Old May 15, 2015, 03:38 PM
MasterCATZ is offline
Find More Posts by MasterCATZ
Joined May 2015
ROFL I have heaps of these around 15x in my old DL380 servers sitting in the shed
how do they go adding into parallel ? say up to 4x
I am after current increase and that nice 13.8v bump is just perfect
is their a way to get all the PSU's to change voltage at the same time during tuning or do I need a separate pot per PSU ?
I might go the stingy path and use a toggle switch to change the volt / amp screen to other PSU's
how do these go with HAM Radio equipment ? I still have an 5kw setup I need to do that will have to be split across 3x different power sources
will they still pair if the mains input is on separate circuits each breaker here is 20Amps with maximum 60Amp main breaker per house @ 240v
downside being most houses only have 10Amp wires in ... some you can get away with changing to 15 AMP wall plug for short term use
will hot swap still work ?
ie) if I use 12x of these to get his 5kw HAM Radio running and 1x drops out
Could I just replace the failed PSU hot ?
I am planning on running 4x units per house circuit hopefully that gives them a fail over and some room to breath
I could get away with 3x per house circuit but thats pushing the PSU's to their MAX and using only 10x units left me with
4x 4x 2x or 3x 3x 4x on a circuit .. I hate not being even :P
also planning on running 3000 Farad capacitors between the PSU's and his HAM radio to help filter any noise / allow equipment to keep running if some PSU's need resetting its all within the $1000 budget
how ever he said its broad casting where the most power is used so I could do a 9 set-up with the capacitor bank
will grab some and start on this 100+ page novel
MasterCATZ is offline Find More Posts by MasterCATZ
Old May 19, 2015, 08:27 PM
rchelijc is online now
Find More Posts by rchelijc
Pro beginner
rchelijc's Avatar
Melbourne, Australia
Joined Aug 2010
To parallel, just hook up all their current share pins together. See first few posts
rchelijc is online now Find More Posts by rchelijc
Old Jun 03, 2015, 03:24 PM
rcallison is offline
Find More Posts by rcallison
Foam Wannabe
Joined Nov 2005
I have been learning to work with my new micro 3d printer and decided to try and design a quick face plate for DPS-600. The current version seems to work pretty well at screwing into the two spots where the daughter board fits. I started with one with 10mm holes for binding posts, but did a blank plate as well so someone could drill there own holes. Let me know what you think.
http://www.thingiverse.com/thing:863039
rcallison is offline Find More Posts by rcallison
Old Jun 07, 2015, 05:02 PM
Pe-a-nuts is offline
Find More Posts by Pe-a-nuts
Denmark, Odense
Joined Feb 2008
Cool builds and great informative thread!
I've just received two DPS-600PB Rev: 03 and decided give these units a go as well. Planning to hook them in series together to feed a Hyperion 1420i.
I'm however still a bit unsure about couple things...
1. Would adding zener diodes to outputs in my 24V configuration for safety be necessary? or does somebody know if the power supply has any build in?
2. So according to previous comments, I could in same configuration risk damaging either computer or charger, if I try hook up the USB cable (analyzing) to my computer as well. I can with my multimeter and continuity test get a display reading, saying 590, when I have the negative probe at the negative charger input, and positive probe at USB GND on my charger. Should I be worried?
3. No one has ever mention the small orange capacitor, that is soldered on the hot-swap board! It's connected between 12V ground and pin 12 (Power OK/Fault). Purpose? Needed?
Pe-a-nuts is offline Find More Posts by Pe-a-nuts
Old Jun 08, 2015, 02:53 PM
FlyNNN is offline
Find More Posts by FlyNNN
FlyNNN's Avatar
Joined Feb 2015
Originally Posted by rcallison View Post
I have been learning to work with my new micro 3d printer and decided to try and design a quick face plate for DPS-600. The current version seems to work pretty well at screwing into the two spots where the daughter board fits. I started with one with 10mm holes for binding posts, but did a blank plate as well so someone could drill there own holes. Let me know what you think. http://www.thingiverse.com/thing:863039
Looks good. Thanks for sharing!
FlyNNN is offline Find More Posts by FlyNNN
Discussion Flydumini Frame Thread and Build Hints/Help nasgul Multirotor Talk 216 Sep 28, 2013 04:58 PM
Discussion DPS-600PB Power Supply Shuts Down wcsd106 Batteries and Chargers 3 Jun 23, 2013 06:11 PM
Mini-HowTo Tips, Tricks, Hints, Secrets & How To's to help make a build/rebuild easier... ABADGTP The Builders Workshop 37 Dec 24, 2011 11:48 AM
Discussion Sokol build tips and hints Dan the man High Performance 9 Aug 21, 2008 03:26 AM
Discussion GWS Piper Cub Build Tips & Hints? Royster Australia 111 Feb 07, 2007 03:11 PM
