Old Aug 16, 2015, 06:59 AM
Adam2003 is offline
Find More Posts by Adam2003
DroneBoy
Joined Aug 2015
Looking for micro quads!
Hello,
I am looking for 2 cheap micro quads, one for me and one for my dad.
from the size around 10-15cm
I was thinking about a Syma X11 and X4.
But I am sure you guys have a better advice or can tell me a bit more about these 2 quads,
Adam.
Adam2003 is offline Find More Posts by Adam2003
Old Aug 16, 2015, 08:24 AM
r2cDUDE is offline
Find More Posts by r2cDUDE
Joined Aug 2015
i highly recommend the hubsan x4 its very fun for beginners and expert flyers because of its two modes,it also is quite durable for its size.
r2cDUDE is offline Find More Posts by r2cDUDE
Old Aug 16, 2015, 09:12 AM
RC Crasher is online now
Find More Posts by RC Crasher
Keep`em in the air
RC Crasher's Avatar
United States, OH, Pataskala
Joined Aug 2012
I would recommend the JJRC JJ-1000 and the Yizhan X4. Both of these quads use the same protocol which means you can use either transmitter for either quad.
Both have propguards (Yizahn X4 isn`t removable).
Once you get a transmitter, you can buy a Bind and Fly (BNF) JJRC JJ-1000 for around $13 (once you start flying, one quad won`t be enough).
The Yizhan X4 comes with a 350mah battery but can hold a 500mah. I get 4 1/2 minutes of flight with the 350mah. The JJ-1000 comes with a 250mah. I use a 350mah and get between 6 and 7 minutes of flight depending how hard I`m flying.
Everyone has their preferences, but IMO these quads are better than the Hubsan X4. I have 2 Hubsans and rarely fly them because the JJ-1000 and Yizhan X4 fly much better. The Hubsan X4 does have longer flight times and with a 500mah battery can get 10 minutes of flight. I think it`s faster, too. It just doesn't fly quite as well.
Parts are easier to find for the Hubsans. With the JJ-1000, it's cheaper to buy a new BNF.
RC Crasher is online now Find More Posts by RC Crasher
Old Aug 16, 2015, 10:14 AM
Adam2003 is offline
DroneBoy
Joined Aug 2015
Thanks, I already ordered a x5c-1 for myself and I have flown a quad before (it broke )
Myself I will be getting a wltoys Q212G
But for my dad I will need something very basic stable and easy to fly, Like a syma X4
he only flew my quad once and that was when it had stability issues.
Any suggestions?
Old Aug 16, 2015, 11:06 AM
Lycan Animal is offline
Find More Posts by Lycan Animal
Joined Dec 2014
My YZ X4 has screws underneath each prop guard that allows you to undo them and remove them. You can also get replacements cheap from Banggood for a set of four minus the screws (so use the right screwdriver and don't strip the heads like I did)
http://www.banggood.com/YI-ZHAN-X4-0...-p-940809.html
Originally Posted by Adam2003 View Post
Hello,
Adam.
The Syma X11 is a nice stable flier and good for beginners but also look at the Moontop M99916 which is a clone with better yaw rate for less money.
JJ1000 BNF's are a great buy if you do go with the YZ X4 as the transmitter and battery will work with both. The YZ X4 is a nice quad but with a lot of pitch and less yaw, great for speed not so much for tight funnels.
A favourite among many including me is Bayangtoys X9, cheap, nice transmitter, swappable battery, can take a lot of knocks and very nice fliers, great as trainers.
But both the X11 and especially the X4 are good suggestions for a nice easy stable flier or a beginners quad.
Edit: Added photos of the screws to remove prop guards from YZ X4.
Lycan Animal is offline Find More Posts by Lycan Animal
Old Aug 16, 2015, 05:54 PM
Keep`em in the air
RC Crasher's Avatar
Joined Aug 2012
Thanks for correcting me. I just flew mine and saw the screws. I was going to correct my post, but you did it for me. I was wrong. First time for everything, I guess.
Old Aug 16, 2015, 08:54 PM
Edmond Y is offline
Find More Posts by Edmond Y
Joined Nov 2008
Yi-Zhan YZ X4, Bayang toy X7, X9. Syma X4 and JJ1000's are super beginner quad. One thing about the Syma X4, because it sit very low to the ground which is hard to take off from grass and also pick up hair and blind the props. you can use cable tire to make some landing feet for it, it is a great flyer.
Edmond
Edmond Y is offline Find More Posts by Edmond Y
Old Aug 16, 2015, 11:39 PM
Joined Dec 2014
Not wrong, think of it as correct given the factual data you had available at the time.
It surprisingly makes very little difference without the prop guards but does look weird with the shafts sticking out so far past the motors. I tried leaving the guards on and modifying them so they don't catch on things too much but went back to fitting full proper guards just because it looks better. And they are effective.
Old Aug 17, 2015, 01:45 AM
Adam2003 is offline
DroneBoy
Joined Aug 2015
thanks for the replys!
I will probably be getting my dad a Bayang X9 soon,
Old Aug 17, 2015, 04:14 AM
SoloProFan is online now
Find More Posts by SoloProFan
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
X9 is a solid choice, get a H8 Mini as well, as it can bind to the same transmitter as the x9, for better control. Both are different flying quads, so nice for some diversion.
SoloProFan is online now Find More Posts by SoloProFan
Latest blog entry: Pictures of various boats
Old Aug 17, 2015, 05:18 AM
Adam2003 is offline
DroneBoy
Joined Aug 2015
Netherlands
Old Aug 17, 2015, 05:46 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Netherlands
You live there too?
Old Aug 17, 2015, 09:40 AM
Joined Dec 2014
GB has the Green for only $18.32 USD at the moment but that price is only on the Green one.
Black is $23.77 USD and White $22.72 USD for some reason.
Green is the best looker in my opinion, if it's anything like the sale they had on the Red HY852 it may not last long though.
Old Aug 17, 2015, 10:03 AM
Adam2003 is offline
DroneBoy
Joined Aug 2015
Originally Posted by SoloProFan View Post
You live there too?
Yea
Old Aug 20, 2015, 10:46 AM
mwhitton is online now
Find More Posts by mwhitton
Joined Jul 2015
Go to a Flea market!! I bet you can get a great deal. I just was at one on Sunday and paid $11(USD) for my Micro Quadcopter
Flea Market Quadcopter - Blade Runner - M.A.V. Mosquito - An $11 Quadcopter - used (11 min 1 sec)
mwhitton is online now Find More Posts by mwhitton
Discussion What do you look for in a micro FPV quad? rc_flyboy Multirotor Talk 2 Jul 27, 2015 07:52 AM
Help! looking for the replacement SMD Capacitor for micro quad. craze Mini Multirotors 0 Jan 19, 2015 11:30 PM
Question Looking for a plug and play FPV system for mini/micro quads rctech96 Mini Multirotors 12 Dec 19, 2014 08:53 PM
Looking to trade for a micro quad Florin777 Non R/C Items (FS/W) 5 Nov 21, 2013 06:49 PM
Wanted Looking for a micro quad from blueskyrc.com ahtiram Aircraft - Electric - Multirotor (FS/W) 3 Nov 14, 2013 04:21 AM
