Old Jun 18, 2013, 04:54 PM
navihawk is online now
Find More Posts by navihawk
United States, FL, Orlando
Joined Nov 2006
Question
Antenna Mixing
hello everyone. I have flown fpv before with planes and quads. i took at break and now i am getting back into it. Im using a 900mhz 250mw video tx and i am mainly going to by flying about 1-2 miles away for me max. Got a twinstar 2 that will begin working on soon thats going to by my main aircraft. I was just wondering what type of antenna i should use. I know a little about them, but what i want to know is can i use a 900 mhz circular polarized antenna for the Rx and an Inverted V for the airplane? or is it better to use both circular antennas for both plane and rx, it just they seem kind of big to be sitting ontop of the airplane? thanks. I also have a 8dbi patch i had been using before with a 3dbi rubber duck on the airplane. thanks.
navihawk is online now Find More Posts by navihawk
Old Jun 18, 2013, 05:56 PM
1fullbird is offline
Find More Posts by 1fullbird
1fullbird's Avatar
United States, NE, Omaha
Joined Nov 2011
The Tx & Rx antenna types should match for the best result. Either two circular polarized or two linear. I run the 900 MHz with an Inverted V to a Biquad for longer range. The 5.8ghz gear are circular polarized, same with my 1280mhz stuff.
1fullbird is offline Find More Posts by 1fullbird
Old Jun 19, 2013, 04:19 AM
julie32 is offline
Find More Posts by julie32
United States, GA, Atlanta
Joined Oct 2009
You can mix them with some loss. I use a inverted Vee on my Tx and a skew planner on the rx with 900mhz. I think 2 miles might be hard to get. I have 500mw and I dont think I have been 2 miles with the mix. I have a rca switch that I use to switch to a Biquad when the signal starts dropping.
julie32 is offline Find More Posts by julie32
Old Jun 19, 2013, 12:17 PM
Joined Nov 2006
Sorry i have a 500mw 900mhz tx, from all i have read that should be plenty of power for 2 miles. So i understand its best to use both same antennas. So i can use 2 inverted V one for the Tx and one for the Rx? or V doesnt work good on Rx?i figured my patch on the Rx and the V on the airplane would make a good combination?
Old Jun 19, 2013, 12:50 PM
rob38 is offline
Find More Posts by rob38
rob38's Avatar
Noord Holland
Joined Oct 2007
hi
if you got linear ant on your plane,and circulair ant on your vrx
you last 3 db signal
linear works fine for 900 to 1300
2400 mhz and 5800 circulair works better
rob
but if your plane can have a circulair 900 to 1300 that,s works fine to they are big,that,s only problem
rob38 is offline Find More Posts by rob38
Old Jun 19, 2013, 06:02 PM
1fullbird's Avatar
Joined Nov 2011
Correct. Inverted Vee on the Tx and the patch for the Rx.
Old Jun 19, 2013, 06:58 PM
Joined Nov 2006
ok thanks a lot for the help guys
Old Jun 19, 2013, 07:04 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
For whatever it's worth, the classic L-COM 8dB patch is not that great on 900Mhz.
The ground plane is just too small.
Inverted Vee on the plane and Biquad on the ground is a much better combo and
will reach out several miles.
As mentioned above, mixing linear and CP antennas will result in a straight up 3dB loss, which
is half the received power, or about 30% reduction in range which will make it hard
to get 2 miles on omnis alone.
Daemon is online now Find More Posts by Daemon
Old Jun 19, 2013, 07:40 PM
Joined Nov 2006
ground plane? what does that mean? im thinking maybe switching to 1.3 those circular antennas are smaller.right?
Old Apr 20, 2015, 10:45 AM
adamtoo is online now
Find More Posts by adamtoo
Sweden, Norrbotten County, Luleň
Joined Sep 2014
When mixing linear and cp video antennas there is a 3 db loss, got it. However, might there be some other benefits to this setup? If I run a linear tx on 1.3 and a cp rx, might I have less dropouts to due a banking plane that puts the tx antenna out of polarisation with the rx antenna?
adamtoo is online now Find More Posts by adamtoo
Old Apr 22, 2015, 02:20 PM
BigSwedeFPV is online now
Find More Posts by BigSwedeFPV
Sweden, Halland County, Halmstad
Joined Sep 2013
Hmmm..interesting.... Im thinking, Gatling and Yagi on ground connected to Eagleeye and inverted V on plane.... Any thoughts? I have all the stuff, might worth testing
BigSwedeFPV is online now Find More Posts by BigSwedeFPV
Old Apr 22, 2015, 02:46 PM
Joined Sep 2014
Well after testing I can report that linear on tx and circular on rx works fine. Range is reduced but its nice for close in flying because I dont have the polarization dropouts seen with linear linear. And I dont have to put my fragile and expensive and huge 1.3 cp antenna on small planes.
Old Apr 22, 2015, 11:07 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Skip the Gatling unless you are putting circular on the airplane. If using linear either 2 yagis or two BiQuad antennas aimed a few degrees apart for good coverage will do well.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Apr 22, 2015, 11:08 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The CP antenna shouldn't be fragile. Mine have been slammed into the Earth countless times. I just bend them back.
-Alex
Old Apr 23, 2015, 03:06 AM
Joined Sep 2014
Good to hear, I have bent mine back a few times and was worried it wouldn't take the continued abuse but now I will get back to slamming it into the ground
-Alex
Question Delta wing mixing/V-tail mixing Schwarzadler Radios 18 Mar 22, 2013 06:04 PM
Sold Antenna Pan/Tilt & 1.3 GHz Crosshair Antenna (IBCrazy) Donger512 FPV Equipment (FS/W) 1 Feb 05, 2013 12:02 AM
Discussion Mixing antennas types on my divercity reciever? rvski FPV Talk 2 Oct 24, 2011 08:16 AM
Discussion Limited No. of Mix-1,Mix-2 and Mix-3 on Evo-9 sirod Radios 3 Aug 11, 2006 11:35 AM
Discussion Limited no of Mix-1,Mix-2 and Mix-3. sirod Hitec/Multiplex USA 2 Aug 06, 2006 10:30 PM
