Old Jul 29, 2015, 12:08 AM
cdaher is offline
Find More Posts by cdaher
Joined Feb 2015
Quadcopter opinions and battery help
http://www.hobbyking.com/hobbyking/s...ame_600mm.html
https://www.hobbyking.com/hobbyking/...dProduct=12921
9x4.7 props
Plush 30A ESC
This is my first quadcopter ever. I was too exited and didnt check my cart and now im seeing that my motors are too big. Should I change them or do I buy a bigger battery? Probably gonna make it FPV with a gopro.
Current battery Turnigy 2200mah 30-40C 3s
cdaher is offline Find More Posts by cdaher
Old Jul 29, 2015, 01:16 AM
DaGriff is offline
Find More Posts by DaGriff
Research Junkie
Canada, BC, Duncan
Joined Jun 2015
Hello,
You'll need to spend some time calculating allot of things. Are you really good at math? It will help. You'll need to estimate the take off weight of your machine. 1.4kg maybe. multiply that by 2.2-2.5 (depends who you ask) so 3.08-3.5kg. Then divide by 4 = 770-875g of thrust you'll need to make it fly. So then you'll need to look at the spec sheet and see what prop and battery you need to get your motor to give 800g of thrust. From that you can demine the max amperage you need for you ESC. That's a start. at first glance the motors don't seems too big. spec say to use a 28-xx sized motor.
DaGriff is offline Find More Posts by DaGriff
Old Jul 29, 2015, 12:05 PM
cdaher is offline
Joined Feb 2015
Originally Posted by DaGriff View Post
Hello,
Yes i can math! It says max pull is 890g with a 2s 10x7 prop, 4s 8x4. Im going 3s 9x4. So i think im good there? Yes no idk. Max AMP is 21A, so i got a 30A for possible future upgrade. Max power is 210watt.
The thing is i already ordered all of this. So should i just change the motors or buy a 3000-3300kv with high discharge?
Im not very experienced with RC stuff as you can see.
Old Jul 30, 2015, 01:11 AM
DaGriff is offline
Research Junkie
Canada, BC, Duncan
Joined Jun 2015
I think what you have is going to work fine. The best thing you can do is set it up and fly it and see if your happy with the performance and flight times. If you get a faster spinning motor higher Kv, then you'll need to get a smaller props. Also a faster spinning motor with a small prop uses more energy than a slower motor with bigger prop. For example I have 800kv motors with 11x5 props. Mx draw is abou 12-13a. So I have 20a esc, on 3s power. You might have been able to save some $. Again, just build it and get it in the air before you spend more money. Then upgrade as you need too to get the performance you want.
Old Jul 30, 2015, 02:38 AM
DaGriff is offline
Research Junkie
Canada, BC, Duncan
Joined Jun 2015
Check this out,
How to select the right motor for your multi-rotor (all types - Tri, Quad, Hex etc.) (9 min 10 sec)
Old Jul 30, 2015, 07:16 AM
Oldgazer is offline
Find More Posts by Oldgazer
FA3PR9WM79
Oldgazer's Avatar
United States, VA, Richmond
Joined Dec 2013
9x4.7 props
Plush 30A ESC
I'm running 2212's on 3000mAh 3S Zippy LiPo, swinging 1045 props.
I'm using an APM 2.6 with GPS, 915mHz Telemetry radios, 700 line camera, 5.8gHz 200mW video transmitter, and MavLink OSD.
Radio is a Fly Sky TH9x, receiver is an FS-R8B.
Video Rx is a Boscam RC805. I have a 7" TFT monitor attached to the radio and I also have the Qunanum V2 goggle. I'm waiting for an RC305 rx so I can separate the monitor and the goggle. I use a 2S 1300mAh Nanotech LiPo to power the RX and monitor, and a separate 1000mAh Lipo to power the goggle. I did this to keep the RX from overheating...
To get ground station functionality I have the 3DR ground radio connected to my Android smartphone and I run 3DR's Tower app. The phone is mounted to my transmitter with a Walkera Type B phone holder. The ground radio is held to the monitor sun shade in a cloth pouch...
With the battery installed, the aircraft All Up Weight is 1543 grams. Flight time is around 7 minutes with 2000mAh used.
Oldgazer is offline Find More Posts by Oldgazer
Old Jul 30, 2015, 07:43 AM
Oldgazer is offline
FA3PR9WM79
Oldgazer's Avatar
Joined Dec 2013
Actually, motor/battery selection is counter intuitive.
For a small, light aircraft like a 250 FPV racer you want high kv motors, "small" props and 3S "high discharge" LiPos.
With a heavier aircraft like a quad or hex photography rig you want low kv motors, 4S or 6S LiPos and big props.
As an example, I run 2212-1000Kv, 3S 3000mAh 20C LiPo, and 1045 props on my X-525 FPV rig. On my Tarot 680 Pro hex, I run 4006-740Kv, 2 4S 5200mAh 10C LiPos in parallel, and 1355 CF props.
With the X-525 I get about 8 minutes of flight time. With the 680 I get about 20 minutes...
Question Opinion/ Suggestions for my quadcopter build nevets_1917 Multirotor Electronics 2 May 18, 2014 05:41 PM
Help! Opinion in buying a Quadcopter PauloFerreira Mini Multirotors 3 Mar 30, 2014 10:31 PM
Build Log Aerial photography quadcopter components - Opinion please DirtyS Multirotor Talk 6 Jan 06, 2014 01:12 PM
Discussion My quadcopter is going FPV. Help choosing the right battery. fapelbaum Batteries and Chargers 1 Jun 11, 2013 06:15 PM
Question Quadcopter Motrs +esc+battery Need Help! Theelectronicguy Multirotor Talk 2 Nov 14, 2011 06:59 PM
