Old Sep 21, 2011, 08:06 PM
hornet_dave's Avatar
USA, IA, Cedar Rapids
Joined May 2003
Brushless winch experiment
It's a bit flintstonian but here's the mechanical progress so far:
hornet_dave is offline Find More Posts by hornet_dave
Old Sep 21, 2011, 09:28 PM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Best of luck. What are you going to use for a ESC and battery?
Evan D is online now Find More Posts by Evan D
Old Sep 21, 2011, 09:46 PM
Joined May 2003
Some more details:
On a 12S lipo, the linespeed should be around 18 MPH and pull about 100 lbs at 100 amps. I'm thinking it will be a bit overkill. Drum diameter is .75" as it's going to spin at ~7000 rpm. Drum ends are wood and will be glued to the drum and prevented from shifting outwards by use of shaft collars. Only one machining operation is needed - a lathe is required to drill the hole in the end of the rod where the motor prop adapter screws in.
The ESC will be from my heli (castle ICE 80HV), and it will be controlled by a simple 555 circuit that takes the pedal "tapping" and converts it to a throttle signal. The circuit has been bread-boarded and works fine, next I need to solder it up to a circuit board and put it into an enclosure. If this whole idea works, the next step would be to add a shunt in the battery line that would reduce the throttle when the current gets high. I'm pretty concerned with the potential to burn out ESC's, as high loads and low throttle positions make hobby ESC's go "POP".
The whole winch, including battery, should weigh around 10 lbs. I have no idea how many launches I'll get on a charge.
Old Sep 22, 2011, 01:04 AM
MrE
United States, WA, Gig Harbor
Joined Aug 2007
Set the current limiting to "Normal" or "sensitive" on the Castle. It will protect itself.
MrE is offline Find More Posts by MrE
Old Sep 22, 2011, 08:36 AM
United States, NY, Lewiston
Joined Apr 2011
7000 rpm's?!!!! Be careful....at that kind of speed, those wooden parts can fly apart (I've had it happen at much lower speeds on my lathe). You need to carefully balance the whole rotating assembly or this thing could be dangerous.
theghosttanker is offline Find More Posts by theghosttanker
Old Sep 22, 2011, 11:01 AM
Joined May 2003
Thx. I just worked out the calcs for the disks, I only have roughly a 100% safety factor, which does not include the sideloading from the string pressing sideways on the disks. This is not enough for comfort. If I stay with a 12S lipo, I'll have to fabricate new disks of plywood. In the meantime, keeping body parts away from the plane of rotation will be necessary!
Edit -- math error! The factor of safety is closer to 10.
Old Sep 22, 2011, 03:50 PM
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Originally Posted by hornet_dave View Post
Some more details:
I know nothing of linespeed, but the Supra is designed to a 200lb winch load. What size airplane are you launching?
rdeis is offline Find More Posts by rdeis
Old Sep 22, 2011, 04:33 PM
Joined May 2003
In that case, you wouldn't need to worry about destroying a Supra as my ESC would die first! In any case, 100 lbs is about the highest I can do with the batteries and ESC I have on hand. If I didn't already have the batts and ESC, I would not have attempted this little experiment. To get up to the 200 lb range, you would need a 150+ amp HV ESC, 30-40C 12S 5000 mah batteries, and a 50CC equivalent motor. I'm flying a 3M woodie so this winch should be plenty for me.
Old Sep 23, 2011, 01:25 AM
rogerflies's Avatar
Thomasville, GA 31792
Joined Apr 2002
How are you going to stop the drum after a launch?
rogerflies is offline Find More Posts by rogerflies
Old Sep 23, 2011, 07:58 AM
Joined May 2003
Im hoping its relatively low inertia will cause it to stop itself. If not i will have to turn on the prop brake feature which will make retrieval a pain.
Old Sep 23, 2011, 09:22 AM
rogerflies's Avatar
Joined Apr 2002
Isn't it a three-phase motor? If so, you can switch any two leads to reverse the direction it runs. That could be accomplished with a double-pole-double-throw relay when braking is needed.
With such a small hub diameter, it's probably going to be spinning much too fast to stop by itself.
Old Sep 23, 2011, 08:52 PM
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
That might work with a steady supply of 3-phase alternating current, but not with an ESC. I'd expect the microcontroller to become totally confused and behave unpredictably if the motor leads were suddenly switched.
Using the prop brake feature is probably the best strategy. You'd just have to disconnect the power to retrieve the line.
Miami Mike is offline Find More Posts by Miami Mike
Old Sep 23, 2011, 09:05 PM
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Warning Warning Will Robinson! (arms waving wildly)
Plywood drum endplates? If the line winds up against the endplates, it could blow them right off the drum ... I've seen this happen on 6 volt FLS winches with welded aluminum drums, to say nothing of wood.
Please be very, very careful with your experiments.
tkallev is offline Find More Posts by tkallev
Old Sep 23, 2011, 09:26 PM
MrE
Joined Aug 2007
Again, your Castle esc will save the day - it has a built in, programmable break function and will stop the motor as fast or slow as you want.
Edit: oops - didnt see MiamiMike already suggested that.
Old Sep 23, 2011, 09:33 PM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
In fact our thread starter, hornet_dave, mentioned it himself in his post #10.
Discussion Bixler battery experiment (FPV step 1) raRaRa FPV Talk 10 May 21, 2014 02:27 PM
Idea rigid direct swash rotorhead experiment Alwayscrash Micro Helis 5 Apr 19, 2011 08:36 AM
Video rigid direct swash rotorhead experiment Alwayscrash Electric Heli Talk 0 Apr 10, 2011 04:55 PM
Discussion F3J Winch (with brushless system!) biesas DIY Electronics 21 Jun 16, 2010 08:06 PM
12.5" Span Brushless F-15 Experiment Lost In OC Pusher Prop Jet Models 27 Mar 09, 2005 07:08 PM
