Sep 26, 2014, 10:43 AM
Gallery
New Bubble Dancer
Finally finished my first Bubble Dancer. I had wanted to build one for some time but I knew it was going to be a large commitment of time to do it right.
Construction probably took about 100 hours, started it November 2013. There were many times when I just had to walk away from it for a while. If something was not to my liking, I redid it. Final weight is 35 OZ, 4 ounces more than Mark Drelas' prototype. I could have made target weight pretty easily but felt a few ounces over would not hurt that much. Someday I'll build another. I would just try to make the wingtips a bit lighter. I wouldn't change a thing about the design & construction. I have modified almost every plane I have built, but not this one; it is a masterpiece of design & engineering.
Thanks to Terry Johnson for supplying me with some major parts. A big thanks goes out to Mark Haley (http://aviatorstudio.net/) for his fine website that describes some of the tricky details of a BD build. That saved me a lot of re-do or mistake time.
Sep 26, 2014, 03:44 PM
craigrrr's Avatar
Very Beautiful
That is one gorgeous Bubble Dancer. It looks like 100 hours very well spent.
35 oz seems very decent for this big bird.
I hope you have many years of thermal joy with this beauty.
Congratulations on a great build!!!
Craig
Sep 26, 2014, 04:15 PM
Sardonic Curmudgeon
I agree, Very Beautiful.
So besides the wing tips where do you think the other excess weight is?
But I must say that 35 oz. for a ship that size is light!
Sep 26, 2014, 04:30 PM
The boom is about 15 grams heavy, I decided to paint the fuse and that probably added another 30-40 grams. I think the bulk of the excess weight is in the wing sheeting. I used what I had on hand which was not bad but not per Mark Drelas' spec. He specs tip sheeting to be 4 LB, increasing in weight twords the center of wing. Next time I will be much more careful i selecting & carefully weighing this.
Sep 26, 2014, 04:32 PM
Craig
Thanks Craig now its time to trim it out. I only have a few hand tosses, and have to even out the washout between wings, play with the elevator incidence & CG.
Sep 27, 2014, 10:07 AM
build what you fly!
Mark Haley's Avatar
Hey Tim,
Congratulations on finishing your Bubble Dancer! I think 35oz on your first BD is fantastic - I'm guessing that you beat my first BDs weight by about 6 oz. (Just a guess since I never actually weighed it) It took me a second try to get the weight right.
Love the blue covering. I'm going to be using blue on BD #3.
I have to agree with you on the engineering of this bird - it is truly fantastic.
As to wingtip weight - On BD#1 I did the extended tips, but on #2 I did the shorter wing. Part of that choice was for reduced weight, but ultimately the very careful selection of tip sheeting had the most impact. Even so, my tips came out at 116 grams - covered, which is 9 grams over the design...
Again. Congratulations!
Mark
Sep 28, 2014, 09:25 AM
Construction probably took about 100 hours, started it November 2013. .
Looks good. Congrats.
What fuselage did you use? I don't recognize it.
Sep 29, 2014, 02:44 AM
Proud member of LISF and ESL
The Bubble Dancer is a wonderful soaring machine. I love mine which is also about 35 ounces.
Sep 29, 2014, 07:35 AM
Wow…Congratulations clwhipper. Encouraging seeing someone bring a Bubble Dancer project to fruition and get it airborne. I’m about 16 months into a 3 plane project. One per plan, I’m using as a control, and two rather exotic material versions.
Sep 29, 2014, 09:17 AM
I wish I knew. Its very nicely done in Kevlar with CF in the right spots.
I got it from a guy who got it from a guy... from "some dude in Pensacola"
Sep 29, 2014, 09:18 AM
I got my inspiration from others as well. There are quite a few good builders out there.
Sep 29, 2014, 03:04 PM
3D Toy Designer
MicroRotors's Avatar
What pod and boom did you use?
Oct 03, 2014, 04:27 PM
I was owner #3 I believe so I'm not sure.
Boom is from ? but maybe Mountain models
http://www.mountainmodels.com/produc...products_id=42
Discussion Yet another Bubble Dancer build Magicmanyyc Sailplane Talk 33 Aug 29, 2021 09:50 AM
Wanted bubble dancer Flyzzzz Aircraft - Sailplanes (FS/W) 1 Aug 10, 2016 11:41 PM
Question bubble dancer Flyzzzz Thermal Soaring 8 Aug 08, 2016 08:32 PM
Sold Bubble Dancer (BD Wing/Ava Fuse) - NATS Pickup szastoupil Aircraft - Sailplanes (FS/W) 2 Jul 17, 2016 04:02 PM
For Sale Bubble dancer cje0114 Aircraft - Sailplanes (FS/W) 13 Mar 24, 2016 07:31 PM
