Old Jul 06, 2015, 07:24 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2015, May 28-31st
Robert Belluomini's Avatar
Joined Dec 2000
Usher F106 video
Wayne's electric Usher F-106 test flight (3 min 41 sec)
E Dina max on 10 cells
Video by Pdawg
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Jul 06, 2015, 08:00 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
flew nice ...I was screaming ....power power power as I saw the sink rate building up . deltas are tricky ....
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jul 06, 2015, 08:32 PM
JetMang is online now
Find More Posts by JetMang
The RC Geek
JetMang's Avatar
San Diego, California, United States
Joined Feb 2002
And rudder on the rollout, haha
JetMang is online now Find More Posts by JetMang
Old Jul 07, 2015, 07:25 AM
Joined Dec 2000
It looked like his exhaust was at 100% fsa
What is a good exhaust diameter to suggest to him. It's a Dynamax on 10S
Old Jul 07, 2015, 09:46 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
If that's Waynes 106 ask him to get me the installed thrust and amps... I measured >12lbs at 3600 watts on the bench (vertical stand)
It shouldn't have limped up in the air with only 17lbs auw
He's also not using all the stators that a dynamax can use so that's going to affect efflux..
Just saw it again, was this the first flight?
When I talked to Wayne he said it was tail heavy and he couldn't build up good speed...
erh7771 is online now Find More Posts by erh7771
Old Jul 07, 2015, 10:00 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
3.5" is a good size to start. On 12s guys have run 3 3\8".
Old Jul 07, 2015, 10:34 AM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
That was the 2nd flight after moving the CG forward 2".
pdawg is offline Find More Posts by pdawg
Latest blog entry: Visiting Edwards AFB
Old Jul 07, 2015, 10:51 AM
Joined Dec 2000
Thanks, I'll let Wayne know when I return Friday.
Old Jul 07, 2015, 10:57 AM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Interesting...as I watched the vid I was thinking the plane is nose heavy..too much up elevator holds the plane in a nose high angle and wont allow it to get on step and just plows along
turbonut is online now Find More Posts by turbonut
Old Jul 07, 2015, 12:26 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
2" seems like a big swing in cg.I remember seeing one of these try to fly back in the glow days at a BITW jet meet at Edwards.......it would not hardly fly.this one flew pretty good once it rotated..if the gear!was move fwd it might come off the ground better.
Old Jul 07, 2015, 12:36 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
TN as I watch the video again it lost alt on every turn. That is another tell tale nose heavy sign.what was the first flight like . maybe start moving the cg back bit by bit.also I have found that models with Delta wing like a air foil with lots of reflex in them.
Old Jul 07, 2015, 01:01 PM
Joined Dec 2000
The model is definitely NOT nose heavy.
Old Jul 07, 2015, 09:12 PM
Joined Nov 2005
Wayne said he was going half throttle after take off and doing a lot of trimming in the flight
Then on landing he dropped power and it dropped it's butt and landed at a aggressive slope...
Sounds still tail heavy by his description; drop power then the plane drops towards the heavy side of the center of lift
Cells were at 3.82 a cell on landing so he wasn't punching it in the air
Can't wait to see this thing fly with it all trimmed out
Old Jul 07, 2015, 09:46 PM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Tail heavy does not work that way!. The only real effect is pitch instability.The plane will hunt up and down as the pilot try to chase it and keep up in the air.The tail low sink was due to low airspeed.
Old Jul 08, 2015, 05:51 AM
candane is offline
Find More Posts by candane
Turkey
Joined Oct 2008
In my opinion this plane is nose heavy. It looks like there are alot of elevatör trim.
candane is offline Find More Posts by candane
Discussion F106 / Mirage 4000 scratch build TTRotary Scratchbuilt EDFs 42 May 13, 2015 04:12 PM
Discussion F106 Jet Crash JohnVH Crash Discussion 4 Apr 07, 2015 11:06 AM
Build Log Colin Usher Megawatt with modifications. solentlife Fuel Plane Talk 7 Oct 12, 2014 06:13 AM
Wanted Usher F-106 MAP Aircraft - Fuel - Jets (FS/W) 0 Apr 28, 2014 07:25 AM
