Old Jun 28, 2015, 09:37 PM
tsenecal is online now
Find More Posts by tsenecal
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
what type of water are you putting it in? pool, pond, ocean?
tsenecal is online now Find More Posts by tsenecal
Old Jun 29, 2015, 08:59 AM
knucklebutt is offline
Find More Posts by knucklebutt
Joined Mar 2010
should have listed that
its a pool in arizona water temp right now is 92 deg
knucklebutt is offline Find More Posts by knucklebutt
Old Jun 29, 2015, 09:12 AM
Cliff Hanger is online now
Find More Posts by Cliff Hanger
California Desert... 7 miles from nearest town
Joined Jan 2010
Pool.
Might find out when they put chlorine in the water.
Pick days just ahead of this to run.
Chlorine reduces signal penetration in water.
Cliff Hanger is online now Find More Posts by Cliff Hanger
Old Jun 29, 2015, 10:18 AM
Joined Mar 2010
wondered about that ill give that a try
btw what depth should i expect this to run at before signal loss ???
Denis
Old Jun 29, 2015, 10:53 AM
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
i run my Delta and Alvin in the local pool here in colorado. I get penetration all the way to the bottom of the 8 foot deep end when using 75mhz gear. water temp is no where near 92 degrees, but it is a chlorinated pool. you might also consider chatting with the pool maintenance people to see how much chlorine and other chemicals they use. the more particulates there are in the water, the worse your reception will be.
THUNDER TIGER 42 GP on Ebay - only $15.50!! ENDS TUE 9-14 night bentgear Aircraft - Fuel - Airplanes (FS/W) 0 Sep 13, 2004 11:18 PM
THUNDER TIGER 42 GP on Ebay - only $5!! bentgear Aircraft - Fuel - Airplanes (FS/W) 0 Sep 10, 2004 05:16 PM
Good Deal on Thunder Tiger Ducati RTR!! grymg Motorcycles 8 Jun 24, 2004 04:52 AM
