Old Yesterday, 04:23 PM
JimDrew is online now
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Originally Posted by jcyr1 View Post
Excuse me.........what is OFS? (One Finger Salute?)
Open Flight Stabilizer:
http://www.rcgroups.com/forums/showt...&highlight=OFS
Here are the links to OpenAero2:
http://www.rcgroups.com/forums/showthread.php?t=1708175
...and OpenAeroVTOL:
http://www.rcgroups.com/forums/showt...t=OpenAeroVTOL
The OpenAero series supports the Xtreme serial protocol (besides SBUS, CPPM, and Spektrum satellites), so you can plug a Nano or RFU directly into the board and use it.
JimDrew is online now Find More Posts by JimDrew
Old Yesterday, 04:28 PM
Lake Havasu, AZ
Joined Jun 2005
Originally Posted by ckleanth View Post
Jim, I was talking about interrupt processing, pid scheduling & send servo signal sequentially to minimise the possibility two servo start moving at the exact same time. When ofs started openaero2 had similar issues.
Umm... No it didn't. The servos have never started at the exact same time. OpenAero2 uses the same servo output control mechanism that our products have used for years - that's because it came from me (see the credits). There is a maximum separation of 100us between the start of each servo outputs with OpenAero2. Our products use a maximum of 71us.
The original OpenAero2 PWM outputs were true sequential (one after another), which means the latency varied depending on the exact position of the sticks. Switching to my servo output method reduced latency by as much as 14ms, and more importantly, it made the servo outputs occur at virtually the same time. This is critical when you have multiple servos on the same surface or need two or more surfaces to move at the same time - not delayed by some random amount of time.
Old Yesterday, 05:45 PM
jcyr1 is offline
Find More Posts by jcyr1
United States, AZ, Surprise
Joined Jul 2002
Thanks for the explanation. Guess I've retired too long????
Got one on order along with the USBasp.
jcyr1 is offline Find More Posts by jcyr1
Old Today, 01:16 AM
ckleanth is online now
Find More Posts by ckleanth
If it has wings it will fly...
ckleanth's Avatar
United Kingdom, England, Birmingham
Joined Mar 2011
i may have got it wrong but i believe when ofs started i don't think it contained your servo output method. Doesn't really matter, the codes now implement two different methods. With ofs two servo that move the same control surfaces (ailerons/split elevators etc) need to be defined one after the other on the channel list - this minimizes response differences and tbh it is not noticible. One cant even blink that fast
ckleanth is online now Find More Posts by ckleanth
Old Today, 12:40 PM
Lake Havasu, AZ
Joined Jun 2005
It does make a difference for ganged servos, and swash plates!
Note: yes, I cleaned up the thread...
Question X10+ Expander with Nano - customer comments please... JimDrew Xtreme Power Systems 48 Sep 22, 2013 09:54 PM
Discussion Channel expander question Engineer Bill Xtreme Power Systems 9 Jun 24, 2013 05:08 PM
Sold Parkzone X10 6 channel transmitter Tampatexan Aircraft - General - Radio Equipment (FS/W) 0 Jun 10, 2012 07:15 AM
Sold Berg 5 channel receiver w/ 4 channel expander Fizzy Aircraft - General - Radio Equipment (FS/W) 0 Oct 02, 2008 05:52 PM
