Old Mar 30, 2015, 03:40 PM
Matthew0 is offline
Find More Posts by Matthew0
I would rather be at the field
United States, GA, Adairsville
Joined Jan 2015
What tools are needed to cover a airplane?
I am getting near the of my first kit and I need to cover it. I have a covering picked out but I am not sure what tools I need. I was planning on taking the plane to my club and seeing if I could get some help covering it. I'm just not sure where I need to go from here and I was hoping to get some advice. I messed up this is not a scale plane
Matthew0 is offline Find More Posts by Matthew0
Old Mar 30, 2015, 07:05 PM
slow_flier is offline
Find More Posts by slow_flier
slow_flier's Avatar
United States, PA, Pottstown
Joined Dec 2009
Mo problem. Most of us build sport planes as well.
The real question is which covering are you planning on using? The tools required depend on the covering being applied.
If you're using an iron-on, you will need a sharp blade and a sealing iron of some type. Most of the iron-ons are hard on the edge of your knife, I often use a single edged razor blade they're sharp and cheap. I don't mind using 2 or 3 on a covering job. A hot air gun is also useful if the project is large enough. Be careful with it you can easily burn a hole in the covering if your not.
For a tissue and dope covering, the tools are the same sharp blade and/or a fine sanding block to trim are tissue once its dried in place. I've only done 2 or 3 tissue jobs so if others have a more complete list here they should jump in.
Other tools you will fine useful are a couple of straight edges, I have them in various sizes ranging from 12 to 48", and a good grain free cutting surface. I use either a steel sheet or a piece of tempered glass. I prefer the glass since it doesn't scratch as easily, but the steel sheet is larger.
I'm sure that as you progress you will find other tools that you like.
slow_flier is offline Find More Posts by slow_flier
Old Mar 30, 2015, 07:07 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
what covering do you have in mind?
Tools /Techniques vary... Widely... dependent on the Covering type.
Esaki Tissue is a helluvatot different than Monokote.. which in itself is also very different from Doculam.
Bare is offline Find More Posts by Bare
Old Mar 30, 2015, 07:51 PM
Matthew0 is offline
Joined Jan 2015
I was looking at the solar film from mountain models. It is an iron on covering. I have a hair dryer but I am not sure if that is hot enough. Is a sealing iron any different from a regular one?
Old Mar 30, 2015, 08:44 PM
slow_flier's Avatar
Joined Dec 2009
You are right the hair dryer won't get hot enough. If it did, I'd have burned off what little hair I have left. What you need here is more of industrial hot air gun.
If normal iron is one you use to iron your clothes, then yes, a sealing iron is different.
I would suggest that you go to either www.tower hobbies.com or www.horizonhobby.com and look at their collection of covering tools. I really like the 21st Century iron from Tower, but still have the older style Monokote and Black Baron irons. Both styles will work well if you follow the directions that come with the covering.
As Bare pointed out, all of the different coverings are different. Monokote is different from solar film which is different from Coverlite, and so on. We all have developed favorites over the years and tend to stay with what we know. Over the last few years I have tried to experiment with different materials and have success with most of them if I stayed with the instructions.
Good luck
Tom
Old Mar 31, 2015, 12:33 AM
peterlngh is offline
Find More Posts by peterlngh
Joined Apr 2012
Hi, Matt.
Good cutting tools are important too. A brand new X-Acto balde or fresh single edge razor work great. For long straight cuts a good sharp pair of scissors can be a great help.
Cheers!
peterlngh is offline Find More Posts by peterlngh
Old Mar 31, 2015, 02:40 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
You can get enough heat from a normal clothes iron for Solarfilm, the problem with it is that it's a bit big and heavy to use on lightweight balsa models. But I did use one for a year or two before I bought a proper sealing iron (which is much easier to use).
You can do the shrinking using just the iron but a heat gun is useful. Hair dryer isn't hot enough but a paint stripping heat gun can be used if you're REALLY careful (don't get it too near and always keep it moving).
The proper modelling versions of those tools aren't really vital but they do make things a lot easier.
Steve
slipstick is offline Find More Posts by slipstick
Help! What covering should I use on my airplane? Matthew0 Scale Kit/Scratch Built 4 Feb 12, 2015 08:21 AM
Discussion Need help on what tool for this kcobello Multirotor Electronics 0 Jan 20, 2015 10:30 AM
Discussion What Airplanes are youI interested in? Mode One Scale Fuel Planes 56 Nov 06, 2013 04:17 PM
Question What code development tools are used? SatelliteBiker Multirotor Electronics 3 Oct 19, 2013 10:29 PM
new to elctronic programming what tools are need? Bladers DIY Electronics 2 Nov 27, 2005 05:16 PM
