Old Sep 08, 2014, 11:41 PM
Albuquerque USA
United States, NM, Albuquerque
Joined Dec 2012
New Product
RCTimer Y6 Tri-Trooper 900 Carbon Fiber Frame - Integrated PCB Version
Specifications:
- 30 mm carbon fiber booms
- 2.5mm carbon fiber Mount(Battery and Gimbal) plate
- Injection molded motor mounts
- Flight controller position between the frame plates
- Pre-drill for 45x45 flight controller patterns
- 28 mm to 52 mm motor size
- INERTiC camera mounts
- 20 mm carbon fiber landing poles
- 900mm size
- Y6 shape
- Frame weight: 1159g
Main Board:
8 ESC Distribution board
XT60 Connector
6050 mold for 32 BIT Brushless GIMBAL
LED 1W
LED module socket for ESC and Motor
Gopro AV signal input
12V 3A BEC output & AV signal input (1 way socket provides AVOUT /12V/GND for FPV, other three only provides 12V output)
5V 3A BEC output & AV signal input (1 way socket provides AVOUT /5V/GND, for FPV, other three only provides 5V output)
Battery Voltage Tester
Just received today and did some un-boxing pictures will start the build soon. Any question feel free to ask.
It look pretty good and big. I will post my finding the good the bad and the ugly when i start the build.
installation manual http://www.rctimer.com/download/Y6Tri-Trooper.pdf
Askyvision is offline Find More Posts by Askyvision
Old Sep 09, 2014, 11:12 AM
Drones everywhere :)
esite's Avatar
Czech Republic, Hlavní město Praha, Prague
Joined May 2013
Manual
Did you receive any manual how to solder the ESCs and what pin is for what ? Mine came without any manual
esite is offline Find More Posts by esite
Old Sep 09, 2014, 11:19 AM
Albuquerque USA
Joined Dec 2012
Nope no manual but it pretty self explain. It lable on the PCB M1,M4 on the back M2,M5 on the right and M3,M6 on the left. Yeah it would be nice to at lease have a manual explain what those are for and a lots of empty pin
I post a lots of picture in order to help people build their because of no manual
Old Sep 09, 2014, 01:52 PM
esite's Avatar
Joined May 2013
I looking forward for your build which motors and FC you want to use ?
Old Sep 12, 2014, 03:28 AM
689PH's Avatar
French Polynesia, Windward Islands, Māhina
Joined May 2013
boom thickness 0,73 !!!
Is it enought for 900 mm ?
689PH is offline Find More Posts by 689PH
Old Sep 13, 2014, 01:01 AM
rctimer's Avatar
Hong Kong, Pok Fu Lam
Joined Sep 2009
Originally Posted by Askyvision View Post
Specifications:
- 900mm size
- Y6 shape
Main Board:
XT60 Connector
LED 1W
Hi Askyvision,
Very great assembled!
We will change Hex screws instead of T7 in the future.
Thanks.
Frank
rctimer is offline Find More Posts by rctimer
Site Sponsor
Old Sep 16, 2014, 01:48 AM
Joined Jul 2009
Can this frame take 2 6s 5000 mah battries with 15" prop and 4114 motors ?
gurudutt is offline Find More Posts by gurudutt
Old Sep 16, 2014, 03:06 AM
Albuquerque USA
Joined Dec 2012
I would go with 17-18" for long flight time. Even 16" on it have plenty of room for props. Y6-900 is huge. I'll take a picture with 15" and 16" for you to see.
Old Sep 16, 2014, 04:13 AM
rctimer's Avatar
Joined Sep 2009
We will release X6 motor ASAP, it work on Y6 is perfect, Thanks.
Frank
Site Sponsor
Old Sep 16, 2014, 05:28 AM
Joined Jul 2009
Is their space to mount 2 6s 5000mah lipos and is the frame strong enough to fly with this setup
Old Sep 18, 2014, 10:11 AM
Germany, NRW, Düsseldorf
Joined Aug 2012
Hi,
my new Y6 Trooper will be here the next days.
I was wondering if anyone managed to get the PCB manual downloaded?
http://www.rctimer.com/product-1152.html
PCB Board manual:
http://www.rctimer.com/www.rctimer.c...oardManual.pdf
EDIT: Link must be http://www.rctimer.com/download/RCTI...oardManual.pdf
Mike_78 is offline Find More Posts by Mike_78
Old Sep 19, 2014, 03:41 AM
Joined Jan 2014
Is the PDB rated for 6s
raybans is offline Find More Posts by raybans
Old Sep 19, 2014, 04:37 AM
Albuquerque USA
Joined Dec 2012
I just got this for the Y6. I talked with rctimer to see if they could assist on this project about motors and esc but they refuse so I got the foxtech. I hope it good
http://www.foxtechfpv.com/foxtech-mo...00-p-1681.html
I will go with maytech esc 40a slim with Blheli. Swinging 16" on top and 17" on the bottom. Hopefully everything be done before cold weather kick in
Old Sep 19, 2014, 05:56 AM
Aaalie's Avatar
Netherlands
Joined May 2006
There is a balancer connector for 8S.
Aaalie is offline Find More Posts by Aaalie
Old Sep 19, 2014, 02:01 PM
Albuquerque USA
Joined Dec 2012
the funny thing is the connector is only for 8s and not any other battery unless you have to cut the slot to fit 4s 5s or 6s
For Sale esc32 , carbon fiber tri (y6)REDUCED Cc3dpilot Aircraft - Electric - Multirotor (FS/W) 0 Mar 08, 2014 09:34 AM
Sold Micro Integrated PCB w/ESCs Quadcopter Frame 235mm (PARTS) bennymack Aircraft - Electric - Multirotor (FS/W) 2 Oct 17, 2013 09:09 PM
Sold H550 V2 Glass Fiber Hexcopter Frame 550mm - Integrated PCB Version kayvannouri Aircraft - Electric - Multirotor (FS/W) 0 Jun 18, 2013 07:27 PM
