Old Mar 31, 2015, 10:06 PM
jcfab is offline
Find More Posts by jcfab
Landing, HEY, I got it!!!!!
jcfab's Avatar
U.S.A. Celina, TX
Joined Oct 2010
I thought I had resolved the tail heavy issue with this setup
4S4000 Glacier where you can get at it easily.
http://www.rcgroups.com/forums/showp...postcount=2480
jcfab is offline Find More Posts by jcfab
Old Mar 31, 2015, 10:33 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Yup...any extra weight helps, but, a larger, more powerful motor is still the way to go in my opinion...
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Apr 01, 2015, 10:15 AM
Yeti1234 is offline
Find More Posts by Yeti1234
Something dangerous to do!
United States, WA, Woodinville
Joined Dec 2009
Okay, so I've got one of these on the way: Motrolfly DM 4315 kv500
Seems like 15x8 is the way to go. Now to decide 5s or 6s as the motor seems compatible with both. Any input is appreciated!
Yeti1234 is offline Find More Posts by Yeti1234
Old Apr 01, 2015, 01:21 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
5S you will more than likely need to use a 16" prop, 6S 15" prop. You "could" use a 16", but it's not going to give you much ground clearance, so, you will definitely need to make good landings..
SteveT.
Old Apr 02, 2015, 05:12 PM
Bob Ruppel is offline
Find More Posts by Bob Ruppel
Nashville Metro, Tennesse, United States
Joined Jan 2004
To anyone that has bought the 58" Edge 540 from the latest batch.
Is it just as good as the earlier ones?
Bob Ruppel is offline Find More Posts by Bob Ruppel
Old Apr 02, 2015, 07:07 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
The model that is available now is the same one that has been available for a few years. If you are asking about the quality, I'm very sure they are. I bought one of the new 75" Extra's when they came out, and the quality is every bit as good any 3DHS kit has ever been.
If you are asking about a comparison between the original plane and this one as per performance. I have had both, and both fly very well, though yes a bit different. But then, my original was a 4S floater, this one is a 5S powerhouse...
SteveT.
Old Apr 03, 2015, 11:30 AM
Joined Jan 2004
Thanks to SteveT
Old Apr 03, 2015, 01:00 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
No problem....
SteveT.
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 09:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 09:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2010 11:12 PM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 12:52 AM
