Old Mar 06, 2015, 03:24 PM
GetFPV is offline
Find More Posts by GetFPV
GetFPV's Avatar
Joined Oct 2014
New Product
HeadPlay HD FPV Headset w/ 32ch 5.8GHz Receiver - Pre-Order open at GetFPV.com
GetFPV is excited to announce that we'll be carrying the new HeadPlay HD FPV Headset.
The HeadPlay HD's are available for pre-order now at GetFPV.com
The new HeadPlay HD FPV Headset is packed full of features that every FPV enthusiast will enjoy. This headset was designed from the ground up with the FPV pilot in mind, with quality, performance and comfort at the forefront. The headset gently rests on the forehead/cheeks spreading the weight out evenly, which compared to many video goggles which rest on the bridge of the nose instead. Three straps securely hold the HeadPlay HD in place while at the same time blocking light coming in from the outside. The end result is a cinematic experience that is sure to impress. This headset is a great choice for FPV pilots that struggle to find a traditional FPV goggle that meets their Interpupillary distance (IPD). Instead of each eye having to look through separate optics, the new HeadPlay HD presents the pilot with one large screen. We've tested the HeadPlay HD with eye glasses and were able to make it work, even though the HeadPlay HD does not officially support wearing eye glasses at the same time.
Beautiful display.
1280x800px HD gloss screen. No blue screen issues.
Integrated 5.8GHz receiver.
32 channel receiver designed by RangeVideo. Super sensitive and works with Boscam/ImmersionRC/Fatshark. All channels. Channel switch by push-button and LED segment display on top of goggles.
HDMI input.
Connect the Headplay HD goggles directly to your DJI Inspire or DJI Lightbridge system. See in HD to make better aerial videos.
External AV input.
Connect your 900MHz/1.3GHz/2.4GHz external FPV audio video receivers to the Headplay HD. Bring new life to your old FPV setup. Try it with the super crisp and bright Headplay HD.
  • Screen resolution: 1280x800
  • Field of View: 72 degree
  • Fully adjustable picture via intuitive menus
General
  • Control via button panel (distinct button design for "blind" operation)
  • Rugged design with extremely durable materials
  • Very high comfort
  • Adjustable straps
  • Different density foam pads allow you to adapt the goggles to your needs.
  • Weight: 400g (excluding battery)
  • Easy to clean optics
Electrical Properties
  • Current consumption*340mA@12V
  • Supply voltage: 6-15V Recommended 2S LiPo
  • Reverse voltage protection
Connectors
  • HDMI type C (HDMI-in)
  • XS9JK (latched high end connector): Power Supply, Video-in, Audio-in, Ground, 5V out
  • SMA antenna connector
Integrated Features
  • 32 channel 5.8GHz A/V receiver
  • Sensitivity: -90dBm
  • Built-in speaker with volume control on buttons
  • Frequencies*(MHz):*
    • Band 1:*5725, 5745, 5765, 5785,*5805,*5825,*5845,*5865
    • Band 2:*5733, 5752,*5771,*5790,*5809,*5828,*5847,*5866
    • Band 3:*5705, 5685,*5665,*5645,*5885,*5905,*5925,*5945
    • Band 4:*5740,*5760,*5780,*5800,*5820,*5840, 5860,*5880
Included
  • 2 Different lenses (to adapt to personal immersion wishes)
  • 1100mA 2S hard case battery
  • 30cm Cable (1 foot) with barrel type battery connector
  • 250cm Cable (8 feet) with AV-in, Audio in and barrel connector
  • 3 Face foam packs (different densities to allow comfort adjustment)
  • Lens cleaning cloth
Q&A
Q: Is the Headplay HD compatible with DJI Inspire1 and Lightbridge?*
A: Absolutely, the goggles are designed with these 2 products in mind! They can be directly connected via a HDMI cable. The picture quality is simply amazing!
Q: What material is used for the Headplay HD housing?
A: The goggles are made out automotive grade EPP which has been chosen for its superior strength (widely used in car bumpers) and for its low weight
Q: Can I wear glasses?*
A: Yes, but it depends on the width of your glasses. But the goggles can be modified with a sharp knife to adapt the width to your particular needs.
Q: Will there be spare housings available so that I can make adjustments to fit my huge glasses?
A: Yes, we probably make the housings available at an attractive price.
Q: Is the Headplay HD 3D enabled
A: No, the goggle uses a single high resolution screen. But due to the unprecedented viewing angle, the immersive feeling almost like 3D.
Headplay HD Overview (0 min 28 sec)
Order your HeadPlay HD's today at GetFPV.com
GetFPV is offline Find More Posts by GetFPV
Site Sponsor
Old Mar 08, 2015, 10:52 AM
CA_Doug is offline
Find More Posts by CA_Doug
United States, CA, Pasadena
Joined Dec 2013
Head play site now says 1000 mah in a forum comment. That true?
What about SkyZone vtx?
What do the different lenses do? I have no idea what personal immersion wishes means.
What about support and warranty? Can parts be replaced, ie if the vrx goes bad.
Can the firmware be updated?
I looked into preordering, but shipping was being added. No free shipping on this? It certainly is over the minimum.
What camera and vtx would be good for this given the huge FOV and high resolution?
CA_Doug is offline Find More Posts by CA_Doug
Old Mar 08, 2015, 11:50 AM
noishi is offline
Find More Posts by noishi
noishi's Avatar
United States, CA, Long Beach
Joined Oct 2003
^ same question on camera requirements to fill the FOV for the goggles. Also is an antenna included?
noishi is offline Find More Posts by noishi
Old Mar 08, 2015, 11:55 AM
Mr.Aaron is online now
Find More Posts by Mr.Aaron
Team Warpsquad
Mr.Aaron's Avatar
United States, NV, Las Vegas
Joined May 2009
If you want the best picture you will need a light bridge setup via gopro or whatever camera I'd imagine. If not any effio camera and vtx should be fine.
Mr.Aaron is online now Find More Posts by Mr.Aaron
Old Mar 08, 2015, 01:08 PM
titeuf007 is offline
Find More Posts by titeuf007
Joined Jun 2006
great !
what is the size of the screen inside?
titeuf007 is offline Find More Posts by titeuf007
Old Mar 08, 2015, 03:37 PM
joelwhite is offline
Find More Posts by joelwhite
Joined Sep 2014
When placing an order it says the preorder is on backorder lol. Just making sure placing this order will get me in on the preorder. Still available to preorder yes?
joelwhite is offline Find More Posts by joelwhite
Old Mar 08, 2015, 03:50 PM
noishi is offline
noishi's Avatar
Joined Oct 2003
Can we still get free shipping for orders over $60?
Old Mar 08, 2015, 06:43 PM
Joined Sep 2014
No free shipping on em
Old Mar 09, 2015, 08:45 AM
GetFPV is offline
GetFPV's Avatar
Joined Oct 2014
Yes the "backorder" status is the same as pre-order in this case. It is simply a new product that doesn't have stock yet. Any order placed now will secure their spot in line for shipment from the first batch.
Free shipping is not available on this product due to the box size it ships in.
For those of you asking about what Tx/Camera to use, yes an HD link like Lightbridge would give you the best overall picture, however a standard definition analogue system looks good as well. The monitor will simply upscale the signal to the native resolution of 1280x800. It won't be an HD picture, but it still looks very nice on such a high quality screen.
Yes there will be spare parts available later on, but we don't have any details on them yet.
Site Sponsor
Old Mar 09, 2015, 08:53 AM
derelicte is offline
Find More Posts by derelicte
Joined Aug 2006
Originally Posted by titeuf007 View Post
great !
7"
http://www.headplay.com/#!/general:s...more-info-on/7
derelicte is offline Find More Posts by derelicte
Old Mar 23, 2015, 09:56 PM
JediKnight2 is online now
Find More Posts by JediKnight2
I'm Bonafide!
JediKnight2's Avatar
Wilmington, NC
Joined Aug 2005
is there a video out on these?
JediKnight2 is online now Find More Posts by JediKnight2
Old Mar 27, 2015, 09:55 PM
MichaelD33 is offline
Find More Posts by MichaelD33
Joined Jan 2015
Yes, I believe there is an external video out (HDMI)
MichaelD33 is offline Find More Posts by MichaelD33
Old Mar 28, 2015, 08:05 AM
steph_a is offline
Find More Posts by steph_a
Canada, QC, Laval
Joined Jul 2008
There is AV in but no AV out as per specs on website
steph_a is offline Find More Posts by steph_a
Old Mar 29, 2015, 09:53 PM
Redemptioner is offline
Find More Posts by Redemptioner
Professional UAV Services
Redemptioner's Avatar
Australia
Joined Dec 2009
These look great, too bad they are EPP instead of ABS or something else that seemed a little less DIY (could of put a plastic coating on it) and not sure why you would skimp out on DVR and head tracking considering how cheap these items are (maybe add $30-50 to the retail cost). Either way I will be ordering a set
Redemptioner is offline Find More Posts by Redemptioner
Old Mar 29, 2015, 10:38 PM
Team Warpsquad
Mr.Aaron's Avatar
Joined May 2009
the use of epp I'd imagine is weight savings and epp is really durable. Plastic will break before that stuff.
Alert Alien Wii FC pre orders at RC-drone.com madman1412 Product Announcements 1 Feb 03, 2015 05:37 PM
For Sale RC832 5.8GHz 32CH FPV AV Receiver (All FPV bands A-E) Waterbound FPV Equipment (FS/W) 1 Oct 31, 2014 09:09 AM
Sold Black Pearl 7" HD LCD Screen FPV Diversity Rx 5.8GHz 32CH greedyg76 FPV Equipment (FS/W) 4 Mar 20, 2014 02:52 PM
For Sale FPV 5.8G 600mW 32CH A/V Transmitter 32CH A/V Receiver (RX) W/ LED Channel fpvhobby_mandy FPV Equipment (FS/W) 6 Oct 11, 2013 03:06 AM
