Old May 15, 2015, 05:26 PM
tamp is offline
Find More Posts by tamp
Joined May 2015
Best FPV kit 5.8 Ghz, and will ImmersionRC 600mw fit with RC832?
Hello, i'm fairly new to FPV and i'm planning to order some items. I thought about ordering the ImmersionRC 5.8 Ghz 600mW:
(http://www.hobbyking.com/hobbyking/s...le_600mw_.html )
and using it with the skyzone FPV receiver RC832 :
(http://www.hobbyking.com/hobbyking/s...er_Cables.html)
However, i'm not sure if these two are compatible? And if they are, is it a good combo? I thought about the 600mW TS832 transmitter which goes with the RC832 but i read a lot of bad reviews about it.
tamp is offline Find More Posts by tamp
Old May 15, 2015, 05:34 PM
moosestang is offline
Find More Posts by moosestang
Joined Mar 2015
They both share the same frequencies, so yes it will work together. That receiver will probably work with just about any vTx. What is it going in?
moosestang is offline Find More Posts by moosestang
Old May 15, 2015, 05:50 PM
tamp is offline
Joined May 2015
I'll be connecting the FPV receiver to an EasyCap (USB Video Capture adapter) and the EasyCap to my Samsung Galaxy S4.
Also, would the FR632 Receiver (http://www.hobbyking.com/hobbyking/s..._Receiver.html)
work better than the RC832? In terms of distance, and image quality?
Another problem i think i might experience is that the RC832 uses RP-SMA conneciton, while the ImmersionRC uses SMA -> which means i would have to buy two pairs of Spironet antennas (two SMA and two RP-SMA) which would be expensive. Is there another solution?
Old May 16, 2015, 10:41 AM
davidsz is online now
Find More Posts by davidsz
Joined Jul 2013
Boscam TS832 just $30 at SurveilZone
http://www.surveilzone.com/5.8g-600m...-fpv-tx-ws1159
and the RR632, $55:
http://www.surveilzone.com/FR632-58G...eceiver-g-1282
davidsz is online now Find More Posts by davidsz
Old May 17, 2015, 10:32 AM
tamp is offline
Joined May 2015
Originally Posted by davidsz View Post
Yes, but there are several problems. First, i read that the TS832 is not as good as it claims to be, and especially that it has a much lower power (mW) than 600mW. Secondly, i've read that the Boscam (TS832) is incompatible with Immersion Diversity receivers because Boscam uses airwave or some other sort of frequency type, and the other companies uses other sorts. Which means that the RR632 is incompatible with TS832.
Thirdly, i believe the TS832 uses RP-SMA and the FR632 uses SMA. This would be problematic because i would then have to buy two pairs of antennas, one RP-SMA pair and one SMA pair.
Old May 24, 2015, 10:53 AM
Joined Jul 2013
In that case, you can have a look at TS5828, SMA connector, just $29
Old May 27, 2015, 03:00 AM
immortals is offline
Find More Posts by immortals
Joined Apr 2015
TS5828 is $26.99 in foxtech, cheaper than this.
immortals is offline Find More Posts by immortals
Old Yesterday, 07:11 AM
itwasntme is online now
Find More Posts by itwasntme
Joined May 2015
i have exact same problem, trying to find good fpv set, can't go with boscam TX, as it won't fit to my setup.
itwasntme is online now Find More Posts by itwasntme
For Sale Immersionrc 5.8 ghz VTX 600mw With GetFpv Lumenier CM-650 jwwrighrc FPV Equipment (FS/W) 7 Mar 04, 2015 03:15 PM
Sold FPV 5.8 GHz 32CH RC832 Receiver With A/V and Power Cables cruisercruiser FPV Equipment (FS/W) 2 Aug 25, 2014 04:16 PM
Sold ImmersionRC 600mW 5.8 GHz Transmitter V2 & 5.8 GHz SpiroNET Omni SMA Antenna Set Chad2323 FPV Equipment (FS/W) 5 Nov 12, 2013 04:03 PM
Wanted ImmersionRC 600mW 5.8 GHz Transmitter - Fatshark compatible sharonx FPV Equipment (FS/W) 7 Feb 20, 2012 08:38 PM
