 Starfighter- GIANT profile pusher jet greenseaships Foamies (Scratchbuilt) 1 Mar 21, 2013 02:44 AM
Wanted HET F-104 Starfighter jricchio Aircraft - Electric - Jets (FS/W) 3 Jan 16, 2013 03:52 PM
Sold HET 70mm F-104 Starfighter ARF/NIB -For Sale- flyinhigh025 Aircraft - Electric - Jets (FS/W) 7 Jan 03, 2013 04:18 PM
