Old May 21, 2015, 05:35 PM
GPR is offline
GPR
Find More Posts by GPR
GPR
GPR's Avatar
Rochester, Michigan
Joined Jan 2009
Originally Posted by Ed Crowell View Post
Hi Greg,
That rear seat is a great piece of engineering.
Ed
Thanks, Ed. I am planning to use your approach here http://www.rcgroups.com/forums/showt...993127&page=53 to making floor mats for the cockpits. I think that was a great idea.
GPR is offline Find More Posts by GPR
Old May 21, 2015, 07:09 PM
Ed Crowell is offline
Find More Posts by Ed Crowell
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
Greg,
I sprayed the plastic floor mats with Testors spray enamel #1249 flat black. I don't recommend using it. Every time I rubbed a finger nail across the paint it left a shiny streak. I had to spray over the flat black with a dull clear coat.
Ed
Ed Crowell is offline Find More Posts by Ed Crowell
Old May 21, 2015, 09:46 PM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Cool, never heard of ABC props, looks aggressive.
Originally Posted by GPR View Post
Fortunately, I was able to find something very close to what I was looking for at Offshore Electronics. I ordered and received this ABC Prop that I think will do nicely. And, it was made in the USA, in Columbus, Ohio! Again, this may not turn out to be the right prop for running, but it will do for scale appearance.
woodybob is offline Find More Posts by woodybob
Old May 22, 2015, 08:31 AM
GPR is offline
GPR
GPR
GPR's Avatar
Rochester, Michigan
Joined Jan 2009
Greg,
Ed
Thanks for the tip, Ed. I think I'll go with my trusty Krylon from a rattle can. They make a formulation now specifically for use on plastic. I'll see how it works.
Old May 24, 2015, 08:54 PM
GPR is offline
GPR
GPR
GPR's Avatar
Rochester, Michigan
Joined Jan 2009
I changed my mind about the paint. While shopping for plastic siding at my LHS, I found some spray paint for use on plastics in the perfect color.
Old May 24, 2015, 08:56 PM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Half Moon Bay
Joined Aug 2009
Wish I had a LHS Anywhere near me !
Tim B. is offline Find More Posts by Tim B.
Old May 24, 2015, 09:02 PM
GPR is offline
GPR
GPR
GPR's Avatar
Rochester, Michigan
Joined Jan 2009
I also picked up some Plastistruct sheeting to use for the rubber inserts on the step pads. I sprayed the inserts with the same rubber colored spray paint. I experimented with several adhesives for gluing the plastic inserts to the chrome bases. Many of the glues called for a thin coat to be applied to each surface and then allowed to dry for a few minutes. Once pressed together there was no ability to reposition. I found one glue that did not require that approach and would allow a few seconds for repositioning.
Old May 24, 2015, 09:19 PM
GPR is offline
GPR
GPR
GPR's Avatar
Rochester, Michigan
Joined Jan 2009
I made the front cockpit bumper pad from some 1/4 inch half round styrene. It was stiff, but after heating with a hairdrier, it held the bends quite well. I originally intended to cover the styrene with leather but, after some trials, I found that the plastic looked just as good as the leather after I sprayed it with my green leather dye. It was a little too shiny so I coated it with a flat clear.
Old May 24, 2015, 10:01 PM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
The Tamiya paint was a good find. With a name like that (Rubber Black) I would have bought it in a heartbeat also. That step pad material is neat stuff also.
Ed
Old Jun 29, 2015, 07:20 PM
californiakid is offline
Find More Posts by californiakid
mahoganyfan
californiakid's Avatar
United States, NJ, Atlantic City
Joined Nov 2010
Beauty
Hey Greg, how is the build coming along?
californiakid is offline Find More Posts by californiakid
Old Jun 30, 2015, 08:06 AM
GPR is offline
GPR
GPR
GPR's Avatar
Rochester, Michigan
Joined Jan 2009
I have been hard at work. Lots of time fussing and fitting the windshields. Good progress attaching trim. Both flagstaffs are done with flags flying. I want to keep going on the outside and will post pictures when that work is complete. Then I will have just the dash and wheel to finish up. I can see the light at the end of the tunnel. Hope it's not a train!
Discussion Central Banks and 'order', II MtnGoat Life, The Universe, and Politics 133 Apr 17, 2013 09:30 AM
Wanted Airtronics Olympic II manual jbogdano Aircraft - Sailplanes (FS/W) 4 Mar 27, 2013 05:07 PM
Discussion CHICO II - Vintage 36/600 RodACarr Sailboats 1 Mar 27, 2013 10:52 AM
Help! Airtronics Olympic II manual jbogdano Thermal 3 Mar 27, 2013 09:53 AM
New Product Now available: Cox Black Widow II - Golden Bee II - Venom II xenalook 1/2A Planes 0 Mar 22, 2012 02:09 PM
