Old Jul 20, 2010, 12:52 PM
Stingray8854's Avatar
USA, LA, New Iberia
Joined Jan 2009
Variable Charging NiMH Batteries
Hey guys, I have two questions. I fly a Firebird Phantom and it came with a variable rate charger which is adjustable from 0.3 to 0.5, for 300 - 500 mah NiMH batteries of 4 to 7 cells. The packs I use are 7 cell, 8.4v, 300mah, for a 180 size motor. The first question I have is, other than the first few charges, is there any advantage or benefit (ie stronger charge, or extended battery life) to be had from charging at 0.3? I've been charging them all at 0.5 and they're warm and "motivated" when I fly them right off the charger, but I think I read somewhere that it's good to charge them on the low rate sometimes. Can anyone verify this? Or call BS if it's not true? Second question. The charger works from a wall adapter or plugs into a cigarette lighter. I use it both ways, but in my truck ('07 GMC Sierra) the charger only seems to work when the engine is running. Seems like maybe it needs a bit over 12 volts to charge. The same outlets power up my cell phone charger and radar detector, with the ignition and engine off. My plane's charger needs not only the ignition on but also the engine running. Is this common? Maybe it's something built in to help prevent the vehicle's battery from being depleted. I'm thinking of using a cheap 12 volt battery and a boat type cigarette lighter outlet to connect directly to charge and/or top off my other packs while I'm flying, so I don't have to burn gas idling my truck to charge. I figure a good full charge on the 12 volt battery should last for probably at least a few weeks, but I'm just guessing, and maybe it won't even work. ANYHOO... I know this is a bit long-winded. Thanks in advance for any advice on these issues.
Stingray8854 is offline Find More Posts by Stingray8854
Old Jul 20, 2010, 02:22 PM
Wasaga Beach, Ontario
Joined Aug 2007
Generally, you shouldn't charge a battery above 1C. So a 300Mah battery should not be charged above 0.3 amps. It should take just over an hour to fully charge.
kalnaren is offline Find More Posts by kalnaren
Old Jul 20, 2010, 03:24 PM
USA, LA, New Iberia
Joined Jan 2009
So does charging at this rate provide a stronger or more thorough charge?
Old Jul 21, 2010, 08:32 AM
Joined Aug 2007
It provides less chance of damaging the battery. Charging faster will heat the battery up more. Heat will kill batteries. Now, that's not to say they shouldn't be warm. A battery will warm up during charging and probably get warmer during discharge, but it should never be so warm as to be uncomfortable to handle, and it should NEVER be too hot to touch.
Charging at faster than 1C generally produces more heat than is necessary. I don't know if it provides any less thorough of a charge, but it's certainly harder on the battery.
Discussion charging nimh batteries for radios phil alvirez Radios 21 Aug 05, 2010 08:54 AM
Discussion Need a simple CHEAP NIMH charger with variable rates. ty_horn Batteries and Chargers 1 Jun 23, 2010 12:47 AM
Discussion Charging new NiMH batteries hefest Beginner Training Area (Aircraft-Electric) 8 Oct 03, 2009 08:52 PM
Charging NiMH batteries? rsieminski Power Systems 1 Nov 18, 2001 09:22 PM
Charging Nimh batteries rcnutt Electric Plane Talk 8 Nov 02, 2001 09:52 AM
