Old Jul 21, 2014, 03:22 PM
Gilbert AZ
United States, AZ, Gilbert
Joined May 2012
Hot foam cutter
Show me your hot foam cutter set up for cutting wings.
Please include your setup details. Thanks.
azflyingguy is offline Find More Posts by azflyingguy
Old Jul 21, 2014, 06:22 PM
aymodeler's Avatar
United States, CT, Hartland
Joined Jul 2011
I'd love to see too ...
aymodeler is offline Find More Posts by aymodeler
Old Jul 22, 2014, 01:25 AM
Rusty
Rusty Nail's Avatar
Auckland, New Zealand
Joined Feb 2006
Pivot Cut (11 min 52 sec)
All you need to start is the thinnest guitar string, a nail and a power supply.
Simple power supply could be a servo tester connected to a brushed ESC and battery.
Rusty Nail is offline Find More Posts by Rusty Nail
Old Jul 27, 2014, 07:40 PM
Marty Petri Sr.
mbpetri's Avatar
Thailand, Uttaradit, Bo Thong
Joined Jun 2007
I use a Bow fabricated from PVC pipe and fittings. The end pieces are 1/2" PVC pipe and fittings, the center is 3/4" PVC Pipe (make sure the wall thickness allows the 1/2" PVC to slide inside, but not overly sloppy).
You can juggle the measurements to make any size bow you need. I glue the end sections with PVC cement, but not the center section, which allows me to change bow length at whim.
Marty
mbpetri is offline Find More Posts by mbpetri
Old Aug 06, 2014, 12:47 PM
Gilbert AZ
Joined May 2012
Thanks all. Searching the web gave me lots of Ideas.
Old Aug 08, 2014, 11:44 AM
Dont Know a Thing
Joined May 2014
Thoroughly addressed here...
http://www.ar15.com/mobile/topic.html?b=3&f=4&t=292695
Using a transformer appears to be a popular approach.
mndless is offline Find More Posts by mndless
Question Hot Wire Cutter SayCheeze DIY Electronics 9 Nov 16, 2013 07:25 AM
Discussion Hot wire foam cutter pencon Scratchbuilt EDFs 71 Oct 27, 2013 06:23 AM
For Sale Feather Cut Foam wing machine (Hot wire foam cutter) thermalsurfer Aircraft - General - Miscellaneous (FS/W) 0 Oct 17, 2010 07:51 PM
hot-wire foam cutter with Astro 110d charger? esox Foamies (Kits) 5 Apr 25, 2002 03:28 PM
