Old Mar 19, 2015, 08:23 AM
drewtronics is offline
Find More Posts by drewtronics
United States, CA
Joined Jan 2014
Originally Posted by odontologo98 View Post
different cameras require different capacitors?
I don't know, but as you have shown placing the cap in front of the vtx can fix this problem when placing it in front of the osd does not. And I did not know it would make any difference.
Andrew
drewtronics is offline Find More Posts by drewtronics
Old Mar 24, 2015, 09:10 AM
odontologo98 is offline
Find More Posts by odontologo98
Joined Oct 2008
the problem came back and then I changed the firmware.
I do not need the capacitor.
OSD data is rock solid on the screen,
the problem was in the firmware.
Fabricio.
odontologo98 is offline Find More Posts by odontologo98
Old Mar 24, 2015, 09:49 AM
United States, CA
Joined Jan 2014
Glad you got it! firmware is the right way to fix it for sure.
I wish that had done the trick on mine, it was the first thing I tried on the 41.
Old Apr 02, 2015, 02:04 PM
Gibbedy is offline
Find More Posts by Gibbedy
Australia, VIC, Berwick
Joined Oct 2013
Attitude adjustment bug?
On my latest build running 41ap heavy my wing tries to descend in abm and rtl.
I am setting attitude with plane level using stick command.
The following video is hands off elevator in abm with plane in steady dive, but osd shows the 41 thinks it's level.
(uploading now)
Attitude adjustment Bug? (0 min 16 sec)
I fix this issue by resetting attitude with nose significantly up.
I have spoken to a mate and that's what he's been doing also.
Has anyone else seen this?
Gibbedy is offline Find More Posts by Gibbedy
Old Apr 09, 2015, 10:04 PM
Spitfirekid is offline
Find More Posts by Spitfirekid
Spitfirekid's Avatar
New Zealand, Auckland
Joined Aug 2011
(uploading now)
http://youtu.be/LTvPqUn-y5M
Same here , as soon as i put it stab mode or rth the nose goes down and speed goes up, have tried everything to correct this but will try setting gyro with nose up as you say
Spitfirekid is offline Find More Posts by Spitfirekid
Old Apr 10, 2015, 10:01 AM
nslmanu is offline
Find More Posts by nslmanu
Joined May 2014
Hey gyus,
Just received my HP Stream 7" .... and of course installed the last GCS 5.11 software, but each time i launch it : it crashs directly ...
I activated the .NET 3.5 , to check the windows compatibility with some tests ... but still the problem. I saw that i'm not the only one on the web but without any solution.
Someone has some new ideas ? tks in advance.
nslmanu is offline Find More Posts by nslmanu
Old Apr 15, 2015, 02:26 PM
FPVxfun is offline
Find More Posts by FPVxfun
Italy, Veneto, Verona
Joined Oct 2014
Originally Posted by Juanantonio View Post
Hi ,I'm having problems with the set up of fy41 light .
I have the fy41 normal version for I year and it works perfectly
Now I buy the light version and mount it to a X8 and configure it with out problem
But when selecting ACM or RTL mode there is now respond on the motor , the wing try's to auto circle or return to launch but it enter in stall,I have change the speed parameters via OSD but nothing happens please give an idea of what is going on thank you
I had a similar problem for many month. Switching from ABM to RTL mode, My Skymule started the flight to home but FY41 cut the motor power then the plane started to flight into a screw. Entering the screw i tried many times to increase power and correct the screw effect with opposite aleiron action but the solution was unuseful and i crashed at least 3 times in 4 month. Today for the first time i was able to get out of ther screw: it is necessary to quickly switch out from ABM (to 3D or RC for example).
Today I also solved my problem of motor shutdown in RTL mode: I changed fron Normal to Reverse the throttle channel into FY41 parameters.
FPVxfun is offline Find More Posts by FPVxfun
Old Apr 18, 2015, 07:33 AM
philgib is offline
Find More Posts by philgib
philgib's Avatar
Joined Oct 2005
OSD shows about 1.1v below the true voltage , as I landed and measured the battery voltage of my batteries at 15.1v.
Is there any trick to have the OSD show the right voltage ? I want to reach a one-hour duration flight but I need to rely on a proper voltage.
Thx
philgib is offline Find More Posts by philgib
Old Apr 18, 2015, 07:00 PM
Gorrie is offline
Find More Posts by Gorrie
Joined Apr 2010
Latest version of the firmware in conjunction with the latest version of the GCS has the ability to calibrate the OSD voltage.
Gorrie is offline Find More Posts by Gorrie
New Product Fy-41AP OSD & autopilot system is coming RC4YFPV FPV Equipment 317 Sep 18, 2014 05:01 AM
Question Is fy-31ap and the Hornet OSD compatible with fy-90qpro? mgs0098 FPV Equipment 1 Sep 23, 2013 03:15 AM
Question Is fy-31ap and the Hornet OSD compatible with fy-90qpro? mgs0098 Power Systems 1 Jan 11, 2013 03:47 PM
Idea FY-21AP/FY-31AP and OSD FY Extender hefest FPV Talk 6 Nov 05, 2012 04:45 PM
New Product FY thread: FY20A/FY21AP/FY3ZT/FY31AP/FY90Q/FY91Q/FY-Frame/FY-GCS/FY-OSD/FY-Dataradio yiny0730 FPV Talk 316 Sep 19, 2011 01:30 PM
